Old 01-25-2011, 11:28 AM   #1
Chim-
Member#: 253747
Default Abnormal Idle
I have a 96 Legacy AWD 2.2 and I am having an odd idle problem... after the car has been driven for a little while and gets to full temp when I come to a stop my idle likes to sit high.. at about 1300rpms... then I can kick the throttle down really quick and it will idle where it is supposed to.
The linkage looks clean and not gummed up... I read it might be an Idle valve or something like that?
Any help or similar experiences?
Thanks!!!!
Chim- is offline   Reply With Quote
Old 01-25-2011, 12:30 PM   #2
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Yeah try the idle air control valve on the throttle body. They can get dirty and throw off your idle. The same can also be said for the maf sensor. I would try cleaning both of those and see how it goes.
Mike
GrimmSpeed is offline   Reply With Quote
Old 01-25-2011, 01:12 PM   #3
Chim-
Member#: 253747
Sorry for the noob question, but do you have a pic of the idle air control valve?
Old 01-25-2011, 10:41 PM   #4
prezarevo
Member#: 266930
2004 WRX
Look at your intake piping and follow the biggest hose coming off of it. it'll lead you next to the upper left of your coil pack. It will have the main vacuum hose connected to it that I mentioned to follow and two smaller hoses on the left and rite towards the bottom of it. and will also have a three pin plug going to it. and if that isnt enough, Look for three small letters A,B,C behind the plug. The top will either be gray or brown plastic and the base will be metal. There is four 8MM bolts holding it on. It will take you aprox one minute to remove.
prezarevo is offline   Reply With Quote
Old 01-25-2011, 10:52 PM   #5
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
There you go.
Should be the same for your 96 if it's an EJ22E. It's the same on my dad's 95 EJ22E.
Jessekrs123 is offline   Reply With Quote
Old 01-25-2011, 10:56 PM   #6
prezarevo
Member#: 266930
2004 WRX
and here is a pic I took of an IACV
[IMG][/IMG]
Old 01-25-2011, 10:59 PM   #7
prezarevo
Member#: 266930
2004 WRX
DAMN, they werent 8MM bolts
Old 01-25-2011, 11:02 PM   #8
Jessekrs123
Member#: 236927
1984 BRAT
They're 10mm, no biggy, I'm sure the OP would find out when he couldn't get the socket to fit.
Old 01-25-2011, 11:07 PM   #9
prezarevo
Member#: 266930
2004 WRX
lol I was thinkin long and hard what size they were and I was almost certain they were 8's. oh well. I was wrong
Old 01-27-2011, 12:18 AM   #10
Chim-
Member#: 253747
Sweet thanks for the info, I will check it out
Old 02-07-2011, 11:38 AM   #11
Chim-
Member#: 253747
Update: I didn't get around to cleaning the IACV when my "Check Engine" light finally went off, which I'm glad it did. It ended up being the TPS. So now it idles fine and has no issues
Abnormal Idle Silver04WRX Service & Maintenance 6 03-09-2009 04:40 AM
Abnormally low idle on a 1995 Legacy bobko Legacy Forum 4 12-22-2006 09:12 AM
A/C compressor noise at idle... Normal? Abnormal? dcwrx2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-21-2004 01:39 AM
Abnormal Clutch noises? jacksonww Normally Aspirated Powertrain 1 04-17-2001 02:53 PM
Re-92 Abnormal wear ?? Deznuts05 Brakes, Steering & Suspension 6 02-19-2001 12:27 AM
