Old 01-28-2011, 03:30 AM   #1
Dknits782
Member#: 153302
Default what rpm do u shift at?
Hey just curious to see what rpm people are shifting at while dd, and what rpm they drive around at? I shift at just over 3k and Cruz at around 2.5k just wanted to see if this is normal. Srry if this has been asked I'm at work on my phone kinda hard to search well.
Dknits782 is offline   Reply With Quote
Old 01-28-2011, 05:13 AM   #2
PoorWRX
Member#: 82260
2002 Impreza WRX
yeah, kinda normal... about 3k under 4k take off.. always shift about 3k very gentle when driving normal, but it just feel dont really check the speedo all the time
PoorWRX is offline   Reply With Quote
Old 01-28-2011, 05:31 AM   #3
Drifter2be
Member#: 265122
2004 WRX
Java Black Pearl
During DD I keep my foot out of it to never go too far above 10inHG on the vacuum side of the gauge, rev to no higher than 3000RPM and try to keep myself in the 1800-2300 range while cruising, this of course is unless I need to get the hell outta the way really quickly. I'm sure it annoys the people behind me to see a WRX with exhaust on it putting up to speed as slow as I do, while I'm being passed by old ladies in Toyota Prius'...Priuses???...Prii??????
Anyways, yeah, slow, but I don't seem to notice much of a difference between driving like that and getting after it a bit up to speed, other than maybe 1-2mpg strictly city driving.
Drifter2be is offline   Reply With Quote
Old 01-28-2011, 08:37 AM   #4
ride4life32
Member#: 121017
1993 Impreza L
Amethyst (factory)
I normally shift around 3k rpm in the morning during warm up, but normall shift around 3.5k-4k driving normal, keep in mind I have an v8 ej207 motor so the powerband is a little different. The v7 motor that I had under 3 grand the car was hopeless
ride4life32 is offline   Reply With Quote
Old 01-28-2011, 08:45 AM   #5
xreaction122
Member#: 264419
2004 RSTi
Plasma Blue Pearl
I normally keep it below 2500 until my oil temps are OP temp. then i shift at around 2800~3000 for DD... On ramps are another story though
xreaction122 is offline   Reply With Quote
Old 01-28-2011, 09:25 AM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Originally Posted by Dknits782 View Post
Cruz at around 2.5k
Penelope Cruz? What does she have to do with this?
Old 01-28-2011, 09:35 AM   #7
DiscoBerry
Member#: 264156
2006 2.5i Wagon
Grey
I normally shift at 3k unless the engines cold or i feel cheap then i shift at about 2200
DiscoBerry is offline   Reply With Quote
Old 01-28-2011, 01:16 PM   #8
Dknits782
Member#: 153302
Because penelope cruz is my girlfriend duh, don't u read the national enquirer
Old 01-28-2011, 03:21 PM   #9
PoorWRX
Member#: 82260
2002 Impreza WRX
She wants to make sure she don't blow engine lol
Old 01-28-2011, 04:47 PM   #10
Back Road Runner
Member#: 60082
2004 Forester STI
Shift rpm depends upon how aggressive I'm speeding up which depends upon the throttle percentage. Throttle percentage will create a natural power band that is different from different percentages of throttle. For example, light throttle will typically choke out above 3k rpm. You will feel the power drop, and that's a natural time to shift. You press down the gas more, and the power band shifts some. During full throttle, redline is the ideal shift point given the power band and gear.
Most of my mild cruising with partial throttle has me shift between 3-4k rpm. Where I shift specifically only has to do with the power band at the throttle I'm applying. When the power output rolls off, I shift.
Old 01-29-2011, 04:36 PM   #11
royalnewjersey
Member#: 250954
2013 WRX Hatch
I try to keep my shifting between 2k and 3k for DD. If I'm revving up I'll let the tach hit around 3k and then after the shift I will try not to let it drop below 2k. Otherwise you're eating up fuel trying to get up to speed at low RPM.
When I'm cruising around I try and keep it about 2.5k
royalnewjersey is offline   Reply With Quote
Old 01-30-2011, 06:24 PM   #12
J-Chow
Member#: 104722
2006 2.5i - SOLD
Gray
Daily driving = 2000-3000rpm
Anything over 3000rpm = passing/merging / spirited driving.
But seriously, we need a 6th gear. :P
J-Chow is offline   Reply With Quote
Old 01-30-2011, 06:32 PM   #13
vinxH
Member#: 159796
2006 WRX
i shift at 2400-2500 for normal driving... but in first gear i shift just a little over 2000.
for passing someone i usually go up to ~3200-3500
love low end torque
...and unless you are in 5th gear.... you shouldn't be cruising at 2500... that's a bit high for cruising in gears 1-4... but I guess it also depends what car you have. When I cruise in 1-4 ... I keep it at ~1600-1800
vinxH is offline   Reply With Quote
Old 01-30-2011, 10:16 PM   #14
royalnewjersey
Member#: 250954
2013 WRX Hatch
So you're cruising around at 1k RPM higher than idle?
Then you're just guzzling gas anytime you have to go up hills. Either that or you're doing a lot of shifting / downshifting for passing etc.
It probably also depends on the terrain, but here in Seattle there's so many hills and curves and turns that it doesn't make sense to cruise that low. There's no power down in the 1600 RPM range, and anything other than a flat hill is going to gulp gas.
Old 01-30-2011, 11:39 PM   #15
vinxH
Member#: 159796
2006 WRX
yes, there's nothing wrong with cruising at 1k RPM above idle.
if i'm going uphill then that's a different story. i can tell if my motor is struggling.
if I have to make a pass, then I just downshift 1 gear which puts me at like 2500-2900... how hard is that?
if i know that i'm gonna have to make lots of passes for whatever reason, then i'll keep the RPM high during that time
and it doesn't matter if you dont have power in the 1600 range, you dont need that much power to maintain a constant speed.
if you're the type that is scared to shift/downshift then by all means cruise at 2500 and look like a rookie. we don't drive hondas, our motors actually have torque.
Old 01-31-2011, 12:31 AM   #16
whiteimpreza1
Member#: 259680
06 2.5i impreza
Aspen white.
for cruising shift around 2500
whiteimpreza1 is offline   Reply With Quote
Old 01-31-2011, 12:52 AM   #17
royalnewjersey
Member#: 250954
2013 WRX Hatch
I realized that you and I are talking about apples vs. oranges. You drive a wrx while I drive a 2.5i. Your car has so much more low end torque than mine (turbo). That accounts for a lot of the power band difference, and why you drive in a lower RPM than I normally do.
You know our cars "cruise" at about 2500RPM at 60mph right? That's how subaru engineers designed our car, to run optimally around 2500RPM cruising speed....
And I'm not a rookie
Old 01-31-2011, 12:54 AM   #18
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
So you're a big fan of lugging the engine?
Wow, you're fricking crazy, man!!
love low end torque
If you love the low end torque, you'll love it even more if you actually go up to (and beyond) peak torque.
So what do you think you're gaining by driving around with RPMs that low?
You're right. I do it all the time... in my LS6-powered CTS-V, which has develops more torque at 1500rpm than a N/A EJ25 develops at peak torque. In a small displacement 4cyl there's nothing to be gained by rolling around at 16-1800rpm.
I hate to break it to you, but the EJ25 is still just a N/A 4cyl. Yes, it's designed to provide a bit more low end than most inline 4s, but I doubt I would drive a Honda 2.4L or Nissan 2.5L or Toyota 2.5L any differently than the EJ25 when it comes to day-to-day driving.
As for when I shift, I'd say my driving style is about the same as Back Road Runner's. I guess that makes me a rookie.
Old 01-31-2011, 04:30 PM   #19
vinxH
Member#: 159796
2006 WRX
prime example that member # doesn't mean anything.
something tells me you've never driven a WRX 2.5L but just like to run your mouth.
and research: torque vs peak torque
Old 01-31-2011, 04:31 PM   #20
vinxH
Member#: 159796
2006 WRX
I was speaking only in terms of gears 1-4.
Old 01-31-2011, 04:56 PM   #21
funky monk
Member#: 143094
08 LGT
DBM
WOT.
All day, every day.
funky monk is offline   Reply With Quote
Old 01-31-2011, 05:06 PM   #22
CornEyedButtSnake
Member#: 271131
Hey its better than Tom "cruise" you know? haha anyway when I'm trying to save on gas I cruise at 2k and shift at 2.5-3k never going above 3k unless on interstate. I never go above 6k even when I'm farting off and even then I've only been that high a few times.
CornEyedButtSnake is offline   Reply With Quote
Old 01-31-2011, 05:16 PM   #23
CornEyedButtSnake
Member#: 271131
I'm a little confused by what your trying to say, but the turbo shouldn't have much effect on low end, check out some dyno's and you will see what I mean. Maybe if a roots or screw was installed this argument could be made
Old 01-31-2011, 05:29 PM   #24
thewritingwriter
Member#: 243214
2014 WRX Premium
Originally Posted by funky monk View Post
WOT.
All day, every day.
thewritingwriter is offline   Reply With Quote
Old 01-31-2011, 06:33 PM   #25
subi400
Member#: 216984
1996 Impreza outback
Green
For dd, I normally shift at 2800-3000 or so. But when the engine is still warming up I'll take it easy and shift at 2200 or so until it gets close to operating temperature on the gauge so as not to induce any extra wear. But when the engine is good and warmed up, I'll shift any where between 3k and 5 k depending on where I am driving, but mostly 3k or so. If it is an on ramp I'll go right up to 5200 or so in gears 2 and 3 if I need to book it, if not then I'll shift at closer to 4k in 2-4 with about medium throttle. My car has 182,000 some miles on it right now but still gets up and goes though...lol I am using the shell T-6 oil in it and about to do a 3rd oil change using this oil and so far it runs good with it.
subi400 is online now   Reply With Quote
at what RPM do you shift for daily driving? swrtwagon Impreza Forum 18 03-21-2005 10:50 PM
what RPM do you shift at? dabigmooish Newbies & FAQs 66 03-11-2005 06:46 PM
What rpms do you launch at???? Devilprobably Texas Impreza Club Forum -- TXIC 23 01-28-2005 08:29 PM
When you shift 1->2 at redline, what RPM do you "land" at? Butt Dyno Proven Power Bragging 2 08-12-2003 05:10 PM
What rpm do you shift your WRX? moojamboo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 04-14-2002 05:32 PM
