Old 01-28-2011, 04:16 AM   #1
grayhatter
Member#: 129526
91 Vintage Legacy
Rallitek Car #124
Default Transmission help, '92 leg with JDM.
Looking for a replacement transmission for the Rally car.... 1992 Legacy with an EJ20G ('96 JDM WRX i think).
Been reading up a lot on what works and still a bit mystified... sounds like pre '97 there's different shift linkage in the transmissions? There's also the question of push vs. pull type clutch's. Then of course trying to figure out the JDM aspect of the whole thing...
At any rate, I need to get a new transmission after loosing third gear on stage at Mt. Hood rally. For now I'm looking for something cheap.
These guys out of Portland, OR seem to have a large selection.... would something like this work?
http://cgi.ebay.com/ebaymotors/96-97...item35af42a176
Appreciate any help you guys have to offer...
On a side note - Anyone in the Puget Sound / Tacoma / KenPen area looking to help out with Rally? I'd love to get a team going.
James
grayhatter is offline   Reply With Quote
Old 01-28-2011, 09:03 AM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
Any transmission from any subaru with an EJ engine will work. You just need the matching parts.
Use a pull clutch and flywheel with a pull clutch trans and push with push.
The shift linkage doesn't matter as long as you use the complete shifter assembly as a unit.
You have to match the trans final drive to the rear diff final drive.
The one in your link would work as long as you got a push clutch and flywheel and made sure the final drives match.
Old 01-28-2011, 11:18 AM   #3
RallyColtTurbo
Member#: 16819
I'll add....
For the shift linkage you will need to have the adapter mounted on the transmission match also. There are two versions, one "male" and one "female".
Also keep in mind that rear differential ratio.
RallyColtTurbo is offline   Reply With Quote
Old 02-11-2011, 04:06 PM   #4
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
there was a variation on the shifter linkage, the way it was assembled at the shift post. but the entire linkage is swappable with another entire linkage for all AWD 5mt imprezas (93-07), and 90's legacys as well. for example i used a usdm wrx shift linkage on a 93 impreza chassis with a jdm 97 STi transmission, its all compatible
also you can use any EJ transmission but i would recommend another turbo transmission so you can keep the same clutch and flywheel and everything.
elislider is offline   Reply With Quote
Old 02-12-2011, 12:58 AM   #5
ncarn8
Member#: 71419
Not too mention annihilating the non turbo one in 5 minutes.
Dont buy the one in the link. Instead, if you want something a bit more up to the task, search around for any of these codes.
TY752VB3EA
TY752VB4CA - STI version 2 RA. Has longer 1st. Good for gravel etc
TY752VB5CA
TY752VB4AA
From the older style ones. All of these have decent ratios for rally applications, but are the older 4 bolt box. (TY752) Cheap these days.
But If it were me, id find one of these ones
TY754VB1CA
TY754VB1EA
TY754VB1BA - my favorite.
The TY754 boxes are stronger, more reinforced and known as 8 bolt boxes. They also have thicker gears, double synchros on 2 and 3 (some 4) and will suit your needs better than some random tranny from ebay. You might need to fiddle the dowels on the bottom of it to fit it buts its easy on the older style engines.
Just make sure you match up the ratios with a matching rear differential. They all use common hydraulic clutches, flywheels are interchangeable, parts are easy to find and shifters/linkages all the same. Throw in an STI short shift while your at it if you dont get one with the box. And youll be all around the chocolates after that.
Hope that helps.
ncarn8 is offline   Reply With Quote
Old 02-12-2011, 01:20 AM   #6
Florin1
Member#: 163625
91 Legacy SS
James, I got a 91 legacy turbo that has an ej20g swap with an a/t trans. When the trans died, i just swapped to 5 spd. I grabbed one out of a 96 impreza. Its held up pretty good for the last few months, so i cant say they wont hold up. Also, all the other guys above me had good info...
Florin1 is offline   Reply With Quote
Need some help with my wrx wagon with jdm spec b 2.0 RyanSwanson Newbies & FAQs 2 12-08-2010 11:57 AM
JDM wrx transmission help VBwrex13 Transmission (AT/MT) & Driveline 2 11-29-2010 02:11 PM
Lifting '92 Leg. w/ '98 Forester struts help iamthelazerviking Interior & Exterior Modification 2 07-16-2010 10:30 AM
Help getting frustrated with jdm USMARINE24M Subaru Conversions 4 10-11-2006 11:26 PM
outback brakes on '92 leg jharl Legacy Forum 2 08-05-2006 02:49 AM
