Old 01-29-2011, 12:33 AM   #1
dez357
Member#: 267662
99 legacy
Default 99 outback ej20k swap
I am swapping an ej20k into my 99 outback. I am uncertain on which ecu I can use. I would like to pass emissions and I don't want to spend a ton of cash does any body have any ideas or opinions
dez357 is offline   Reply With Quote
Old 01-30-2011, 01:13 PM   #2
kheff46
Member#: 66739
2002 WRX wagon
not gonna pass with any JDM/EDM, EJ20K ECU. the ECU won't communicate with any emissions testing devices.
--keith
kheff46 is offline   Reply With Quote
Old 01-30-2011, 03:31 PM   #3
slavik.86
Member#: 238300
00 2.5rs built
ej255 swap
how much cash? and ya jdm aint passing
slavik.86 is offline   Reply With Quote
Old 01-30-2011, 05:30 PM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
What you are trying to do can not be done. EJ20K is OBD1 and your 99 Outback is OBD2.
Old 01-30-2011, 08:55 PM   #5
dez357
Member#: 267662
99 legacy
What about an ej207 ecu or maybe the stock ecu with an safc
Old 01-30-2011, 10:52 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
207 - no too different
safc .. start and run yes .. pass emissions .. probably not
Old 01-31-2011, 01:04 AM   #7
dez357
Member#: 267662
99 legacy
What is so different from the 20k to the 207 what would prevent it from working
Old 01-31-2011, 09:46 AM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
timing pattern on the cam socket .. and the shaft diameter is different - not swappable
Old 01-31-2011, 02:38 PM   #9
kheff46
Member#: 66739
2002 WRX wagon
sell it and get a USDM WRX/STI engine/harness/ECU/clip/etc. so you can pass emissions. whatever you choose, make sure it's as complete as possible. verify the condition of used anything you purchase. and prepare to rebuild it if you don't take the time.
the K isn't worth your time unless your car is OBDI, or emissions exempt.
--keith
swap 2.5 and a/t from an 01 outback into a 99 outback mod-sqd Newbies & FAQs 0 02-18-2010 02:00 AM
inspection on ej20k swapped 2001 rs help 2.5rsTurbo Subaru Conversions 6 11-15-2006 02:34 AM
state inspection w/ ej20k swapped 01 rs 2.5rsTurbo General Community 3 11-12-2006 11:39 PM
ej20k swap, clutch question bicanek Transmission (AT/MT) & Driveline 0 11-11-2005 02:05 PM
99 outback sport...looking for swap wagonman138 Newbies & FAQs 0 06-21-2005 12:19 PM
