Old 07-10-2002, 01:15 AM   #1
SeanLiew
Member#: 12367
Default Accident in Outback
My dad was driving the car at a low-rate of speed and a Dodge Ram decides to gun it in reverse and back into the front fender.
The bug guard flew off, front left rim is damaged and tire blew. Front fender, bumper, and hood must all be replaced.
Driver's door is hard to open, I am not sure if it is due to the fender being messed up, or the door.
Anyways, what else could possibly be damaged? I looked under the car, and all the plastic guards (I think they are called skid plate, sorry I don't know much about the mechanicals of the car) were still intact on the car.
The car is impounded right now. When it is towed to a shop ( I am thinking our Subaru dealer), what in particular should I ask them to really check?
Thank you
SeanLiew is offline   Reply With Quote
Old 07-10-2002, 01:48 AM   #2
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Depending on how hard you were hit (sounds like either an oblique shot from the front corner or a straight shot into the fender), I'd recommend checking the front wheel hubs, the axles and seals, the CV joint (including the boot), the brake system (including the ABS mount, the rotor, and all front brake connections), the steering rack and tie rod ends, the front strut (including the strut tower, spring perches and top hats), and the front sway bar mounts and connections. I've heard of steering racks actually shearing off their mounts when hit from the side.
You many need to check your engine mounts and your exhaust connections too.
Sounds like your fender has pushed back or deformed into the front door "swing" space - that small area just behind the front fender where your door swings open and closed.
Good luck and let us know how it goes.
Br, Dale
Subietonic is offline   Reply With Quote
Old 07-10-2002, 08:17 AM   #3
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
Actually, my GT was hit in the same area by a drunk driver last month. The damages might be a little different on yours but here's the rundown on the parts needed for my car (plus the associated connectors, attachements, etc):
front bumper cover, front grille, ALL DRIVERSSIDE: foglight, fender, wheel, tire, strut, control arm, upper tie bar, steering column, bearing, sway bar mount, door, side mirror, sideskirt, and a slight straightening of the frame
Plus painting . . .
All in all, about $5000 worth of damages . . .
But I must say it looks better than before the accident.
Jason
2.5GT is offline   Reply With Quote
What to do in accident in WA state RedHotLama North West Impreza Club Forum -- NWIC 17 08-27-2014 04:02 PM
Just saw WRB WRX in accident in Somerville?! 2002WRXSTi Tri-State Area Forum 2 12-17-2005 11:44 AM
Manute Bol in bad car accident in Colchester CT! BrysImpreza New England Impreza Club Forum -- NESIC 11 07-02-2004 02:06 PM
14 killed in ferry accident in NY!! xfactor834 Off-Topic 8 10-15-2003 08:03 PM
Innocent man killed in street racing accident in MD elgorey Mid Atlantic Impreza Club -- MAIC 45 08-14-2003 10:26 AM
