Old 01-28-2011, 03:08 PM   #1
TPNORTH
Member#: 210741
Default Need help looking at 95 Impreza!
Okay going to look at a 95 impreza 1.8 fwd tonight.The guy says it has problems when its cold out starting.What can this be? Im thinking maybe thermostat? Also what should i look for i know the headgaskets are crapo but anything else i really need to look for other then the normal stuff?
TPNORTH is offline   Reply With Quote
Old 01-28-2011, 03:26 PM   #2
beaconhillkilla
Member#: 174710
1992 Legacy Turbo
Dream Machine
The EJ18 headgaskets are just fine, you really don't have much to worry about there. I would bring a mechanic friend with you, or take it to a mechanic before you buy it. If you don't know much about cars this is your best option to make sure that you don't get screwed over.
beaconhillkilla is offline   Reply With Quote
Old 01-28-2011, 03:32 PM   #3
TPNORTH
Member#: 210741
haha i know cars pretty well just not this car kinda thing. lol i plan on doing a compression test and such just not sure about the cold start thing.I have a 2004 wrx im building now since my motor blew so i have a pretty decent knowledge of the ej205 motors through research and tear downs but not sure how similar these older motors are to the new turbo cousins.Also im looking at droping 600 bucks on the car haha so i know ill need to do a little work but i have a weekend to get it running cuz ill lose my current car on monday so the faster i can fix things and not have to diag the motor the happier ill be!
Old 01-28-2011, 03:32 PM   #4
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
EJ25s are the only known EJ to have noteable HG failures. Cold start problems could be caused by a faulty coolant temp sensor, it is pretty common for these to go bad at some point. You can test it before you get a new on, and even at that the new part is only $20.
Jessekrs123 is offline   Reply With Quote
Old 01-28-2011, 03:36 PM   #5
TPNORTH
Member#: 210741
how do you test them? I was thinking thats what it will be and hell at 20 bucks ill just replace it lol
Old 01-28-2011, 08:42 PM   #6
Jessekrs123
Member#: 236927
1984 BRAT
The coolant temp sensor is a thermosistor that sends a certain resistance to the ECU which tells it how to adjust the fuel according to the temperature of the coolant. Obviously during a cold start, the engine must use more fuel to get it going, if there isn't adequate fuel, it won't start.
How to test it:
Remove your coolant temp sensor. Use something to plug up the threads or else you will spill coolant everywhere. There are 2 prongs on it, with your multimeter, measure the resistance between the two prongs. As the temperature DECREASES, the resistance should INCREASE. I'm not sure on the exact numbers at certain temps.
It's a cheap part. Replace it, if it works then you just fixed your car for $20. If it doesn't work, oh well, whats 20 bucks.
Old 01-28-2011, 09:09 PM   #7
TPNORTH
Member#: 210741
car just sold before i got there.....
Old 01-28-2011, 09:16 PM   #8
Jessekrs123
Member#: 236927
1984 BRAT
Ahh thats too bad...
I'm sure you can find another 1st gen for cheap somewhere else. My first legacy wagon was $180 and the one I drive today was only $800. Both were FWD with the 2.2. I've yet to own a 4WD or AWD Subaru
Looking at '09 Impreza GT... Need advice... jcantx82 Newbies & FAQs 13 10-07-2009 08:38 PM
Attn Pittsburgh: Need help looking at apartments ($) adamrj8282 Mid Atlantic Impreza Club -- MAIC 1 04-21-2009 08:28 AM
Some help needed - Looking at 06 Impreza 2.5i.. Damn Dirty Ape Newbies & FAQs 19 10-29-2006 07:38 AM
Need help- looking at new rims for WRX rudyWRX New England Impreza Club Forum -- NESIC 7 03-02-2006 02:54 PM
Looking for 95 Impreza Front bumper QuickDrive Canada Region Forum 5 01-08-2004 03:32 AM
