Old 01-27-2011, 11:06 PM   #1
alejo
Member#: 170081
2004 2.5RS
blue
Default 02 sensor fitment?
I just received a new O2 sensor I bought from amazon. I used the "make sure it fits" feature, and it said it would. Now, this sensor only has 3 lines, two white a one black. I beleive mine has 4!! havenīt checked due to lack of time. Will it fit? It`s a 99 OBS. thanx a lot, cheers
alejo is offline   Reply With Quote
Old 01-29-2011, 10:29 AM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
as far as i know, the front is a 5 wire, rear is 4.
Old 01-29-2011, 10:57 AM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
I've not had much luck with aftermarket sensors.
I gave up and now only buy oem
Sounds like you've got the wrong sensor.
I would not install it as if it doesn't work, they likely will not take it back.
Old 01-29-2011, 11:16 AM   #4
Wrencher86
Member#: 250463
2010 Impreza 2.5i
There is the possibility that they were just lazy in designing/manufacturing the sensor and instead of running a ground wire they just ground the heater circuit through the pipe. That's kind of a big if though. And even if it still works with the three wires do you really want to trust a sensor from a company that's too lazy to put in the proper number of wires?
Wrencher86 is offline   Reply With Quote
Old 01-29-2011, 06:41 PM   #5
alejo
Member#: 170081
2004 2.5RS
blue
what color is the ground that comes from the harness to the sensor?
Old 01-30-2011, 01:29 AM   #6
Wrencher86
Member#: 250463
2010 Impreza 2.5i
No idea.
Old 01-31-2011, 12:15 PM   #7
alejo
Member#: 170081
2004 2.5RS
blue
anyone?
Old 01-31-2011, 04:02 PM   #8
Wrencher86
Member#: 250463
2010 Impreza 2.5i
An auto parts store should be able to print you a wiring diagram. (Act like you want to buy something first)
Wanted: MAF mass air sensor. 02 sensors. EGT sensor timing cover. tscott915 Private 'Wanted' Classifieds 10 10-07-2009 01:26 AM
Front 02 Sensor,Rear 02 Sensor,MAF Sensor,Blox Shift Knob,SPT Oil Cap, bunch of stuff TopEndPull Engine/Power/Exhaust 11 08-14-2009 05:48 PM
WTB: 02-07 Maf Sensor, 04-07 Sti or 06-07 WRX 02 Sensor. TopEndPull TXIC Private Classifieds 1 07-26-2008 09:54 AM
Oem 02 front sensor Or Wideband 02 sensor Fast_Wrx62 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-06-2006 09:58 AM
Defi EGT sensor fitment problem kyo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-13-2005 11:02 AM
