Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-29-2007, 10:38 PM   #1
wrxdragger
Member#: 73052
2002 WRX Hybrid
CandyBluEcutek,GT30,?whp
Default Utec able to remove cel due to tgv deletes??
I will be doing tgv deletes either with leaving the rod or with out if the car would run good. Does it have to be tuned or change anything in the map? Also installing modding sti pink injectors to 650-750cc. Doing them at www.witchhunter.com.
wrxdragger is offline   Reply With Quote
Old 03-07-2013, 02:03 PM   #2
emsmap
Member#: 159334
02 PSM WRX
UTEC,PPG,FMIC, Big turbo
Alrite instead of making a new thread, Ill add to this one.
I am running a UTEC and just did my TGV delete. I gutted everything and sealed up the hole. I am wondering what I can do when I start the car when the CEL's show up? I will be getting it tuned, however not for a month or 2 since Jermaine at TurboXS is a busy man! LOL. I have researched this problem through different forums and it comes down to I will be getting 12 CEL's and my car will go into limp mode. My question is, will it hurt my motor to drive around in limp mode? I have 1000cc injectors, PTE 5031 turbo, EWG, catless, FMIC etc... So not sure if going into limp mode will do any damage.
Thanks in advance for the advice
emsmap is offline   Reply With Quote
Old 03-11-2013, 03:43 PM   #3
Rodwrx23
Member#: 170948
The only way to disable the specific TGV delete related codes (iirc its 1080-1092) is through romraider/ecuflash. All you can really do with the UTEC is disable the CEL light from illuminating on your dash which I don't recommend unless you're going to scan your car daily. I wouldn't drive the car in limp mode unless your going to baby it. You won't be able to run full boost anyway assuming you're controlling it through the ecu/Utec anyway but they run pig rich at WOT and I don't recommend that.
Rodwrx23 is offline   Reply With Quote
utec, 02 wrx ecu and top feed tgv deletes skate enjoi Engine/Power/Exhaust 16 11-07-2008 03:55 PM
First CEL due to 3/16 Mod sonicwrx03 Factory 2.0L Turbo Powertrain 13 01-31-2005 08:21 PM
CEL due to running lean due to cat back or removed silencer?? wrx_snobordr Factory 2.0L Turbo Powertrain 14 12-03-2004 11:22 PM
CEL due to system? NateDogg Car Audio, Video & Security 0 09-08-2002 04:26 AM
CEL due to engine sensor falling off = very hot turbo Snowphun Factory 2.0L Turbo Powertrain 5 06-21-2002 05:57 PM
Message Board Statistics All times are GMT -4. The time now is 02:35 PM.
