View Poll Results: Which Color do you like?
Gold 285 27.56%
Hyper Silver 136 13.15%
Chronium Black (gunmetal'ish) 355 34.33%
Flat black 229 22.15%
Bronze 136 13.15%
Multiple Choice Poll. Voters: 1034. You may not vote on this poll
Old 01-10-2012, 06:36 PM   #2301
sc00by4life
Member#: 97135
Originally Posted by BullyWRX
Yes they are, but it's not like they just put wider fenders and called it a day! The suspension actually got pushed out a little bit as well. It's all relative.
No it didn't......
If anything, it got moved inboard. They have more inboard AND outboard clearance than the GD/GH chassis.
Old 01-10-2012, 06:50 PM   #2302
yo14jman
Member#: 138229
2006 STI
Originally Posted by USAFSTI View Post
Post up some closer pics im looking at that setup but in chromium black.
it's dark so tomorrow i will. I don't rub in the rear at all. I don't have passengers in the back ever though...
yo14jman is offline   Reply With Quote
Old 01-10-2012, 07:26 PM   #2303
BullyWRX
Member#: 258756
2011 WRX
Originally Posted by sc00by4life View Post
No it didn't......
You certainly aren't trying to compare the track width of a GD to that of a GH are you? 2 totally different animals. How can you begin to say that they moved the hubs, more inboard, and result in a 1.5 inch wider track on the 2011's over the '08-'10 models? The wheels have the same backspacing on them, and they're only 1" wider than the '08-'10's. which can equate to about half an inch on either side of the wheel. .5"x2=1" for both wheels in track width difference. Still leaving .5" unaccounted for. Where did that come from? Witchcraft?
BullyWRX is offline   Reply With Quote
Old 01-10-2012, 07:44 PM   #2304
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
COBB Stg3 336whp/370wtq
Originally Posted by 2010SlowHatch View Post
Thanks! How much is ur front rim poking out? I really like the rear fitment.
Front tire pokes out a little bit, but not too bad. Waiting on the RCE camber plates to be released next month.
My camber in the rear is -2.5
My camber up front is -1.8
Once I get the camber plates up front I should be able to dial in a little bit more negative camber and get it looking like it should.
QwaktastiK is offline   Reply With Quote
Old 01-10-2012, 07:49 PM   #2305
sc00by4life
Member#: 97135
I'm not comparing the GD and GH chassis, merely saying the GR has far more inboard AND outboard room than all previous models.
Explain how you can fit 18x9.5 +44 with 265's and no roll on a GD (you can't) like you can on a GR?
Explain how you can also fit 18x9.5 +44 with 265's on a GD with stock suspension (you can't) like you can on a GR?
I'm not saying they moved ANYTHING inboard, merely saying there is FAR more room on BOTH sides of the wheels than previous subaru models.
Your assertion of "its all the same/relative" is inaccurate, because its not.
Old 01-10-2012, 07:56 PM   #2306
BullyWRX
Member#: 258756
2011 WRX
If there's all this extra room everywhere between a 2010, and a 2011, then why do I have the exact same spec wheels on my 2011 sedan as Qwaktastik has on his 2010 hatch, and our fitment is almost identical? Since the person I was responding to is also in a 2010 hatch, it's a pretty fitting statement.
Old 01-10-2012, 07:57 PM   #2307
aeion
Member#: 182114
1996 Nissan HARDbody
1931 Ford Model A
Easy guys.....let's just try to focus on working with each other to try and get this guy the right info
aeion is offline   Reply With Quote
Old 01-10-2012, 08:01 PM   #2308
USAFSTI
Member#: 224720
2005 Impreza WRX STI
What about in the front? what you running for suspension?
USAFSTI is offline   Reply With Quote
Old 01-10-2012, 08:06 PM   #2309
BullyWRX
Member#: 258756
2011 WRX
Pics as promised Kitty, and for 2010Slow's reference as well. 17x8.25 +25 235/45-17 factory tires.
Old 01-10-2012, 08:06 PM   #2310
USAFSTI
Member#: 224720
With those 522 17x9 do you have to have the hub spacer?
Old 01-10-2012, 08:11 PM   #2311
yo14jman
Member#: 138229
2006 STI
No spacers. I'm running RCE Yellow Springs. That's it. No rubbing. But if you have people in the back you might rub in the rear. I never do so i'm ok. I can fit almost 3 fingers in the front well and 2 in the rear well.
Old 01-10-2012, 08:12 PM   #2312
sc00by4life
Member#: 97135
Look at his tire size. Look at yours.
Camber settings.
There is MUCH more involved with how a wheel looks on a certain car versus wheel specs.
I can clearly see a difference in where his wheel fits in relation ship to his fenders and yours. They might "appear" the same in pictures, but its not.
Old 01-10-2012, 08:17 PM   #2313
USAFSTI
Member#: 224720
I dont ever have people back there either got a harness bar back there for stiffness not to safe for peoples heads. Does anyone know if you need the center bore ring thing on these wheels?
Old 01-10-2012, 08:19 PM   #2314
BullyWRX
Member#: 258756
2011 WRX
Camber settings.
Tire size, etc will not affect the poke. Camber may a little bit at the top and bottom, but in this case, not enough to make more than a mm or 3 difference. The poke is almost the exact same. And again, if I had this massive amount of extra room over a 2010, then with the same wheel specs, he should have more poke than me by a long shot.
Old 01-10-2012, 08:19 PM   #2315
BullyWRX
Member#: 258756
2011 WRX
Hubcentric rings are recommended.
Old 01-10-2012, 08:22 PM   #2316
USAFSTI
Member#: 224720
What are the size I need for a 05 sti with these wheels?
Old 01-10-2012, 08:24 PM   #2317
BullyWRX
Member#: 258756
2011 WRX
Not too sure on that one bro. Are you ordering from NL? If so, just tell them you need the rings too, and they can get you squared away. I'm sure someone like El STi can get you squared away on the info though.
Old 01-10-2012, 08:29 PM   #2318
USAFSTI
Member#: 224720
No from discounttires.com
Old 01-10-2012, 08:35 PM   #2319
USAFSTI
Member#: 224720
Found it its 56.1mm to 73.1mm
Old 01-10-2012, 08:36 PM   #2320
BullyWRX
Member#: 258756
2011 WRX
A little searching goes a long way!
Old 01-10-2012, 08:39 PM   #2321
sc00by4life
Member#: 97135
tire size has EVERYTHING to do with how the wheel fits within the fender. The amount of "poke" will heavily depend on camber settings.
And no, the "poke" isn't the exact same. It just appears so .
I'm not saying theres a friggin 25mm difference. There is ENOUGH of a difference that you can....
run a 18x9.5 +44 and will clear STOCK GR suspension, AND run a 265/35 without rolling. You can't do that with the GH or previous chassis.
Old 01-10-2012, 08:42 PM   #2322
hansomm
Member#: 281290
Originally Posted by WhatisFunction View Post
in the weeds
hansomm is offline   Reply With Quote
Old 01-10-2012, 08:43 PM   #2323
BullyWRX
Member#: 258756
2011 WRX
like5
Old 01-10-2012, 09:09 PM   #2324
USAFSTI
Member#: 224720
Yup yup!
Old 01-10-2012, 09:17 PM   #2325
EL STi
Member#: 208377
2005 STi
i'm on 225/40/18 on my 05 w 527s.
EL STi is offline   Reply With Quote
Enough of teh Sex threads! Remy E. LeBeau Off-Topic 18 08-19-2013 07:47 PM
teh burn thread Samuelleeogden Off-Topic 13 09-06-2005 08:28 PM
Teh Welcoming Thread.. PwNeD Texas Impreza Club Forum -- TXIC 7 10-06-2004 10:42 AM
