Welcome to the North American Subaru Impreza Owners Club Thursday March 5, 2015
Old 07-09-2002, 10:20 PM   #1
skid00skid00
Member#: 18531
2000 Outback LTD
Default Spark Plug mod: clipping the electrode
Well, hell, this idea of mine has been ignored everywhere
else I posted it, so I'll give you people a chance, too!
I've been using this mod in all my engines since 1975.
I came up with it when trying to eliminate a bad missfire
in a heavily modified Yamaha RD 350 two-stroke bike.
The idea is to provide a sharp-edged conductor (which
helps the spark to jump the gap, along with un-masking
the spark, so the flame-front can grow outwards more
quickly.
I simply cut the side electrode with a side-cutter, so
the resulting tip is even with the -edge- of the center
electrode. I file off any burrs, then gap around .040.
I've never had a problem with the gap being too large
(I've gone as large as .050) and plug life is "adequate".
(I've got 50,000 miles on the plugs in my subie, and
won't be replacing them any time soon.) I've not had
ANY misfire with the large gap...
In other applications, I've noticed much faster starting
in very cold weather, with much better cold idle, much
better throttle response, and seemingly better mileage.
I've highlighted the electrode in these pics, since it
didn't show up well otherwise. I hope you get the
picture...
http://netnet.net/~llueck/P7097335c.jpg
http://netnet.net/~llueck/P7097330c.jpg
skid00skid00 is offline   Reply With Quote
Old 07-09-2002, 11:03 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
What did you use to cut the electrode? Just a normal cutters?
Legacy777 is offline   Reply With Quote
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 692 12-21-2014 03:42 AM
Spark Plug chage on the 06' Peaty Tribeca Forum 0 03-06-2010 06:30 PM
NEED: Plug/Clip that plugs into WRX spark plug coil BeBop86 Private 'Wanted' Classifieds 16 07-16-2008 04:05 AM
Spark Plugs (Split Electrode and Pressure Relief) - Burn Rate/Timing Effects? Trunk_Monkey Engine Management & Tuning 3 02-24-2006 11:17 AM
Are these multi-electrode spark plugs really worth it? Patrick Olsen at work Technical Forum Archive 10 05-29-2000 11:50 AM
