View Poll Results: Which Color do you like?
Gold 286 27.61%
Hyper Silver 136 13.13%
Chronium Black (gunmetal'ish) 355 34.27%
Flat black 229 22.10%
Bronze 137 13.22%
Multiple Choice Poll. Voters: 1036. You may not vote on this poll
Old 07-24-2012, 12:16 AM   #4726
slowsti15
Member#: 308358
18x9.75 225/40/18 camber 3.5 rear front cant remember
slowsti15 is offline   Reply With Quote
Old 07-24-2012, 09:03 AM   #4727
sohchx
Member#: 213634
2002 Impreza
Originally Posted by SubieChik View Post
Nope....VA's garbage highways did. A truck hit a pot hole and kicked up a piece of the highway (about the size of a brick) and I ran right into it. Ni didn't see it....my husband did....but it was too late. Now I don't know what to do....
Did you ever get a replacement wheel? If not check with these guys on Ebay,they always have stock.
http://www.ebay.com/sch/motostartire...&_trksid=p3686
sohchx is offline   Reply With Quote
Old 07-24-2012, 01:56 PM   #4728
Outback257
Member#: 326898
2005 Outback XT
XXR 530 18x8.75 +35 on 255/40/18
Outback257 is offline   Reply With Quote
Old 07-24-2012, 02:24 PM   #4729
Pidgeon
Member#: 284247
2002 Wrx
MBP!
perfection
Pidgeon is offline   Reply With Quote
Old 07-24-2012, 08:11 PM   #4730
NineBreaker
Member#: 237756
2011 2.5i Sedan
^ ****!!! SOO in love!!
Fender mods and suspension?
NineBreaker is offline   Reply With Quote
Old 07-24-2012, 10:20 PM   #4731
Outback257
Member#: 326898
2005 Outback XT
Im on legacy spec Endura Tech coilovers. With whiteline rear camber bushings to bring the camber back out a smidge. The metal fenders were cut to make space for the 255s. As was the flat parts on the plastic flare.
Old 07-25-2012, 01:05 AM   #4732
jeffg
Member#: 2958
2001 WRX (GC8)
XXR 530 17x9.75 +20 - 255/40-17 Falkens
As you can see, the new shoes are slightly bigger than the old ones.
What do you think of them?
The front fenders are rapidly approaching paint time and I did a little flare with the existing fender in the rear to see if it will clear the new wheels.
I actually had to raise the car up to get them under in the rear. They stick out a bit too much so I may have to address that in some way.
Not too bad in the front.
Better pics to come.
jeffg is offline   Reply With Quote
Old 07-25-2012, 06:43 PM   #4733
NineBreaker
Member#: 237756
2011 2.5i Sedan
Good info. I plan on ditching the Impreza for an Outback soon.
Any more pictures?
Old 07-26-2012, 01:50 PM   #4734
IVIattIVIan
Member#: 295602
IVIattIVIan is offline   Reply With Quote
Old 07-26-2012, 02:24 PM   #4735
Outback257
Member#: 326898
2005 Outback XT
Any more pictures?
I dont anymore at the moment. Ill get more soon.
Old 07-26-2012, 06:46 PM   #4736
Chagie_WRX
Member#: 290752
2008 STAGE 2 REX
SSM
Preview!
Chagie_WRX is offline   Reply With Quote
Old 07-26-2012, 08:23 PM   #4737
chosen one
Member#: 273532
'08 Sti
^very nice!
quick update
chosen one is offline   Reply With Quote
Old 07-27-2012, 12:20 AM   #4738
NineBreaker
Member#: 237756
2011 2.5i Sedan
^ Mexipoke.
Old 07-27-2012, 08:28 AM   #4739
Chagie_WRX
Member#: 290752
2008 STAGE 2 REX
SSM
Thank you and same to you.
Old 07-27-2012, 11:33 AM   #4740
LorenzoBayuga
Member#: 316096
2007 WRX
Hey guys, I know this has probably been asked countless times before, but I'd appreciate the help. I'm looking to get some 527's in a wide, aggressive setup, but would the 18x9.75's have too much poke for someone that's just on Tein S-Tech's at the moment? I plan on getting coilovers with camber plates a little later to go lower and have camber adjustment options, but as of right now I'm trying to decide between 9.75 +20 or 8.75 +20. Thanks for the help guys.
LorenzoBayuga is offline   Reply With Quote
Old 07-27-2012, 01:11 PM   #4741
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
#1 you'll look retarded with just lowering springs and 9.75 plus u won't get enough camber..mexi poke like a mofo
#2 it's best with coils but since you're just on springs i'd recommend 8.75 +35 if you don't want much work.. (at least slightly rolled rears and u should be okay)
blakkboxer is offline   Reply With Quote
Old 07-27-2012, 01:22 PM   #4742
aeion
Member#: 182114
1996 Nissan HARDbody
1931 Ford Model A
This man speaks the truf
aeion is offline   Reply With Quote
Old 07-27-2012, 01:45 PM   #4743
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
If you're going for fitment and haven't done this before it's actually A LOT of work to make the wheels fit...stretched tires, pulled & rolled fenders (flat roll), camber and of course alignment every time you lower or raise the vehicle
Old 07-27-2012, 02:23 PM   #4744
aeion
Member#: 182114
1931 Ford Model A
Preach it brotha!! Trust us, we're doctors
Old 07-27-2012, 02:26 PM   #4745
chosen one
Member#: 273532
'08 Sti
Amen, I'm still working on mine.
Old 07-27-2012, 03:11 PM   #4746
LorenzoBayuga
Member#: 316096
2007 WRX
Thanks guys I really appreciate all of the help. I think I'll take your advice and go with the 8.75's. I was worried about having some mexi poke haha. I do plan on getting coilovers later on like I said but I'm sure 8.75's will still look good dropped on coilovers right? I will definitely roll fenders and pull if needed. Another question, what's the difference between a flat roll and just a roll? I rolled fenders on a BMW 325i before but I don't know if it's any different on the subies. Thanks again guys
Old 07-27-2012, 05:32 PM   #4747
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
It's for tire clearance. The flatter the better
It depends on your height..I did a slight roll in the rear but my ride height is directly above the tire tread so the fender was actually rubbing and cutting/killing the sidewall of the tire...then I finally flat rolled it which fixed most of it but still rubs only on hard dips. I could add some camber bolts to fix it since my megans doesn't have rear camber plates (I'm already on -2.3 just from the drop alone) OR just run a tad bit smaller tire like a 235/40 (I'm on 245/40's)
Old 07-27-2012, 09:05 PM   #4748
SLIC VIC
Member#: 187428
2006 WRX Limited
Originally Posted by chosen one View Post
^very nice!
quick update
enough clearance for a thick credit card? try again
SLIC VIC is offline   Reply With Quote
Old 07-27-2012, 10:00 PM   #4749
ravenlunatic
Member#: 180601
2003 PSM WRX
(>")>==HADOKEN==<(o)
love the grenade cap!
ravenlunatic is offline   Reply With Quote
Old 07-27-2012, 10:27 PM   #4750
Ed05WRX
Member#: 319401
05 WRX
WR BLue
What's your wheels set up?
Ed05WRX is offline   Reply With Quote
Enough of teh Sex threads! Remy E. LeBeau Off-Topic 18 08-19-2013 07:47 PM
teh burn thread Samuelleeogden Off-Topic 13 09-06-2005 08:28 PM
Teh Welcoming Thread.. PwNeD Texas Impreza Club Forum -- TXIC 7 10-06-2004 10:42 AM
