Old 01-26-2011, 04:04 PM   #1
atvtrailrider
Member#: 271521
Default Is 90 Legacy the same in AWD and FWD?
I have a 90 legacy AWD with an automatic. The tranny is out. Can I swap in a 2wd transmission? I have found one much cheaper than the AWD and had one person told me I just move over the AWD stuff and it is an easy swap.
Thanks Much
atvtrailrider is offline   Reply With Quote
Old 01-26-2011, 04:45 PM   #2
soobrdad02
Member#: 226084
1991 Legacy wagon
Desert Sand Mica
I can't answer your question, but I'm sure that someone over at bbs.legacycentral.org could! It's a great resource for those first gen Legacy's!
soobrdad02 is offline   Reply With Quote
Old 01-26-2011, 09:16 PM   #3
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
You can, but you'll have to remove the rear differential or swap it for one of another ratio, as FWD and AWD ratios are frequently different.
DLC is offline   Reply With Quote
Old 01-27-2011, 02:07 PM   #4
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I would not say it's an easy swap. You've got to open up the trans and swap over the pinion shaft & driven shaft as well as all of the AWD stuff in the transmission. If you were going to go to that length to do all that stuff, I'd recommend just rebuilding your existing AWD trans.
Personally, I'd recommend to keep looking for an AWD trans.
Legacy777 is offline   Reply With Quote
OEM boost gauge question: Steering columns the same in 03 and 05 WRX's??? YinUCSD Interior & Exterior Modification 2 02-10-2005 09:01 PM
Is the 2.5 Turbo the same in the STI and Forrester? tchprivat Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 09-09-2004 07:28 PM
OK....so who is going to the meet in MD, and who is going to the meet in PENN? AustinSTi Mid Atlantic Impreza Club -- MAIC 4 06-28-2002 02:28 AM
driveshafts in version 3-6 WRXs are the same as AWD Ls? Superu Transmission (AT/MT) & Driveline 0 03-31-2002 05:37 AM
Heres a stupid question: Is 4x4 the same as AWD Andrew Newbies & FAQs 15 02-04-2001 04:53 PM
