Old 01-29-2011, 05:59 PM   #1
12Pack
Member#: 269282
Default 95 LSi no AWD??
I thought all subarus were awd, i guess i found out the hard way during all this snow lol any thought.
12Pack is offline   Reply With Quote
Old 01-29-2011, 06:00 PM   #2
12Pack
Member#: 269282
Also recently today my key wouldnt come out the ignition. Never did it before today but the car was in park and didnt come out. The only way i got it out was to put it in drive then reverse for a little bit then park then it came out, it did this twice already.
Old 01-30-2011, 01:07 AM   #3
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Up until 1996 Subaru did indeed sell a FWD version of the Legacy.
From 1997 onwards they have always been AWD. My guess is that for basic commuter driving AWD really only makes sense in areas that frequently have snow.
My guess is that your shift linkage is slightly out of adjustment and that is why you are having problems yanking your key out. Simplest solution would be to have an extra key made and then keep the current key in the ignition. Use the new key to lock the car with.
Jonathan is offline   Reply With Quote
Old 01-30-2011, 12:16 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
So you really did your homework before you bought the car, eh? No, not all Subarus were AWD back then. Your LSi should be AWD, assuming it is actually an LSi.
any thought.
I'm assuming that's a question? Any thought about what?
Old 01-30-2011, 07:23 PM   #5
12Pack
Member#: 269282
I dont really care its fwd or awd just figured it be awd. Any way to really tell?
Old 01-30-2011, 08:54 PM   #6
Jonathan
Member#: 4021
1999 Legacy GT Ltd
I don't really care if it is FWD or AWD. I just figured it would be AWD. Is there any way to really tell?
Just look at the underside of your car. Is there a round shaft sticking out of the back of the transmission ? If there is one, does it connect to some sort of a differential thingey in the centre between the rear wheels ? If so, then your car does indeed have AWD. It is entirely possible that your car does indeed have AWD that for what ever reason(s) isn't functional.
If your car is an automatic shift, a disreputable seller may install a "FWD enable" fuse, so that the AWD doesn't function and you wont detect any "torque binding" that is typical of a failing electronically controlled clutch pack.
Just a thought.
Old 01-31-2011, 01:49 PM   #7
12Pack
Member#: 269282
Car is AUTO btw and I think i found what would be the diff. and its not working so what can I do, pull the fuse out?
Also.. im leaking gas on the bottom of the fuel from the bottom of the filler neck, it looks kinda rusty but can I sand it down and put some kind of liquid metal on it when its not wet?
Old 01-31-2011, 02:02 PM   #8
thenuge88
Member#: 262660
2009 WRX 5dr Premium
Try mercury
thenuge88 is offline   Reply With Quote
Old 01-31-2011, 02:03 PM   #9
12Pack
Member#: 269282
Old 01-31-2011, 02:22 PM   #10
kirbykirb
Member#: 183596
2005 WRX/9-2x
Obsedian Black Pearl
Wow, my subie was the same color and wasn't that bad rusted
Uhm if theres no fuse inside, then either the system is working and you didn't know...or theres a major issue but it is AWD since it has a rear diff...
kirbykirb is offline   Reply With Quote
Old 01-31-2011, 02:28 PM   #11
12Pack
Member#: 269282
haha gotta love the sand and salty NE roads. fml. awd isnt working im pretty sure just spinning up hill in the snow lol
Old 02-03-2011, 09:45 PM   #12
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
The AWD eventually went out on my 93 Touring Wagon...till I swapped in a 5MT.
DLC is offline   Reply With Quote
Old 02-04-2011, 12:43 AM   #13
Jonathan
Member#: 4021
1999 Legacy GT Ltd
I am [actually your car is] leaking gas on the bottom of the fuel from the bottom of the filler neck, it looks kinda rusty but can I sand it down and put some kind of liquid metal on it when its not wet?
This issue has been covered in the past. I am surprised that some other posters haven't asked you to "do a search". At any rate, in order to save you some time here is a link to what others have encountered :
http://forums.nasioc.com/forums/show....php?t=1466705
Car Run with no oil what can go wrong!!!! wrxsubie2008 General Community 349 06-01-2011 02:23 PM
Why didn't Subaru do this: Dodge AWD commercial Snow Drift Non-Subaru News & Rumors 44 02-12-2011 04:02 PM
FS : no longer fs. methaddict SCIC Private Classifieds 0 02-09-2011 09:59 PM
FS : no longer fs. methaddict Engine/Power/Exhaust 0 02-09-2011 09:53 PM
