Old 01-28-2011, 09:50 PM   #1
rhino6303
Member#: 181314
2005 Impreza OBS SRR
05 Legacy GT RBP
Default TWE header questions
Questions answered. Please delete thread.
rhino6303 is offline   Reply With Quote
Old 01-29-2011, 09:38 AM   #2
GEE-OTTO
Member#: 201277
2009 Legacy GT
Well nobody knows yets except TWE as they are still in the process of building the prototype. However they are smart people and performance oriented so im sure they will prouce a unit to address all the gripes amongst the community
GEE-OTTO is offline   Reply With Quote
Old 01-29-2011, 11:04 AM   #3
renyo
Member#: 93577
98 Impreza
The TWE header works for 05 already.
Originally Posted by rhino6303 View Post
Within the next month or so, I plan on getting rid of my wrapped borla replica and buying a nice TWE header. I have some questions regarding the "new" TWE header (I searched for answers to no avail).
Car: MY05 Impreza OBS 4EAT
Supposedly they don't fit automatics.
1. Will the TWE header hit the subframe/melt the P/S line?
I've never heard of anyone saying it will.
4. Is it cost effective to get the header coated rather than wrapping it?
Cost effective depends on you. Coating has its advantages over wrapping though.
renyo is offline   Reply With Quote
Old 01-29-2011, 11:10 AM   #4
GrundleJuice
Member#: 165749
2. Will the TWE header allow me to drain my tranny fluid without removing the header?
3. Can I use my existing skidplate with the TWE header (I already have spacers because of the Borla replica)?
5. Last, will coating the TWE header still produce the P0420 CEL (have never had the CEL with the wrapped Borla replica)?
Sorry for so many questions, but I appreciate the help. By the way, I talked with Tom at TWE and the price really is cheaper than what they quote online.
Thanks again,
Steve
The "new" headers twe is producing are designed for 06/07 I thought. The 4-2-1 design runs right under the trans drain plug on my 5MT, but a tool can be fabricated for little $ to aid removal of the plug without removing the headers. A little drip pan or something around the headers like alum foil when draining the fluid should do the trick. If you want a pic of the tool, let me know and ll post it here. The 4-2-1 design will fit the 4EAT according to who I bought mine from.
Old 01-29-2011, 11:56 AM   #5
colorfull
Member#: 136688
2005 Impreza RS
I have a 4 into 1 TWE header on my 05 rs (MT) and it used to hit the U-frame on the driver's side until I replaced my engine mounts by hardened STI mounts. No problems since the new mounts are in.
On my 5 speed tranny, the header has to be taken down to flush the transmission oil.
No 0420 CEL, and the header's not wrapped nor coated.
TWE header & mechanical rear diff = best mods I ever did to the car.
DO IT!!!!!
colorfull is offline   Reply With Quote
Old 01-29-2011, 12:32 PM   #6
renyo
Member#: 93577
98 Impreza
Didn't know the 4-2-1 design didn't have that problem. My mistake.
Old 01-29-2011, 02:02 PM   #7
rhino6303
Member#: 181314
05 Legacy GT RBP
Thanks for all of the replies. Your input is appreciated. I updated the original post to be a little more clear on which header my questions are about. Thanks again.
Old 01-30-2011, 12:21 AM   #8
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Since I ended up with a PM about this:
1) My TWE 4-2-1 HO header, bought in 2010, does not hit the crossmember or power steering lines. Yes, I have the Group N engine mounts. You should have them to.
2) The TWE 4-2-1 header will clear both the 5MT and 4EAT trannies
3) Coating will last longer than wrapping and work pretty well, if done right. The only company doing exhaust coating right is Swaintech. Yes, I've tried JetHot personally. No, it's not as good as Swaintech. The coatings used by cheap pipe makers like Grimmspeed, Import Image, etc isn't worth a damn. Keep in mind that coatings and wrappings work slightly differently. Coating primarily reduces the pipe's ability to radiate. So the surface temperature of the pipe is high but stuff near it, but not touching the pipe, stays much cooler. Wrapping reduces both radiation and conduction. Meaning things can touch the pipe (well, the wrap on the outside of the pipe) with less chance of catching on fire. Wrap does retain more heat overall, but has problems with durability and evenness that coating doesn't have. It's a tradeoff.
twe headers questions newbiescooby2.5rs Normally Aspirated Powertrain 2 06-16-2006 05:12 AM
Video: TWE Header + TWE Cat Section + Brullen Quiet Catback Jard Normally Aspirated Powertrain 7 02-10-2005 12:51 AM
TWE Header Question impr25rs Normally Aspirated Powertrain 1 10-23-2004 07:23 AM
TWE Header owners, I got some questions 1fastrs Normally Aspirated Powertrain 2 08-08-2004 03:25 AM
The TWE Header question thread DrBoy01 Normally Aspirated Powertrain 30 04-12-2003 01:49 AM
