Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
View Poll Results: Which Color do you like?
Gold 285 27.72%
Hyper Silver 136 13.23%
Chronium Black (gunmetal'ish) 352 34.24%
Flat black 228 22.18%
Bronze 134 13.04%
Multiple Choice Poll. Voters: 1028. You may not vote on this poll
Old 06-26-2013, 09:01 AM   #6651
dsoob
Member#: 181069
'15 WRX
Lightning Red
Anybody running 9.75" +20's on a GR I have a question. My front fender liner is rubbing the tires like crazy did you guys cut or remove this at all? I need to get an alignment still but I don't think that'll help much. Thanks in advance for the info.
dsoob is offline   Reply With Quote
Old 06-26-2013, 09:13 AM   #6652
sc00by4life
Member#: 97135
Originally Posted by fiftysevenpercent View Post
They're both cheap ****. Doesn't change the fact that both make nice looking affordable wheels. Soooo back on subject.
whatever you gotta say to convince yourself.
Old 06-26-2013, 01:01 PM   #6653
NWsoobie
Member#: 289516
2012 WRX
ISM
Circle cut the top. Those are the beautiful struggles of the lowlife. Check where it's rubbing and cut it out.
NWsoobie is offline   Reply With Quote
Old 06-26-2013, 01:20 PM   #6654
fiftysevenpercent
Member#: 104707
2002 WRX Sedan WRB
2011 STi Hatch SWP
Convince myself of what exactly?
fiftysevenpercent is offline   Reply With Quote
Old 06-26-2013, 02:28 PM   #6655
SubieSnacks02
Member#: 323545
Old Racekorrrrr!
Multi
It rubs (the lining) on my right fender on my GD. I cut it sort of, but I just let the tire rub and eat it up. I need smaller tires, I got 225/45 on 18x8.75 +35 xxr 527.. Other then that I rub over bumps and cornering
SubieSnacks02 is offline   Reply With Quote
Old 06-26-2013, 02:31 PM   #6656
Soobie4life
Member#: 337830
My rear rubs.. The front doesn't though.
Soobie4life is offline   Reply With Quote
Old 06-26-2013, 03:23 PM   #6657
chosen one
Member#: 273532
'08 Wrx
wrb
chosen one is offline   Reply With Quote
Old 06-26-2013, 03:40 PM   #6658
Soobie4life
Member#: 337830
How do you not rub in the rear? I got tein coils and I rub.
Old 06-26-2013, 03:43 PM   #6659
skatin707
Member#: 251552
Chapter/Region: HIIC
2014 FXT
Satin White Pearl
Drive VERY slow.
skatin707 is offline   Reply With Quote
Old 06-26-2013, 05:02 PM   #6660
Soobie4life
Member#: 337830
Hahahah that works!
Old 06-26-2013, 05:26 PM   #6661
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
I've got my coils as stiff as possible in the back. I still rub a bit though. I'm only running a 17x9 +30 though.
Old 06-26-2013, 05:36 PM   #6662
Soobie4life
Member#: 337830
Yeah I got 18's and 9.75's... Is it even possible to not rub?
Old 06-26-2013, 05:55 PM   #6663
mr.phil.roxass
Member#: 223470
2005 PSM wrx impreza
eckk.
^ yah go with a wider rim..lol i used to rock the xxr 527 in 18 X 9.75 and i rubbed more with the xxr then i have now which is 18 x 10 +25 and i dont rub that much or at all..and im almost maxed out camber in the back and on coils maxxed out on my stiffness..my tires are 225/40/18
mr.phil.roxass is offline   Reply With Quote
Old 06-26-2013, 06:10 PM   #6664
Soobie4life
Member#: 337830
Wait so what are you saying? Do you have rear camber plates?
Old 06-26-2013, 07:10 PM   #6665
dsoob
Member#: 181069
'15 WRX
Lightning Red
I don't really rub in the rear that I can notice. On bc coils with pretty hard dampening. But the front rubs a lot. I'm gonna cut out some of the liner tomorrow.
Old 06-26-2013, 07:58 PM   #6666
SubieSnacks02
Member#: 323545
Old Racekorrrrr!
Multi
I have Raceland coils (needed something quick after my accident) my springs are stifffff and I rub like bananas, especially front is lowered ish and back is raised.. So stupid lol
Old 06-26-2013, 07:59 PM   #6667
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
Go with a wider rim to not rub? Am I reading that correctly?
Edit: I finally lowered my front end another inch. Man it looks so much better to have zero gap. I don't know why it took so long.
Old 06-26-2013, 08:44 PM   #6668
Soobie4life
Member#: 337830
That's my front and rear right now.
The front doesn't rub at all, it's cambered and lowered to the maximum.
The rear rubs on bumps when I'm alone, but with multiple people it rubs even when I'm cruising at 25.
Old 06-26-2013, 09:28 PM   #6669
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
I'm setup about the same as you and have the same rubbing issues. It's not bad at all really.
If I worked my fenders I'd be fine.
Old 06-26-2013, 09:39 PM   #6670
Soobie4life
Member#: 337830
I rolled and pulled all four fender like crazy!
Old 06-26-2013, 09:47 PM   #6671
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
My fenders aren't touched. Healthy camber and a decent wheel/tire size is an easy fit.
Old 06-26-2013, 09:58 PM   #6672
Soobie4life
Member#: 337830
I got camber plates for the front only. Should I get some for the rear? I only got camber bolts for the rear.
Old 06-26-2013, 10:13 PM   #6673
dsoob
Member#: 181069
'15 WRX
Lightning Red
I guess you guys are different than the GR and my rear is more of a wider body so the rear is perfect with a flat roll. The front I did a slight roll but I think I need to camber more with the bolts.
Old 06-26-2013, 10:22 PM   #6674
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
Yes, it makes life a lot easier. I can only get so much camber from the bolts before I start to rub the strut. With plates I can get another 2 degrees.
It's an obvious difference. The GR accepts MUCH wider wheels than any previous model.
That, and 04-07 STI rear fenders SUCK for rolling. I'm not looking forward to grinding mine.
Old 06-26-2013, 10:28 PM   #6675
SubieSnacks02
Member#: 323545
Old Racekorrrrr!
Multi
^ Ahhhh! Before my paint I should grind my rear
Enough of teh Sex threads! Remy E. LeBeau Off-Topic 18 08-19-2013 08:47 PM
teh burn thread Samuelleeogden Off-Topic 13 09-06-2005 09:28 PM
Teh Welcoming Thread.. PwNeD Texas Impreza Club Forum -- TXIC 7 10-06-2004 11:42 AM
