Old 07-09-2002, 10:24 PM   #1
jacobhorn
Member#: 5122
1998 Legacy GT LTD
'02 HD Softail Deuce
Arrow Brake Install
jacobhorn is offline   Reply With Quote
Old 07-09-2002, 10:28 PM   #2
samowrx
Member#: 8403
brake pads and rotors are easy to change because they don't involve bleeding the brakes. that's the only thing holding me back from changing the lines myself.
samowrx is offline   Reply With Quote
Old 07-09-2002, 11:15 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
bleeding isn't too hard. Get yourself a friend, bottle of brake fluid, little hose, and plastic bottle, and bleed
If you would like specific instructions let me know.
Josh
edit: Oh BTW Jacob, I'm goin to be leaving to come up to Seattle on July 26th. Will prob be around till Aug 6th-7th. I've got a laundry list of stuff I'm hoping to be able to do to my car while I'm up there. Damn I miss having a garage
Let me know if you or any of the other legacy folk would want to meet up some time. Hopefully I can get most my mods on/done early in the first week.
Legacy777 is offline   Reply With Quote
Old 07-09-2002, 11:20 PM   #4
samowrx
Member#: 8403
well i have an idea on how to do it, i'm just affraid that i'd mess up something. brakes are not something i want to mess with unless i had someone who knew what they were doing helping.
Old 07-09-2002, 11:54 PM   #5
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
It is a very easy job. I don't have the SS lines but I did bleed the brakes a couple of months ago. I bought a Motive power bleeder so I could bleed by myself. It is a wonderful tool. I changed the fluid in mine and my wife's car in a total of 1 hour. Remember to start at the RR than do the LF, than do LR and last but not least RF. Subaru has two seperate diagonal circuits. So you need to bleed one, than the other. I would recommend getting a power bleeder or a vacuum bleeder. Makes the job almost fun.
HIHO is offline   Reply With Quote
Old 07-09-2002, 11:57 PM   #6
snowone
Member#: 6035
05 92-X Saabaru
87 VW Westfalia
I paid to have mine done... mainly 'cause I was in lazy mode and didn't feel like dickin' around w/ it. I've changed pads and rotors in my older Subarus... isn't difficult. Like everyone else says... it helps if you've got an extra hand to bleed the brakes. Sometimes the stainless lines are a bit tricky to route properly... if you've got tools, place to work, and time... I'd say hook it up yourself.
Let me know if you decide to DIY... I'll give you a hand if available.
snowone is offline   Reply With Quote
Old 07-10-2002, 02:14 AM   #7
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Default Start to finish - 2 hours
To pull the rotors (to get them dressed) and change the pads on a Subaru is walk in the park as they say. Easy. That includes putting it on four jack stands for ease of access. Add a little more time if you have to jack each wheel up individually. Go to Scooby Mods to check out the how to stuff.
General rule of thumb - replace two sets of front pads to one set of back pads (there are exceptions - mostly mountain running and hard running track days). I pull the wheels and check the brakes every 5K miles when I rotate the tires. The two to one ratio is reasonably accurate. One thing is for sure - get the 8mm x 2", "Magic Bolt" to use on the rotors. If your rotor has been on the car for any length of time that bolt will make the difference between a frustrating, schnitzed up event and a quick, routine, pull the rotor event.
Cracking the lines to change out a caliper or to put on SS lines, is a bit more time but as HIHO mentioned, a power bleeder is worth it's weight in gold when you want to get the brakes bled and not put stress on the relationship with your SO. The power bleeder will pay for itself in time alone the first time you use it.
Br, Dale
Subietonic is offline   Reply With Quote
Old 07-10-2002, 02:03 PM   #8
jacobhorn
Member#: 5122
1998 Legacy GT LTD
Thumbs up
WOW! Thanks for the great feedback guys!
Jacob
Old 07-10-2002, 02:21 PM   #9
froggert
Member#: 768
OB, volt, 911,
ram 1500, 1098s, m620
i didn't have "magic bolts " so used a 3 lb. rubber hammer to break the rotors loose.
froggert is offline   Reply With Quote
Old 07-11-2002, 12:21 AM   #10
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
You da man Froggert. Like my dad always said, if you can't get it off with a little WD-40, (which I don't recommend in this case because you could end up soaking your e-brake shoes) get a bigger hammer.
Br, Dale
Old 07-11-2002, 02:59 AM   #11
VOLTIS5
Member#: 2353
98' LegOver GT
dark whiteish pearly red
jacob- i've got step by step instrustions and pics to go along with it if ya want. PM me if ur interested
VOLTIS5 is offline   Reply With Quote
Old 07-12-2002, 01:21 AM   #12
GTkrockett
Member#: 8678
Silverish 2.5GT
PM'd ya!
GTkrockett is offline   Reply With Quote
Old 07-12-2002, 03:06 AM   #13
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Voltis,
Just a suggestion but it would be cool if you'd post your brake repair directions/pics in the FAQ and/or on the Scoobymoods.com site under Legacy.
Br, Dale
Old 07-12-2002, 03:15 AM   #14
jacobhorn
Member#: 5122
1998 Legacy GT LTD
Thumbs up
Voltis:
PM'ed you!
JH
Old 07-13-2002, 02:11 AM   #15
McCloyd
Member#: 21005
1990 Legacy LS
I just recently replaced front rotors on my 90 Legacy and the drivers side rotor just fell off but the passenger side was totally fused in place. After using rust buster (soak an hour) and whacking at it, I got a 2 jaw 6" gear puller and put some tension on the rotor. It came off after 5 whacks with the gear puller.
I wouldn't recommend this if you are going to turn and reuse the rotors (I replaced mine anyway.)
McCloyd is offline   Reply With Quote
Old 07-13-2002, 10:08 AM   #16
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Some install info here. It's for my RS but should be very similar:
http://www.scoobymods.com/forums/sho...=&threadid=349
Magic bolts:
PS if you have anything that you want posted on the Scoobymods site send the stuff to me and I'll see it gets there
Peaty
Peaty is offline   Reply With Quote
brakes vibrate after new brake install brandonwrx06 Brakes, Steering & Suspension 6 04-07-2009 05:56 AM
Brake Installs From $215 Installed Gruppe-S SCIC Vendor Classifieds 11 08-12-2008 03:53 PM
Watch/Hang out/Help with Brake Install Saturday? mav1c Mid Atlantic Impreza Club -- MAIC 14 03-24-2001 08:20 PM
Anyone feel like helping with brake install? mav1c Mid Atlantic Impreza Club -- MAIC 15 11-30-2000 07:08 AM
Suspension and brakes install? bsquare North West Impreza Club Forum -- NWIC 2 08-09-2000 03:28 AM
