Old 01-25-2011, 02:36 PM   #1
Ditch64
Member#: 169903
07 WRX Limited
CGM
Default 2011 Impreza 2.5i. Is there a reflash?
My girlfriends car just holds rpm's between shifts so bad that it's actually difficult to drive. You literally have to hold the clutch in and wait for 3-6 seconds between shifts. We took it to Subaru when she got It last year but no luck. Maybe someone here knows if there's anything now, or if i can take it to a tuner and have him adjust anything.
Thanks guys,
Robert
Ditch64 is offline   Reply With Quote
Old 01-25-2011, 02:39 PM   #2
Bootzy
Member#: 253657
My manny trans just went in my 011 impreza hatch! A coupler came a part and trashed all my gears( what subaru said)! Maybe they are ****in up
Bootzy is offline   Reply With Quote
Old 01-25-2011, 02:50 PM   #3
Airplay355
Member#: 213825
2013 BRZ
Droe an 11 Legacy that was just like that. I hated it. I don't sift with lightning speed but I don't want to hae to wait between shifts.
Try letting the clutch out slower and using the synchros more.
Airplay355 is offline   Reply With Quote
Old 01-25-2011, 03:17 PM   #4
AfflxnPB
Member#: 172036
2010 2.5i Prem
SSM
This sounds familiar. I think someone had said its an emissions thing? Don't hold me to it though, it just sounds like something I saw before on here.
AfflxnPB is offline   Reply With Quote
Old 01-25-2011, 05:00 PM   #5
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
There is no reflash, but you can get them open source tuned to re-map and improve the throttle response. This is a common complaint with the drive-by-wire sytems in the 08+ NA Imprezas.
Ogden is offline   Reply With Quote
Old 01-25-2011, 10:16 PM   #6
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
^^ If you're gonna use open source tunning to re-map, learn and understand what you're doing as you could render your car crapola if you do something wrong.
kero is offline   Reply With Quote
Old 01-25-2011, 10:57 PM   #7
Wrencher86
Member#: 250463
2010 Impreza 2.5i
The way I understand it, they hold the throttle open so the the engine doesn't go into a sudden and unplanned for lean condition. This allows them to achieve the fuel control needed to make sure that the converter works more effectively. But, yeah, it's pretty annoying. 3-6 seconds is waaaay longer than what my '10 does, though. It's more like 1-2 for me.
What did yours do before it failed? Mines been grinding going in to second first thing in the morning. Only when it's cold and ONLY on the first shift into second. It seems to be getting worse so I'm planning on calling Subaru.
Wrencher86 is offline   Reply With Quote
Old 01-25-2011, 11:02 PM   #8
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
Oh, I'd pay to have it done by a professional.
Old 01-30-2011, 02:42 PM   #9
kachofool
Member#: 212698
2008 Impreza Stock
Hey
The 3-6s wait sounds absurd. I get nothing like that on my 08 2.5i... I notice a slight rise in RPM when I pop the clutch, but I thought it was to help ease between shifts. Even if the car is holding rpm while you shift, isn't it responsive to throttle when you're back in gear?
kf
kachofool is offline   Reply With Quote
Need sway bars for n/a 2011 Impreza 2.5i papang15 Newbies & FAQs 24 01-02-2013 10:58 AM
FS/FT : NC: 2007 Impreza 2.5i [email protected] Private Vehicle 'For Sale' Classifieds 23 02-27-2011 07:07 PM
Weight of Steel Wheels on 2008-2011 Impreza 2.5i Thio Newbies & FAQs 5 01-20-2011 07:44 PM
New owner of 2011 Impreza 2.5i 5-door igorkv Newbies & FAQs 8 11-15-2010 02:42 PM
('11-'14) 2011 Impreza 2.5i Rear Cupholders Halforc Impreza Forum 6 08-28-2010 02:41 PM
