View Poll Results: Which Color do you like?
Gold 286 27.61%
Hyper Silver 136 13.13%
Chronium Black (gunmetal'ish) 355 34.27%
Flat black 229 22.10%
Bronze 137 13.22%
Multiple Choice Poll. Voters: 1036. You may not vote on this poll
Old 07-02-2012, 08:02 AM   #4626
cuztomimportz
Member#: 97904
World Rally Blue
Originally Posted by chosen one View Post
i'll just leave this here. waiting on camber bolts and maxing out my coils.
I can almost read your BOA credit card numbers lol
cuztomimportz is offline   Reply With Quote
Old 07-02-2012, 10:17 AM   #4627
TykoSubs
Member#: 324900
Chapter/Region: PRSIC
2005 Impreza
Crown Blue
Originally Posted by aeion View Post
Welcome to NASIOC! They will probably fit on stock suspension, but would look absolutely ridiculous. I suggest an 8.75 or 8.25 width. Much easier to fit and look much better on stock suspension
Ridiculous how?
The thing is that 17"s have only 8.25 & 9.75 in width, and 8.25 doesn't look flush enough for my taste.
Will Coil Overs resolve this? And if so, what would you recommend?
Thanks
TykoSubs is offline   Reply With Quote
Old 07-02-2012, 12:47 PM   #4628
aeion
Member#: 182114
1996 Nissan HARDbody
1931 Ford Model A
Originally Posted by TykoSubs
Ridiculous how?
Thanks
They'll be really wide and poke like crazy. Best fix would be coilovers, tons of camber and small tires to run that size
aeion is offline   Reply With Quote
Old 07-02-2012, 12:48 PM   #4629
Pidgeon
Member#: 284247
2002 Wrx
MBP!
this, beat me to the punch haha
Pidgeon is offline   Reply With Quote
Old 07-02-2012, 03:14 PM   #4630
TykoSubs
Member#: 324900
2005 Impreza
Crown Blue
I really appreciate the help. Much thanks!
Going for the 17x9.75 225/40 +25 anyways, but also expecting to get coil overs and camber bolts mounted.
Again, mad props for the help.
Old 07-02-2012, 03:25 PM   #4631
aeion
Member#: 182114
1931 Ford Model A
No problem buddy! Just make sure to do everything right the first time and RESEARCH RESEARCH RESEARCH before you start putting the whole setup together. Otherwise you'll end up
And helping is just what I try to do around this thread. If you need any more help or anything, refer to this thread as we've pretty much covered it all over the years in here haha.
Old 07-03-2012, 09:32 PM   #4632
VooDooSTi
Member#: 308632
2011 STi
Black Obsidian Pearl
well this is my 2011 STi with the 18x8.75 +35mm's....had to get a 5mm shim to clear the calipers until I can find some hubcentrics for it. If anyone knows where I can get some 5mm hubcentrics that will fit the center bore of the 530's please let me know
tires are goin on tomorrow am
VooDooSTi is offline   Reply With Quote
Old 07-03-2012, 10:45 PM   #4633
NWsoobie
Member#: 289516
2012 WRX
ISM
Les schwab has hub rings. Thats where i got mine for my 530's. But they aren't going to push it out at all. They are only used to keep the wheel centered on the hub. You will still need to run spacers. Also, you might want to make sure to run the same spacer in the rear to match too.
NWsoobie is offline   Reply With Quote
Old 07-04-2012, 06:56 AM   #4634
VooDooSTi
Member#: 308632
2011 STi
yeah no matter what I'm running spacers front to back I'm just putting on a generic spacer for now until I can get my hands on hubcentric spacers or have some made
Old 07-04-2012, 11:03 AM   #4635
knoxville1
Member#: 248436
2000 2.5RS V7 STI
Sedona red pearl
knoxville1 is offline   Reply With Quote
Old 07-04-2012, 12:40 PM   #4636
chicagosynergy
Member#: 288958
527's in 17x9.75 with 25 offset.
This is on a Bugeye
chicagosynergy is offline   Reply With Quote
Old 07-04-2012, 12:58 PM   #4637
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
^post up wheel & tire specs please
blakkboxer is offline   Reply With Quote
Old 07-04-2012, 01:01 PM   #4638
chicagosynergy
Member#: 288958
Edited, sorry.
Old 07-04-2012, 01:20 PM   #4639
AII2_JOI2DAN
Member#: 194530
5555 V-TECH
what size tire are you planning chicagosynergy?...im looking at the same setup but 530's
AII2_JOI2DAN is offline   Reply With Quote
Old 07-04-2012, 01:26 PM   #4640
chicagosynergy
Member#: 288958
The plan at the moment are star spec 255's
Old 07-04-2012, 01:29 PM   #4641
NWsoobie
Member#: 289516
2012 WRX
ISM
That's a lot of rubber. Gonna need to roll for sure. And a good amount of camber.
Old 07-04-2012, 01:31 PM   #4642
chicagosynergy
Member#: 288958
Already completely rolled and I know I'm gonna have to put some camber on it. I don't plan on going that low, I just don't want stretched tires.
Old 07-04-2012, 01:53 PM   #4643
NWsoobie
Member#: 289516
2012 WRX
ISM
Yah I hear ya. What series tire? 40 or 35's?
Old 07-04-2012, 02:01 PM   #4644
chicagosynergy
Member#: 288958
Probably a 40. That's still in the works lmao
Old 07-04-2012, 04:44 PM   #4645
Alpha X
Member#: 324935
I almost bought XXR 530's but decided to go with Enkei Raijins. Basically the same look.
Alpha X is offline   Reply With Quote
Old 07-04-2012, 05:05 PM   #4646
NWsoobie
Member#: 289516
2012 WRX
ISM
And triple the price.
Old 07-04-2012, 08:45 PM   #4647
TykoSubs
Member#: 324900
2005 Impreza
Crown Blue
This is on a Bugeye
Post pics of mounted tires PLEASE!!
im getting the same setup and want to know if 255's rub against stock suspension.
Old 07-04-2012, 08:46 PM   #4648
TykoSubs
Member#: 324900
2005 Impreza
Crown Blue
and/or innecessary wheel well rubbing, when locking front wheels.
Old 07-05-2012, 03:08 AM   #4649
chicagosynergy
Member#: 288958
I will as soon as possible. I can get you pics of 9.5's with 265's tomorrow lol
Old 07-05-2012, 08:54 PM   #4650
timebombswrx
Member#: 164410
06 WRX Wagon
Dipped Flat White
Got my 527's in today, 18x8.75, hopefully going to put tires on tomorrow, probly going to go with the new nitto motivo's 235/45/18
[/IMG]
[/IMG]
[/IMG]
[/IMG]
timebombswrx is offline   Reply With Quote
Enough of teh Sex threads! Remy E. LeBeau Off-Topic 18 08-19-2013 07:47 PM
teh burn thread Samuelleeogden Off-Topic 13 09-06-2005 08:28 PM
Teh Welcoming Thread.. PwNeD Texas Impreza Club Forum -- TXIC 7 10-06-2004 10:42 AM
