Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 01-26-2011, 11:26 AM   #1
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Default 190 HP on Monday!
165 HP at -28C, 60% humidity, 50 m altitude and 1020 hpa air pressure...... 15.6% increase in power = 190hp
http://wahiduddin.net/calc/calc_hp.htm
Bluefoton is offline   Reply With Quote
Old 01-26-2011, 11:35 AM   #2
JoshP
Member#: 94350
JoshP is offline   Reply With Quote
Old 01-26-2011, 12:33 PM   #3
GEE-OTTO
Member#: 201277
2009 Legacy GT
Wtf?????
GEE-OTTO is offline   Reply With Quote
Old 01-26-2011, 12:47 PM   #4
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Oh, I get it. OP is pretending HP calculators are accurate on outlier inputs like -28 degrees C. If they were, an NA Subaru could make 190 bhp. At which point axles and/or wheels would shatter from the cold brittle.
BAN SUVS is offline   Reply With Quote
Old 01-26-2011, 12:53 PM   #5
NH8991
Member#: 197937
2016 Golf R
Under the radar silver
So that's why i was bouncing off the rev limiter in top gear on Monday morning, early on it was actually -28 with a -38 wind chill here in Montreal
NH8991 is offline   Reply With Quote
Old 01-26-2011, 01:03 PM   #6
JoshP
Member#: 94350
-28c isnt that cold? nothing would shatter LOL
Old 01-26-2011, 01:21 PM   #7
Bluefoton
Member#: 141373
2008 2.5i-hatch -
It was meant as an utterly silly post, but why wouldn't it be accurate? Colder = more dense = more fuel = more power. Feed -30C air into an intake of an engine on a dyno and the resulting power/tq curves should rise by 15%..
Old 01-26-2011, 01:48 PM   #8
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Hush.
Old 01-26-2011, 06:01 PM   #9
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
lol. The simple formula used to estimate changes in HP by temp, humidity, etc are simple because they are taking a lot of factors out assuming that the user will be within a certain envelope.
To put it short, if things are extreme the formulas don't apply anymore.
Rudgers73 is offline   Reply With Quote
Old 01-26-2011, 08:20 PM   #10
Bluefoton
Member#: 141373
2008 2.5i-hatch -
^ sure, but i'd still be curious to know the accuracy range. The only factor unnacounted for is the increased friction loss, which would occur mainly in the drivetrain - bearings, differential, etc. THe engine being at normal operating temperature, the rest is in principle unaffected...
Old 01-26-2011, 08:37 PM   #11
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Well, your engine would have to have the overhead on fuel delivery and air metering to actually deliver the power, plus your cams and manifolds would have to work at the new flow rates. None of which would actually be true.
Old 01-26-2011, 09:49 PM   #12
renyo
Member#: 93577
98 Impreza
Why would the manifold and cams care about the mass flow rate? The volumetric flow rate should be the same. Although, the wave tuning might be different if the stiffness of the air changes.
renyo is offline   Reply With Quote
Old 01-26-2011, 10:04 PM   #13
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
If that were true, all manifolds and cams would make the same power in the same RPM ranges right?
Old 01-26-2011, 10:15 PM   #14
renyo
Member#: 93577
98 Impreza
Two manifolds and two sets of cams that are made the same should produce roughly the same VE curves, yes.
Old 01-26-2011, 11:18 PM   #15
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
The mass flow rate is more important than the volumetric flow rate because we are dealing with difference in air density. The volume is fixed. More dense air has more molecules of oxygen meaning it has a higher mass flow rate but there are several things that still need consideration.
Again, this is too simple of an approach to a very dynamic system...
let's just look at the air for example:
1. How much is the air heating up from conduction before it gets into the engine? Remember, the higher the difference in temperature, the higher the rate of heat conduction...
2. How does the denser air flow through the system compared to less dense air assuming it is constantly expanding from the rising temperature?
(and remember the flow is almost completely turbulent which can't even be predicted without modeling or huge assumptions)
3. As your engine heats up, will the air temperature entering the engine taper up to an equilibrium point from the thermal mass of everything around it? How much will this established "steady state" temperature really differ from standard inlet air temps on days when it isn't balls cold?
4. Etc
Old 01-26-2011, 11:26 PM   #16
renyo
Member#: 93577
98 Impreza
3. As your engine heats up, will the air entering the engine taper to an equilibrium in temperature from the thermal mass of everything around it? How much will this "steady state" temperature really differ from standard inlet air temps on days when it isn't balls cold?
No, I agree, he won't have 190 horsepower. I'm saying the manifold and cams would work just as good as they always did.
Old 01-26-2011, 11:29 PM   #17
subezero
Member#: 207614
2008 WRX Hatch VF52d
SSM
All I know is my butt dyno absolutely see's difference between a -30C day and a 30C day. Feels like I'm driving a whole different car at that low temperature! I'll have to run an Airboy on it some day as I'm curious now.
subezero is offline   Reply With Quote
Old 01-26-2011, 11:44 PM   #18
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
well -30 to 30 is a pretty big difference, so yeah, of course there is an increase. All I'm saying is that you aren't gaining 30 horses. If there were giant gains to be made from really cold intake air people would be spending money on refrigerated intercoolers and skipping the forced induction
Old 01-27-2011, 03:40 AM   #19
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
People do spend money on refrigerated intercoolers. It's just less effective than FI because the air isn't in contact with the cold thing for that long.
And air temps that low would cause the manifold and cams to "respond differently". The speed of sound would change, among other things affecting resonant tuning behaviors.
Old 01-27-2011, 11:24 AM   #20
Bluefoton
Member#: 141373
2008 2.5i-hatch -
This would call for a dyno test.. especially that there is only one variable involved and no changes to the engine itself... I didn't think about the change in speed of sound. Combustion is probably affected as well. Nevertheless, if the predicted HP gain based only on air density is 15%, I'd still assume I gained at least 10%.
To be anally correct though, my IATs never went down to -30C. With the engine and engine bay warmed up (30 min + of freeway driving), at WOT my IATs are about 15C (30F) higher than ambient air temperature - which means that I never went below -15C (5F).
Maybe the 190 HP NA EJ20? Scoobie Steve Subaru Conversions 13 04-09-2010 09:52 PM
Sighting: Toyota Starlet on Monday or Tues on 60E codemunky Southern California Impreza Club Forum -- SCIC 2 05-11-2003 01:40 AM
New Accord Wagon, 190 hp. SubaruRules Off-Topic 24 10-15-2002 07:31 AM
2.5RS spotted on Monday on Holcomb Bridge Blindeye_03 South East Region Forum 1 03-20-2002 09:34 PM
Sighting: On Rt. 15 on Monday at 7.30 am AustinSTi Mid Atlantic Impreza Club -- MAIC 5 10-04-2001 02:34 PM
