Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 01-28-2011, 06:08 PM   #1
ezil71
Member#: 207118
2003 Wrx Wagon
Default caliper grease - guide pins and lock pins
So one of my pins had the rubber rip a bit and I picked up a replacement at autozone (duralast). It seems to be a bit thicker, doesn't slide as well. Even the stock pins don't have a lot of space for grease as far as I can tell.
Does subaru use some sort of unique grease on those pins? The usual brake/caliper grease I've used is a bit thick. I'd hate to have a pin lock up on me.
Why the heck does one pin have the rubber on it and the other doesn't in the first place?
I couldn't find new boots for the pins that worked, and Subaru seemed to only have them as a pricey kit. The Napa boots that claimed to be for the wrx were too short and pop off.
Is OEM the only way to go for those pins?
Thanks
ezil71 is offline   Reply With Quote
Old 01-28-2011, 07:41 PM   #2
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
i havent had any issues using an aftermarket hardware kit for any car/truck before, and that should come with the pins, boots etc. but i know ppl that are diehard for OE stuff so its ur choice. as for the grease ill lube the pin, work it in an out to make sure it slides ok, if i have to ill dap some grease at the opening then put the pin in. it doesnt have to be an enormous amount, u should be using synthetic caliper grease so it stays pretty well. whenever you do a break job u should reapply the grease to the pins.
the little rubber booty thing i think is so the caliper doesnt "wiggle" under the force of braking an cause a click or knock sound. im not 100% on that tho
romanlynch is offline   Reply With Quote
Old 01-28-2011, 08:50 PM   #3
ezil71
Member#: 207118
2003 Wrx Wagon
That's just it though, the aftermarket pin I have is clearly thicker, so even when greased properly it doesn't slide easily, although it does move with some effort. I'm guessing the duralast part isn't a metric part, and just off by a hair. None of the parts I found include the caliper boots, only the caliper rebuild kit from subaru did, and the ones Napa sold that were the wrong size.
Just wondering if anyone else has had that problem, or found another aftermarket part that does fit right.
Old 02-03-2011, 09:46 PM   #4
OrbitalEllipses
Member#: 178811
2013 Why don't you
just GFY?
I replaced my rear caliper slide and lock pins with a generic kit from Advance Auto not very long ago; I too noticed they didn't slide as well.
The kit included dust boots and the small rubber bit that goes on the end of the lock pin. What I found was that the generic replacement rubber bit was actually rather large, and that the Subaru one was smaller. Luckily, I had a Subaru seal rebuild kit on hand and used the small rubber bit it provided. I'm talking about part a5 in this picture:
FWIW, the generic guide/lock pin kit I used was this one. It says two required, you only need one.
OrbitalEllipses is offline   Reply With Quote
Old 02-07-2011, 04:00 PM   #5
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
I'm having problems with this same part, after installing an aftermarket H6 upgrade bracket (RacingBrake). The slide pin builds up pressure like a syringe, and won't push down very far into the hole before the pressure is so high that it is effectively bottomed out. LIkewise, if I pull it out a bit, it builds up a vacuum and pulls the pin back into the hole. I was barely able to get it compressed enough to slide over the pads when reattaching the caliper, but now I think the outboard pad is dragging because of it. Is this "syringe" type behavior normal, or should the pin move freely in and out? The only way I can get the pin to slide freely in/out is if I remove that rubber boot from the bottom of the pin.
Wade-O is offline   Reply With Quote
Old 02-08-2011, 12:15 PM   #6
romanlynch
Member#: 126684
02 wrx
how much are you moving the pin in and out, when you hit the brakes theres not much movement of the caliper. ive had the same thing happen on my car an many others after i grease up the pins. it might have some resistance when u go to push it all the way in an then pull it almost all the way out. you definately need the boot on there so the water etc doesnt get into the caliper bracket, thatll rust it together real quick.
Old 02-08-2011, 04:31 PM   #7
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
I'm not talking about the accordian-like boot at the top of the pin, but the small rubber bushing at the bottom of the guide pin. I actually couldn't get it to compress enough to get the caliper over the pads until I scooped some of the grease out. Even then it was super tight. I went ahead and ordered the seal kit last night, we'll see how it goes with new bushings.
Old 02-14-2011, 02:33 PM   #8
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
Got the new rubber bushings installed this weekend, and it made all the difference. The guide pins now slide in/out effortlessly. When I put the new bushings next to the old one, it was obvious there was some deformation in the old ones. They were longer than the new ones by about 1/8" or so. Pretty dramatic size difference, I thought for a minute they weren't even the right part.
Part a5 on the diagram above for anyone who's wondering. I had to buy the whole kit (#3 in the diagram) just to get those little buggers.
Old 04-27-2011, 10:59 PM   #9
2:43AM
Member#: 190273
05 WRX evoIII-16G
I'm bumping this one out of a two-plus month hiatus because of the exact problem I am experiencing now! I cannot get the lower caliper pin to go into the housing. The pressure is far too great, as if it feels like the bolt is bottoming out. Wade-O, you hit it on the head.
I think the rubber gasket at the end of the pin is either deformed or swollen enough to not allow proper insertion, even with minimal grease.
Where did you get the rebuild kit? Dealer?
2:43AM is offline   Reply With Quote
Old 04-27-2011, 11:12 PM   #10
2:43AM
Member#: 190273
05 WRX evoIII-16G
Something I found of great interest regarding the rubber bushings:
Get a slider pin bushing kit from dealer and make sure u use sil-glide (silicone based lube), u can get it from Canadian tires (green bottle), its about 5.99 i think. Permatex silicone lube is OK to use.
Any petroleum-based lub will swell the rubber bushings and the boots.
Huh. Seems reasonable. Well, I wish I would have know that a long time ago. Live and learn, I guess.
EDIT: Best choice/alternative to NIGLUBE RX-2 (per subie service manual) is Syl-Glyde. The cheaper Permatex lube (green bottle) may not be appropriate.
Old 04-27-2011, 11:38 PM   #11
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
Well first, my 2002 FSM shows the bushing on the top pin, not the bottom. So you might just have the pins reversed.
I ordered my caliper seal kit from SubaruGenuineParts.com and had it in about 2 days. One kit has all the parts for both sides.
Old 04-28-2011, 12:04 AM   #12
2:43AM
Member#: 190273
05 WRX evoIII-16G
Hmm. My 04-05 service manual shows no bushings for either pin on the front...only on the rear brake, bottom pins. Unless the image is drawn incorrectly where the "bushing" shown is present, but it doesn't match the pin shape. #17 in the first diagram (for front brakes) and #33 in the second diagram (for rear brakes). In the first diagram, #17 vs. #8 doesn't make any sense.
Did I somehow swap these pins into the wrong places during my last brake job?
I do know one thing for sure. This is ****ing ridiculous!
Old 04-28-2011, 12:13 AM   #13
2:43AM
Member#: 190273
05 WRX evoIII-16G
And is this stuff OK for the pins and bushings? This is what I am CURRENTLY trying to use (before giving up when the bottom pin would not push into the caliper).
But thinking about returning it, and buying this instead, which seems more appropriate:
Old 04-28-2011, 12:51 AM   #14
2:43AM
Member#: 190273
05 WRX evoIII-16G
And YES this seems like a one sided conversation, but I just trimmed my "swollen" bushings by about 1/16" with a razor blade. The pin slid into the housing with ease. I suspect the sixteenth of an inch won't make a bit of difference in the long run.
Even with a future, "correct" lube, the pin would STILL refuse to go in. Therefore, since I will continue to use the existing bushings, the cut was necessary.
Old 04-30-2011, 04:40 PM   #15
SamwiseTheBrave
Member#: 281509
FYI, O'Reilly Autoparts has a pin kit for 4.29 that includes two of those little rubber grommets. The pin boots in this kit are too small, but they got the grommets the right size. My dealership wanted 35 for a seal kit. No way!
The O'Reilly ones work great. Kind of a stupid design on Subaru's part. They are so hard to get in with all the air compressed behind them.
SamwiseTheBrave is offline   Reply With Quote
Old 05-01-2011, 05:03 PM   #16
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
The OEM caliper rebuild kit only cost me $20 from SubaruGenuineParts.com (aka Chaplin's Subaru). It's way overkill if you only need those bushings though. O'Reilly's (aka Shuck's) only pulled up the same kit in their parts search, and their price was only a couple bucks cheaper and they had to order it, so I went with the OE kit. Of course mine is an 02, so things might be different for the newer model years.
Old 05-06-2011, 02:54 PM   #17
ezil71
Member#: 207118
2003 Wrx Wagon
I suspect the swelling is due to getting brake parts cleaner on the rubber boot section. Lessoned learned on that one! Take off the rubber part before cleaning up the pins.
Old 05-23-2011, 06:22 PM   #18
samo22
Member#: 119693
1995 L w/ ej205
I too am having a similar issue with the duralast guide pin having a hard time fitting into the caliper bracket pin hole. I noticed on the duralast one, the three equally spaced flat surfaces that run concentric along the pin ends about half inch shorter than the oem one, which is causing the pin to hit the caliper bracket hole early and gets stuck. There are other minor differences such as duralast one is .1mm larger diameter than OEM and the duralast flat surfaces are slightly wider. I thought about grinding down the pin to increase length of the flat surfaces but I'd probably need to paint it to prevent rust, and that's too much of a trouble. I guess I am ordering a OEM guide pin from a subaru dealer.
samo22 is offline   Reply With Quote
Old 05-23-2011, 07:44 PM   #19
A5un
Member#: 174095
2011 EVO X MR
I did a LGT front brake swap onto my car some months ago, and during the process I had rebuilt the calipers with OE kit. Contained in the kit were two little packets of grease, a red one and a pink one. Along with them came a note that said something to the effect of "any other grease is not okay!" I'm not sure what's so special about these grease, but just letting people know that's what they said.
A5un is offline   Reply With Quote
Old 07-01-2011, 09:58 PM   #20
the dude
Member#: 94542
2002 WRX wagon
bump. any definitive answer on if the guide pin or lock pin is on the top or bottom of the caliper?
the dude is offline   Reply With Quote
Old 07-01-2011, 10:48 PM   #21
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
lock on the bottom
Sir-Knight is offline   Reply With Quote
Old 07-02-2011, 12:57 AM   #22
the dude
Member#: 94542
2002 WRX wagon
cool. thanks man!
Old 07-03-2011, 01:56 PM   #23
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
This is the rear brake assembly diagram from the 2002 FSM:
Old 07-03-2011, 02:06 PM   #24
vr6vdub172
Member#: 287291
01 VW
This stuff works great. Use it on every brake job I do for caliper slide pins. Can get it in different quantities as well.
http://shop.advanceautoparts.com/1/1...art-09977.html
vr6vdub172 is offline   Reply With Quote
Old 07-06-2011, 10:43 PM   #25
drummerdude
Member#: 255999
2002 Impreza RS 5MT
blue
Default guide pins
I just replaced my pads due to a seized guide pin, while waiting for the new guide pins to come in, I got the old one out, cleaned it up and lubed it, it now slides okay.
The guide pins came in today and they are about a half inch to an inch longer than the oem ones. the oem pins, one has a rubber bushing on it, the other doesn't, on the new pins, neither had any rubber on it.
My questions is are these supposed to be trimmed, cause otherwise, all the replacement ones I pull up (that have pictures) look to be about the same length, and is the rubber bushing needed?
drummerdude is offline   Reply With Quote
Guide Pins? Lock Pins? WTF! T Wrex--OH Brakes, Steering & Suspension 5 04-04-2009 01:41 AM
caliper lock pin - seized up all the time - common? MrZone Brakes, Steering & Suspension 3 05-26-2006 09:55 PM
Guide pin vs. lock pin Legacy777 Brakes, Steering & Suspension 8 12-09-2004 09:52 AM
Hi-Temp Grease = Caliper Grease? Hank3 Brakes, Steering & Suspension 6 08-16-2004 05:39 PM
guide and lock pins eastbaysubaru Brakes, Steering & Suspension 4 09-17-2001 11:54 AM
