View Poll Results: Which Color do you like?
Gold 209 26.76%
Hyper Silver 99 12.68%
Chronium Black (gunmetal'ish) 264 33.80%
Flat black 188 24.07%
Bronze 102 13.06%
Multiple Choice Poll. Voters: 781. You may not vote on this poll
Old 08-08-2012, 07:42 PM   #4826
The Tall Man
Member#: 316804
2012 WRX - Stage 2
Originally Posted by SLIC VIC View Post
what if the tire sizes are the same all around?
This may work, but you could end up going through some costly trial and error by trying to create identical diameters. However, you are allowed to be off no more than 2/32's or 1/16th in diameter heights. This is why the TPMS is so important. You don't want to be driving around on a low preasure tire for a long period of time due to it's different tire height.
As I've stated before, I'm running some XXR 518 18x8.5 +48's with H&R 25mm spacers (only) in the rear wrapped in some Hankook Ventus V12 255/35-18's. I'm on stock suspension but rolled in the rear and have no rubbing.
As others have stated, you can run the same width wheels with different offsets. Example: 527's - 18x8.75 +20 (rear) 18x8.75 +35 (front). Keep in mind that you may have to roll, pull, adjust camber or do all depending on suspension, wheel and tire size.
The Tall Man is offline   Reply With Quote
Old 08-09-2012, 01:20 PM   #4827
Pidgeon
Member#: 284247
2002 Wrx
MBP!
Even if they have all the same tire size... but the wheels are different. It would still ruin your car. Awd. All wheel drive ....all at the same time... if the rears take longer to turn then the front that's when you tranny goes boom.
Pidgeon is online now   Reply With Quote
Old 08-09-2012, 08:34 PM   #4828
SLIC VIC
Member#: 187428
2006 STi
^what does the width of the wheel have to do with the outside diameter? ps: my boy has 9s up front and 10.5 out rear on his audi s4, i believe it is All Wheel Drive....all at the same time.. i could be wrong
SLIC VIC is offline   Reply With Quote
Old 08-09-2012, 09:14 PM   #4829
Asubie
Member#: 275582
2011 WRX
Asubie is offline   Reply With Quote
Old 08-09-2012, 09:30 PM   #4830
blessthekellen
Member#: 273859
MY98
WRX
I was never a fan of the 530's until your car.
That looks so perfect Asubie.
blessthekellen is offline   Reply With Quote
Old 08-09-2012, 09:43 PM   #4831
blakkboxer
Member#: 167244
2k3 WRX MBP
black & gold is pimpin'
uhhh where's the higher res pix at asubie?
blakkboxer is offline   Reply With Quote
Old 08-10-2012, 12:29 AM   #4832
colin05wrx
Member#: 284818
2005 Impreza WRX
colin05wrx is offline   Reply With Quote
Old 08-10-2012, 12:52 AM   #4833
dboywrx05
Member#: 291083
2005 wrx
blue
That car is what made me in love with 530s!
dboywrx05 is offline   Reply With Quote
Old 08-10-2012, 03:01 PM   #4834
USAFSTI
Member#: 224720
2005 Impreza WRX STI
Well done sir!
USAFSTI is offline   Reply With Quote
Old 08-10-2012, 03:06 PM   #4835
Nukem
Member#: 303705
Asubie what are your specs??? Fender rolled?
Nukem is offline   Reply With Quote
Old 08-10-2012, 03:10 PM   #4836
Asubie
Member#: 275582
2011 WRX
I don't like swag jakers lol there 18x9.75 +20 fenders rolled
Old 08-10-2012, 03:13 PM   #4837
Nukem
Member#: 303705
Ha I'm not going to swag jack I just like the stance set up :P
Old 08-10-2012, 07:12 PM   #4838
Asubie
Member#: 275582
2011 WRX
Lol no problem...
Old 08-10-2012, 11:40 PM   #4839
The Tall Man
Member#: 316804
2012 WRX - Stage 2
Old 08-11-2012, 12:54 AM   #4840
JeffrWRX
Member#: 48589
2006 SGM STi VF39
EWG/EBCS/Phatron Tuned
Several tracked cars have run wider wheels up front with same tires all around and claimed it helped with understeer. The diameters are the same all around.
Found this, "When running wider front wheels, you are suppost to use the exact same sized tires front and rear. The idea behind running a slightly wider rim width in the front, but the same tires all around is that the sidewall will be stiffer on the front tires. The stiffer rounder front sidewall will help with turn in while the rear will give a little more easily to help balance the car during cornering. Japanese tuners have been using this trick on Evo's and STi's for years. The Cusco STi is a rolling catalog so the wheel thing is just an extra little touch. I also don't think that a two pound difference per wheel in the front is gonna wreak much havoc on the Cusco diffs. Stock diffs might be a different story."
I don't think it was smart for the guy above to run that staggered setup but its not completely a no-no if done right.
JeffrWRX is offline   Reply With Quote
Old 08-11-2012, 08:43 AM   #4841
dumlao76
Member#: 324580
Originally Posted by AsILayDying View Post
yeah they def are not 527's. pretty close in looks but the 527's dont curve at the outer edge of the wheel.
Anyone one want to buy some XXR 522's 18x8.5 48 offset in Chromium black, really want some gold 527's.... :-(
Whats the price?.could you send me a pics of the wheels?.heres my # 631605zerosixfivetwo
dumlao76 is offline   Reply With Quote
Old 08-11-2012, 09:37 AM   #4842
aeion
Member#: 182114
1996 Nissan HARDbody
1931 Ford Model A
Please take that to PM's. Also, how old is that post?
aeion is online now   Reply With Quote
Old 08-11-2012, 05:29 PM   #4843
Pidgeon
Member#: 284247
2002 Wrx
MBP!
This is basically what I'm saying. IMHO I would never ever run two different wheels on an awd car.. Cusco's car is built out or mordor steel so I'm sure "their" car is fine. I'm over cluttering this already downhill thread so lets just leave it at that.
Old 08-13-2012, 05:02 AM   #4844
davidsti1
Member#: 210923
2004 sti aspen white
on my way to e85 army wii
Anyone have fender flares with 18x9.75 xxr's?
I have the karlton flares and don't know
If these wheels will be wide enough :/
davidsti1 is offline   Reply With Quote
Old 08-13-2012, 01:10 PM   #4845
Pidgeon
Member#: 284247
2002 Wrx
MBP!
They are wide enough but I suggest the +20 offset with the flares... you want it to be flush correct? Or inside the flare ...
Old 08-13-2012, 01:44 PM   #4846
davidsti1
Member#: 210923
hey...i want them to be normal look flush or in flare...
i might add hub sentric spacer
Old 08-13-2012, 03:02 PM   #4847
elementality809
Member#: 234898
2007 STi Limited UGM
EFI tuned | 291awhp
My 2007 STi lowered on coilovers
Wheels - XXR 527 17x8.25 +35
Tires - Yokohama S-drives 245/40/17
Iphone pic
elementality809 is offline   Reply With Quote
Old 08-13-2012, 03:36 PM   #4848
Pidgeon
Member#: 284247
2002 Wrx
MBP!
Get the +20 if they are not wide enough .... replace the studs with extended studs and get spacers accordingly
Old 08-13-2012, 04:04 PM   #4849
davidsti1
Member#: 210923
Awesome tanks
Already have the arp studs
Old 08-13-2012, 05:05 PM   #4850
davidsti1
Member#: 210923
Awesome tanks
teh burn thread Samuelleeogden Off-Topic 13 09-06-2005 08:28 PM
Teh Welcoming Thread.. PwNeD Texas Impreza Club Forum -- TXIC 7 10-06-2004 10:42 AM
Enough of teh Sex threads! Remy E. LeBeau Off-Topic 17 09-10-2003 01:56 PM
Message Board Statistics All times are GMT -4. The time now is 05:10 PM.
