Old 01-29-2011, 01:26 AM   #1
Justin.S
Member#: 258212
2006 WRX Wagon
Default 06 WRX WAGON, STI swap
How/What do I need to turn my 06 WRX Wagon into a STI? What parts do I have to swap? And how much am I looking at to get a built 5 speed put into my WRX?
Justin.S is offline   Reply With Quote
Old 01-29-2011, 09:15 AM   #2
FullBlackMetal
Member#: 260470
03 WRX Wagon
I'm guessing you want STi to later build on.
I believe you need the STi turbo, STi top mount IC, the injectors, rewiring involved and Cobb tuner (because the ECUs aren't the same). There's other stuff I maybe missing, though Sport Compact Car or Modified Mag, showed a WRX to STi build back last year.
From my Droid
-Dan
FullBlackMetal is offline   Reply With Quote
Old 01-29-2011, 10:35 AM   #3
Justin.S
Member#: 258212
2006 WRX Wagon
Later build on?
Will my block & stock 5 speed handle it?
Do you have a Cobb tuner? I hear they are a must have! What's so awesome about them? If I had one I wouldn't have to go get my car tuned at a shop if I added stuff to my car would I?
Old 01-29-2011, 03:30 PM   #4
Keif
Member#: 107302
It sounds like you need to do a lot of reading.
The STi engine and the 06 wrx engine are almost identical. So you would just want the turbo and the intercooler (The injectors on the 06 wrx are actually a bit bigger). And then buy a 3" turbo back exhaust, a walboro fuel pump, 3-port boost solenoid (search "GM Solenoid") and have it tuned.
A Cobb accessport isn't necessary but it does have a few features that are nice. But IMO they're not worth it. Most tuners use open source programming so all you have to pay for is their time to tune your car.
If you really want to have fun with your car and never have to worry about the transmission breaking i would get the trans built or swap an STi drive train. To have it built with ppg gears is around 4-5k. And STi swap will be around 3-4k with the advantage of the more quiet gears but you also need the drive shaft, linkage,axles, hubs, brembo brakes, etc. Check out of the private classifieds and eventually you'll come across a ppg gear set or STi transmission.
But personally ive ran an STi turbo for a couple years, have done about six auto crosses, made about 15 passes down the 1/4 (12.7 at 108mph, 1.7 60 ft), the occasional spirited drive and my trans has held up great. You can shift as fast as you like as long as the clutch engagement is smooth. Be a bit cautious with first to second, run stiffer mounts ,some good fluid and you'll be fine.
This should give you a good jump start. Like i said, do lots of research and figure out a plan before you buy anything. Every thing you need to know is all here. Good luck!
Keif is offline   Reply With Quote
Old 01-29-2011, 03:40 PM   #5
Blue02Rex.
Member#: 238511
02 Bug Eye
yeah u got alot of reading up to do i have a 02 wrx and i just did a full 06 sti swap trans and motor. ecu, wiring harness all around everything its a big pain in the ass.
Blue02Rex. is offline   Reply With Quote
Old 01-29-2011, 10:18 PM   #6
Justin.S
Member#: 258212
2006 WRX Wagon
Thanks for the info guys! Again haha I'm new at this so the more info the better!
Old 02-01-2011, 08:03 PM   #7
Jefe009
Member#: 197824
1998 Outbk STi SOLD!
Ugly white and gray
Default You just want the power, or....?
If you want to make STi power in your wagon, that's really easy. Start with new exhaust and go from there. Bigger turbo, catless UP, larger TMIC, larger injectors...
Stock STi parts (turbo, tmic) are easy to come by in the used classifieds, and well within an amateur's ability to change out on their own. Ditto for the DP/UP/exhaust. But you'll need tuning for that new setup.
Or do you instead want your wagon to 'feel' like a STi? That's much tougher, and most people who want AVCS (super quick spool up in the low end) just end up buying a wrecked STi and swapping over anything that will fit.
I am running a Stage 2 hybrid setup with stock STi turbo and tmic (300 awhp) and my 06 WRX transmission has handled it fine.
My advice is to find a local shop that specializes in Subaru swaps and tuning. That way you have a local resource to call when you get the flashing check engine light. Good luck!
Jefe009 is offline   Reply With Quote
Old 02-05-2011, 02:52 PM   #8
Link2006
Member#: 249123
2004 PSM STi
I personally have a 2006 wrx wagon with a vf39, sti topmount, full 3in exhaust and nothing else is modded as far as power goes and i do not have an access port, i didnt feel like spending 500 on one or whatever they cost, i got a pro tune from Maxwell power in washington state, tuned me at 320whp and 385 ft lbs. and we have a stock catless uppipe so no real need to change that. but there are rumors about a lot of people blowing up there tranny.
hope this helps
tucker
Link2006 is offline   Reply With Quote
Old 02-05-2011, 03:52 PM   #9
Justin.S
Member#: 258212
2006 WRX Wagon
I just enjoy having a wagon so that's why I want to build it up to get that STI power. What if I upgraded to a stage 2 clutch? Would that help with having the tranny last longed?
Old 02-06-2011, 12:20 PM   #11
Link2006
Member#: 249123
2004 PSM STi
i currently dont have any, but my friend took some recently so when he gets them to me ill give you a link to where i post them.
tucker
Old 02-06-2011, 04:15 PM   #12
Justin.S
Member#: 258212
2006 WRX Wagon
Awesome! Thanks
swapping a 92-x aero front end with a 06 wrx wagon front end. x7742539329x Interior & Exterior Modification 10 01-03-2010 09:59 PM
WTB: 6spd Swap Installed on my 06 WRX Wagon turboge Private 'Wanted' Classifieds 1 09-13-2007 05:45 PM
Can you put an 06 STi Exhaust on an 06 WRX Wagon? INDY_06_STI Interior & Exterior Modification 3 06-20-2006 09:51 AM
Fixed up 06 wrx wagon or stock 06 sti? Balishag Newbies & FAQs 39 12-20-2005 10:32 AM
