Old 07-09-2002, 08:02 PM   #1
TGycageL0002
Member#: 9116
2000 Legacy
Timberline Green Pearl
Default Attn Anyone Who Knows Alot About Subies
Problem... no lowering springs for the BE Sedan
Solution... have a set custom made
Problem2.. Need exact spring specs for the STOCK SPRING>>front and back...top, and bottom diameter: rate, etc etc for front and rear
If you know where i can get the specs, let me know, or if you just happen to have them off hand you are a god/godess.
please help
TGycageL0002 is offline   Reply With Quote
Old 07-09-2002, 11:05 PM   #2
snowone
Member#: 6035
05 92-X Saabaru
98 Legacy GT Wagon
Uhhhh... I dunno how much yer custome jobby might cost you, and what want/need but:
Sti LEGACY SPRINGS 2000 MY
Sti lowering springs for the 2000 MY. Lowers car 1 inch.
Sedans & Wagons
Price - $440.00 set of 4
http://www.isrperformance.com/suspension.html
snowone is offline   Reply With Quote
Old 07-10-2002, 02:22 AM   #3
TGycageL0002
Member#: 9116
2000 Legacy
it will end up costing me around 350 to 400.... I will never deal with isr again no matter what.. but i have seen those springs. I need all the specs of factory springs so that they can use the rates and everything else to essentially create a factory spring that is 1.5 inches lower. So i still need those specs
Old 07-10-2002, 08:18 AM   #4
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Check with Dale Teague, he should have no problem getting those springs.
www.teaguesauto.com
pleiades is offline   Reply With Quote
Old 07-10-2002, 09:36 AM   #5
2001LegactGT
Member#: 5089
2002 Audi A4
Denim Blue
If you make the springs with the same specs as the stock ones but 1.5 inches lower isn't the ride gonna quality gonna suck?
2001LegactGT is offline   Reply With Quote
Old 07-10-2002, 11:55 AM   #6
kbrate
Member#: 7472
2001 Legacy
Winestone Pearl
Here is what I've been able to learn after 6 mths of harassing SOA. Note the information is for the BH (Wagon) not the BE so I do not know if this really helps - I would suspect that they are similar.
There are four (4) spring rates used between the GT and L. The Front springs change depending on the Transmission used and the Rear Springs change with the Model.
All they could/would give me are "ranges" that the front and rear springs fall in.
Fronts - 18.90-023.8 N/mm (108 - 136 lbs/in)
Rears - 39.20-042.6 N/mm (224 - 243 lbs/in)
Remember there are two (2) different springs within each range.
Now if I was going to have custom springs done I would either get real friendly with a parts guy that had springs for me to measure or find a wreck and get the springs from that ( Again an Auto will have different front rates than a Manual and a GT will have different rear rates.
- The Spec's you need are :
1) OD
2) Wire Dia.
3) Free Length
4) End Condition (i.e. closed, closed & ground, open etc...)
5) Rate (anyplace that can make springs should be able to test them for rate.)
BTW STi BE/BH Legacy rates are on their website:
BH Front 3.1 kg/mm (174 lbs/in)
BH Rear 4.9 kg/mm (275 lbs/in)
BE's are a little different - you'd have to check the website for numbers.
The STi's are avaliable thru a number of dealers in addition to iSR - Vermont Sports Car, Rallispec, etc... Really anyone who deals with STi should be able to get them. What you would need to find out is the spring id - will work they with the standard US Spec Strut or if you would need the Sti Strut and different Upper Cap. (I think they were originally designed for the B4.)
Hope this helps
KCB
kbrate is offline   Reply With Quote
Old 07-10-2002, 02:37 PM   #7
TGycageL0002
Member#: 9116
2000 Legacy
thankyou so much!!! that was exactly what i needed
Old 07-10-2002, 05:36 PM   #8
AKSubie
Member#: 6214
92 Corrado SLC
01.5 S4
Cool, ok, so quick question, has anyone tried the STi spring/strut combo on a US BE yet? do the top plates match up, do they need to be modified, ala a GC8 bracket or something? Obviously, just another BE in the same boat.
Thanks,
Ben
AKSubie is offline   Reply With Quote
Old 07-18-2002, 12:44 PM   #9
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
Hi Kbrate,
Which web site are you talking about, I wouldn't mind browsing the site you are referring to.
Thanks
JoeT is offline   Reply With Quote
Old 07-18-2002, 06:45 PM   #10
Jgrahn555
Member#: 3224
Check this thread for more info
-Jason
Jgrahn555 is offline   Reply With Quote
Old 07-18-2002, 07:26 PM   #11
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
working on a (not-so) top-secret project...
someone in our midst (not me) is the proud owner of some JDM B4 Bilstien suspension. Complete set: Front / Rear, spirings, struts, top-mounts. It's being shipped from Japan within a few days.
soon enough we'll all have some answers to some of our questions.
monovich is offline   Reply With Quote
Old 07-18-2002, 10:49 PM   #12
JoeT
Member#: 3956
Titanium
Monovich,
You bum!!!
I wanted that set. Can you keep your eyes open for another set please.
Struts + hats, springs are not necessary cause I'm having a set made up by Espelir Springs of Japan.
Ugh.....
Old 07-19-2002, 03:05 AM   #13
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
he he he! did we out-bid you on the suspension?
we got the Japan connection goin' on.
if you want some struts, you know the drill. Just PM me when you find a set you like on auction and have the money ready to paypal.
Jacobhorn is the third happy guy we've hooked up, so the formula seems to work well.
you might want to wait until we see how well they work before you get 'em just in case there are fitament issues.
-Steve
Old 07-19-2002, 08:28 AM   #14
kbrate
Member#: 7472
2001 Legacy
Winestone Pearl
Originally posted by JoeT
Hi Kbrate,
Thanks
The STi Site Subaru-Sti under Sports Parts listings for both older and new gen Legacys
Who knows alot about swaps? Need tips! dg_performance Newbies & FAQs 10 12-11-2007 01:00 AM
Who knows alot about aquariums and keeping fish in general? ShortThrow Off-Topic 54 05-25-2006 07:38 PM
who knows alot about 5th gear??? rtw rally Transmission (AT/MT) & Driveline 3 01-17-2006 09:32 AM
So, who knows alot about Gen 1 Scoobs? Kostamojen 'Old School' Subaru Forum 2 04-15-2004 09:41 PM
ATTN: dan evander, and anyone who knows anything about chrome imprezive General Forum Archive 4 05-16-2000 08:50 PM
Message Board Statistics All times are GMT -4. The time now is 10:54 AM.
