Old 07-10-2002, 02:14 AM   #1
ScoobyRacer99
Member#: 20972
SILVER
Question A/F Guage.....Please Help....Tried Everything!!!
I just purchased a Venom Performance A/F monitor, and hooked up all coorsponding wires. I ran the sensor wire to the O2 sensor in the center pipe, and attached it to the white wire....is this correct? Because I tried the blue wire as well, and it didn't work either.
If i disconnect the sensor wire, it lights all LEDs up. When attached it stays all the way over at lean, regardless of the rpms or opperating temp.
I relocated my O2 sensor after my cat in my exhuast, because of a CEL. I have a full turbo back exhuast on my 02 WRX, and Since I started fooling with the O2 sensor, my car will run rich, and then lean out. But I really cannot tell whats going on due to the sensor not working.
Should I wire it to the ECU?? If so what wire do I need to attach the sensor wire to???
Please help.....
T.D.
ScoobyRacer99 is offline   Reply With Quote
Old 07-10-2002, 02:31 AM   #2
ScoobyRacer99
Member#: 20972
SILVER
Exclamation Also
When I extended my O2 sensor wires I confused the two black ones, and I know one is a heater, and the other is a ground.........
I need to know which is which......
4 wires....
1 blue
1 white
2 BLACK!!!!! Please Help!!!!
They are supposed to have stripes, but they don't
Old 07-10-2002, 03:42 AM   #3
d's_wrx
Member#: 19903
2002 impreza wrx
world rally blue
hey man i had the same problem. i just bought an autometer a/f/ ratio gauge and i got the ecu pinouts to install the gauge and it didnt work. so i called autometer and asked them where it would connect to. he told that our o2 sensors are wideband (whatever that means) and that it wont read the sensor.
d's_wrx is offline   Reply With Quote
Old 07-10-2002, 07:47 AM   #4
giulio
Member#: 16040
1998 Impreza RS
Supercharged
Most people in your situation tap the o2 wire on the ECU. It worked on both my SAFC and J&S a/f guage.
good luck!
g
giulio is offline   Reply With Quote
Old 07-10-2002, 09:40 AM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Use a voltage meter to read while the car is on... one will read nothing, the other will read positive. The positive one should be the heater wire (unless it's the ground for the heater instead).
Old 07-10-2002, 12:23 PM   #6
ScoobyRacer99
Member#: 20972
SILVER
Ok.... but thats comming from the plug, how do I know which is which from the actual O2 sensor???
==0---------------- "I cut here" ---------------8
==0 Actual O2 sensor bung
8 plug going to ECU
My delimma is even if I can find out which it is from the plug, I dont have any idea which black to attach it to on the o2 sensor
Old 07-10-2002, 12:39 PM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Ok, the O2 sensor has a plug a little back up the line... see if you can see where those black wires meet in there and see what colors the attach to on the other side of that plug.
Please Help! Air in my Power steering! I've tried everything. WrxP36 Brakes, Steering & Suspension 15 10-31-2008 09:13 PM
CEL p1507 code. Please help Ive tried everything. Motts Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-28-2006 07:49 PM
Would a local please help with egt gauge install? OvrClkdPmp Mid West Subaru Owners Club Forum -- MWSOC 9 12-25-2005 03:27 AM
please help with vacuum gauge install Jonathan_Yi Interior & Exterior Modification 4 06-24-2001 06:36 PM
Help i've tried everything? XROLLER General Forum Archive 1 12-21-2000 06:17 AM
