#1 |
Member#: 13733
Vehicle:05' Saabaru Black YO! |
Just wondering...how much hp. does a stock 01' 2.5RS put out at the flywheel?
#2 |
Member#: 11585
Vehicle:02 2.5RS i am also not a p**** |
165hp
166ftlbs |
#3 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
hi, im your owners manual, please read me
![]() hi, im the search button, use me ![]() ![]() but yes 165hp/166lb ft. Jay |
#4 |
Member#: 1165
BAIC
Vehicle:1990 dcrawford died for your sins |
To be exact...
165 hp @ 5600 RPM 166 lb ft @ 4000 RPM NC |
#5 |
Member#: 5796
Vehicle:2007 11 F150, 2004 WRX-dont get married! |
actually you are both wrong, the 2000 and 2001 actually make more, thats the readings from the 99 motor, figure you got 5-7 more ponies than that stock, subaru just never dynoed, and used the same #'s
-mikey |
#6 | |
Friendly Neighbourhood
Moderator Member#: 269
VIC
Vehicle:2005 ABP LGT LTD BP6 00 Impreza RS GM6 RIP |
![]() Then again, there are manufactures like Nissan who (ahem) made a very optimistic guestimate on their HP and torque numbers for the Spec-V. Then they had to "tone it down" after they actually dynoed it. ![]() LaterZ! Darren!! |
#7 | |
Member#: 1165
BAIC
NC |
#8 |
Member#: 5796
i forget my source, sorry guys, but the but dyno will back it up!
#9 |
Member#: 3269
SCIC
Vehicle:2001 2.5RS Sedan STM RSTi |
I have heard the same thing. Subaru dynoed the phase I engine, but never bothered to dyno the phase II design. Would be nice if someone could confirm this and give us numbers.
-Chav |
#10 |
Member#: 112
NWIC
Vehicle:2011 Jetta TDI Black |
every motor is different and will give you different power output within a few hp, but the design has been the same for the past 3 years, and should be very close...power output is the same as the phase 1 1998 dohc design, but switching to the sohc design flattened/widened the torque curve, and put more usable torque down low...i've seen dyno graphs for both, just don't have/know where to get them anymore....at our local events i can creep up on 1998 rs's..but the 2000/1's never pull away from me, 5-7hp due to a change from a MAF to a MAP? hard to believe.....l8
#11 | |
Member#: 821
It also says that the 2001 RS has 9.7:1 compressin ratio. I always thought that the compression ratio was 10:1 and the peak HP was 169.THis gives me even less respect for the media...... Greg Last edited by Section 8; 07-09-2002 at 11:54 PM. |
#12 | |
Member#: 821
5-7 HP on an auto-x course is nothing. To many variables involved generating noise to try and compare accuratly. cheeRS, Greg |
#13 | |
Member#: 3717
Vehicle:MKV GTI - tite! bikes with pedals |
#14 |
Member#: 112
NWIC
1999 = MAF SOHC
2000-1 = MAP SOHC both are exact same engine |
#15 |
Member#: 821
Some 99's slipped out early in the build year with DOHC...... but they are by far not the norm.....
cheeRS, Greg |
#16 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
IIRC the 99's had 165hp/160ft lb torque...ask revision, he knows all the numbers
Jeremy |
#17 | |
Member#: 5796
99 compression 9.7.1 00-02 10.0.1 |
#18 |
Member#: 232
Vehicle:99 RS-T RIP 02 Forster-S |
MY 98 Phase 1 DOHC
MY 99-01 Phase 2 SOHC Yes, MY 00-01 had 10.0:1 compression Yes, MY 99 had 9.7:1 compression Yes, MY 99 had MAF sensor Yes, MY 00-01 had a MAP sensor The heads are the same for 99-01, the blocks are listed under different part numbers, the only change is probably a few mm deck height. The MAF sensor, although fragile, reads the incoming air mass and are more accurate for A/F calculations. The MY99's are dramatically different from the MY98's, I don't buy it that Subaru could "accidentally" put the wrong engine in the car. The ECUs are very different, the ignition system is different, the MAF sensor is different. Too many parts would have to "accidentally" be switched. As for the few hp difference, woohoo! You'll get more change than that based on weather conditions . Each car is different, factory hp numbers are an average. |
#19 | |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT QuickSilver Metallic |
And, if you look at the specs for the '98 2.5RS and '97-99 2.5GT (all of which used the DOHC Phase I engine) you will find that the ratings are different than those for the '99+ 2.5RS and '00+ Legacy/Outback. The Phase Is were rated at 165hp @ 5600rpm and only 162ft-lb @ 4000rpm. Not a huge difference, but the peak numbers don't tell the full story. The SOHC cars have a much better torque curve, and part throttle response is also much improved. I think it is worth noting that Subaru's torque numbers seem to be under-rated. I know that all of the dyno results I've seen during dyno days at Adrenalin Motorsport in Massachusetts have shown the 2.5L cars (both DOHC and SOHC) to have about 10-15 more ft-lbs of torque than they do HP. Check out this graph that I compiled from one of my stock runs compared to a stock SOHC 2.5RS run: ![]() Both cars peaked around 105hp, so based on the factory ratings one would expect the torque peaks to be in the 105ft-lb range. In actuality the torque peak for my DOHC 2.5GT was around 112ft-lb, and the SOHC 2.5RS peaked around 122ft-lb (I have the actual numbers at home, but reading off the graph should be good enough for now). I've seen the same type of results for a number of stock or lightly modified (intake and exhaust) RSs. Now, it could just be the dyno that Adrenalin uses, but I vaguely recall seeing Dynojet graphs with the same sort of HP/Tq mismatch. Interesting.... Pat Olsen '97 Legacy 2.5GT sedan |
#20 |
Member#: 16261
Vehicle:2000 Impreza 2.5RS Blue Ridge Pearl |
Im learning a bit, so please correct me if im wrong, but... isn't is safe to say that if someone is concerned with the HP and Tq of an engine, they are really concerned with acceleration, or more specifically, quicker straight line times? If this is the case, then why are sooo many people concerned with PEAK HP and Tq, rather than how broad their ranges are? Ill tell ya one thing, I did not buy headers for my impreza because I wanted to maximize my vehicles peak HP and Tq, I bought them because I know that the HP and Tq curves would broaden greatly, especially in mid to high ranges. As was expected, my vehicle accelerates much faster now, though I doubt that my peak HP and Tq have gone up any. Its my belief that peak values are mearly an advertisement tool for automotive companies to push their product. I feel that there should be some means of quantifing how "peaky" an engine's power is, and that should be quoted as well
#21 | ||
Member#: 2697
Vehicle:2000 Celica GT-S Spectra Blue |
phucvtec, I believe you are correct . . . partially . . . it all depends on what you want out of the engine.
For a daily-driven street car, you'd want a flatter, broader torque curve. This basically means that you'll have useable power throughout the rev range (or most of it anyway). Honda's are notoriously known for being "gutless" at lower rpms. Why? Because they are peaky engines. Compare that to a VR6, per se, and you'll see crazy variances in powerbands, or should I say torquebands. However, this peakiness shines at the track, where for the large majority of the course, the driver will keep the engine within the optimal powerband. Quote:
![]() Quote:
Now someone please correct me, if I'm wrong ![]() Jason |
#22 | |
Member#: 821
They simply put DOHC heads on the blocks and used everything else for the 99 year.There are people who have that configuration from the factory in their cars, it has been refered to as the "silver bullet", and this is not any new information. For an example there is also a difference in rear calipers, if you order pads for a 99, they could fit or they might not, depending on what the build date was, 2 different part numbers for the same part in the same year. Same situation, different part. Porsche CONSTANTLY changes spec, and it must be a pain in the butt getting parts for the car unless you know exactly what you are doing. (of course you probably wouln't need to worry about that, if you own a newer Porsche, odds are you don't do the maintenance on it anyway). cheeRS, Greg |
#23 |
Member#: 3266
NESIC
Vehicle:2006 Jetta 2.0T 6MT 2009 Jamis Aurora Elite |
And all this thread just from a small failure to use the search button, read a manual, or check out any number of websites that have the answer to the original question..
![]() Interesting discussion, tho.. I even learned something with Pat's dyno post! Imagine that! .. I had no idea the torque number was so much higher than the hp.. That explains why my TS pulls like a frieght train from ~3250rpm on up. Even stronger after cat-back exhaust/ghetto CAI.lb www.trancelab.com |
#24 | |
Member#: 821
. Thats why your car pulls the hardest in 1st gear and has the least pull in 5th gear (A bad example due to air restance, but your acceleration is less and less as you go through the gears).cheeRS, Greg Last edited by Section 8; 07-10-2002 at 03:10 PM. |
#25 | |
Member#: 120
AKIC
![]() BTW, what the hell's up with Subaru not having a 1:1 gear to dyno with??!! ![]() Pat Last edited by Patrick Olsen; 07-10-2002 at 05:37 PM. |
| Thread Tools | |
| Display Modes | |
| FS: Stock 01RS 16" Alloys | RS_NW | North West Impreza Club Forum -- NWIC | 7 | 06-16-2005 12:44 AM |
| what should i be quoting people on stock STi HP and TQ | TRM | Factory 2.5L Turbo Powertrain | 4 | 12-22-2003 01:26 PM |
| FREE stock 01RS struts/springs/topmounts...OC pickup only | PacificMartin | Southern California Impreza Club Forum -- SCIC | 1 | 07-19-2002 08:56 PM |
| Stock Impreza HP numbers on AWD Dyno? | Tangmere | Rocky Mountains Impreza Club Forum -- RMIC | 1 | 02-09-2001 10:26 PM |
| Stock 218 HP to 250? | Jeff | General Forum Archive | 1 | 11-22-2000 05:33 PM |
