Old 01-28-2011, 12:59 PM   #1
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
Default MAF Voltage dipping on tip-out
Can anyone explain this? APS FMIC, stock BPV, APS 70mm intake.
Causes a lean condition and hesitation on throttle tip-out.
Code:
3397;   1.8; 3.0 ;    9;   0 ;  0 ; 34.9;  16.4; ECU ; WGS ;15.07;
 3380;   0.8; 2.9 ;    8;   0 ;  0 ; 35.6;  13.8; ECU ; WGS ;15.19;
 3411;  -2.0; 3.3 ;    6;   0 ;  0 ; 33.5;  11.5; ECU ;  0.00;14.02;
 3290;  -2.8; 3.3 ;    6;   0 ;  0 ; 33.6;  11.1; ECU ;  0.00;15.03;
 3350;  -5.0; 1.7 ;    5;   0 ;  0 ; 39.3;   5.4; ECU ;  0.00;19.07;
 3418;  -5.6; 1.4 ;    4;   0 ;  0 ; 38.0;   4.9; ECU ;  0.00;24.18;
 3425;  -6.6; 1.5 ;    4;   0 ;  0 ; 38.6;   5.0; ECU ;  0.00;25.50;
 3373;  -7.0; 1.8 ;    4;   0 ;  0 ; 38.1;   5.7; ECU ;  0.00;21.87;
 3439;  -7.6; 1.8 ;    4;   0 ;  0 ; 38.6;   6.1; ECU ;  0.00;18.56;
 3436;  -8.0; 1.8 ;    4;   0 ;  0 ; 38.8;   6.7; ECU ;  0.00;15.17;
 3512;  -8.2; 1.8 ;    4;   0 ;  0 ; 39.3;   6.8; ECU ;  0.00;15.17;
Zackbo is offline   Reply With Quote
Old 01-28-2011, 01:46 PM   #2
quazimoto
Member#: 70395
You should start yet another thread on this............
"#11. No CROSS-POSTING of topics is allowed in the forums. Definition of Cross-Posting: posting the same thread, or a link to the original thread, in more than one forum. This will get you put into TimeOut."
http://forums.nasioc.com/forums/misc.php?do=cfrules
quazimoto is offline   Reply With Quote
Old 01-28-2011, 01:59 PM   #3
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
I'm sure you're right.
My apologies to everyone on the board for wasting space.
Won't happen again.
Old 01-31-2011, 06:59 PM   #4
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
column headers would be nice....
what do you expect the MAFv to do when you are letting off the gas?
whats your fuel trim in that g/s range?
are u in cl or ol? if you're in OL whats your target AFR at that load and rpm?
Phatron is online now   Reply With Quote
Blow-Thru MAF SIZE... MAF Voltage Question!?! Maverick7531 AccessPort 4 09-16-2010 01:37 PM
MAF Voltage when Car in on, but not running Mechie3 Factory 2.5L Turbo Powertrain 4 11-25-2009 08:43 AM
Enginuity: Is load column based on MAF voltage? NITROS Commercial ECU Reflashes 5 03-05-2007 04:26 PM
MAF voltage on stock sti turbo? overdose Engine Management & Tuning 8 07-06-2006 01:32 PM
Need help: MAF voltages Orbiter Normally Aspirated Powertrain 4 11-08-2000 09:36 PM
Message Board Statistics All times are GMT -4. The time now is 10:07 AM.
