Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 01-30-2011, 05:01 PM   #1
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Default What does slipping the clutch mean and why is it bad?
What does "slipping" the clutch refer to and why is it bad for your clutch? The comments on this video say this guy is slipping the clutch, is it just letting the clutch out too slow when shifting hard?
xabre1200 is offline   Reply With Quote
Old 01-30-2011, 05:04 PM   #2
usfsfire42
Member#: 242630
.. Flu shot
technician.
It is bad for it in the sense that it makes it wear out faster.
usfsfire42 is offline   Reply With Quote
Old 01-30-2011, 05:15 PM   #3
Howl
Member#: 57830
Yes - it means letting it out too slow or only letting it out part way. It means the clutch plates are rubbing against each other and are wearing quicker.
Howl is offline   Reply With Quote
Old 01-30-2011, 05:47 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
subarus need to be driven a bit differently than 2wd cars.....if you shift fast and dont slip the clutch.....and the wheels dont spin....guess what????
you blow the gear in the trans
it takes a good bit of finesse to drive a subaru without blowing the trans or wearing out the clutch
and the proof of this is in all the busted 5mt's and guys burning the factory clutch up in 30k or less miles
and then ya have the guys that get 120k+ outa the stock clutch--autoxing the car at stage 2+ every weekend and driving the car like they stole it...and never blow the trans
so....if ya dont spin the wheels or dont slip the clutch...ya blow the trans
the finesse is getting the proper mix...and that is where the kiddies screw the p00ch
Old 01-30-2011, 10:01 PM   #5
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Any tips on how you achieve this? Slip the clutch faster when you are driving aggressively?
Old 01-30-2011, 10:45 PM   #6
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
There's a difference between slipping your clutch and a slipping clutch.
A slipping clutch is a worn clutch in which your RPMs will jump/rise like your revving in neutral and your car won't accelerate at the same rate of RPM acceleration.
Slipping your clutch is, like what Uncle Scotty said, properly shifting your AWD car when shifting aggresively/launching (as opposed to "dumping" your clutch) so you don't pop your transmission.
Tips: Practice.
ThreeEleven is offline   Reply With Quote
Old 01-30-2011, 10:49 PM   #7
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
its a feel thing after you understand how the system mechanically works its all about understanding whats going on when your driving the car. and that takes lots of practice which is why scottie said "and that is where the kiddies screw the p00ch". i always think its funny when some new 16 year old kid comes to the track and thinks that hes going to beat that old man in his miata around the track. Now im only 18 but i know how the game goes
jdmboy is offline   Reply With Quote
Old 01-30-2011, 11:56 PM   #8
jxkim
Member#: 239150
2003 WRX Sedan
i.e. riding your clutch
jxkim is offline   Reply With Quote
Old 01-31-2011, 12:54 AM   #9
jdmsilverbugeye
Member#: 267945
Slipping the clutch may be bad for yur clutch but its better than blowing yur trans like mentioned above. Launching and shifting in an Awd is a bit diffrent than 2wd. It takes a little practice. If u smell clutch then u didnt let it out fast enough. If u feel a bang/jerk then u let it out too quick.
jdmsilverbugeye is offline   Reply With Quote
Old 01-31-2011, 01:02 AM   #10
jxkim
Member#: 239150
2003 WRX Sedan
Old 01-31-2011, 03:29 AM   #11
Shewillbemine
Member#: 84680
^^ lol
Shewillbemine is offline   Reply With Quote
Old 01-31-2011, 07:38 AM   #12
dnorton
Member#: 218997
07 WRX Mikey Tuned
JE/FSR built,35r 1300c
The video sounds like the clutch is slipping to me do to a bad clutch. Uncle Scotty hit the nail on the head. Another good point is a lot of guys will slip 1st when taking off from a dead start but slam 2nd. I have a 5 speed running 335/360 and it's the torque that's the reason I worry about launching to hard then slamming second. I've heard how second is the gear that will break with to much abuse. I wouldn't know how to slip second when your racing. I know how to launch from the line slipping the clutch but second I wouldn't have a clue how to slip.I don't speed shaft between gears just for the very reason I'm worried I'll break a gear. I slip first then let off just a little of gas between gears and make sure I have a good gear set before letting out the clutch. I know it takes a little more time but I'd rather take a little more time then pay for a rebuilt trans.
dnorton is offline   Reply With Quote
Old 01-31-2011, 01:05 PM   #13
pahaekachilles
Member#: 258632
2011 WRX
Slipped the clutch this morning and spun all 4 without any burnt smell from the clutch. Guess ive been doing it right this whole time and didnt even know
pahaekachilles is offline   Reply With Quote
Old 01-31-2011, 08:56 PM   #14
dnorton
Member#: 218997
07 WRX Mikey Tuned
Sounds like it just be careful with 2nd gear or any of them with a missed shift.
Old 02-01-2011, 12:11 AM   #15
775sti
Member#: 272464
When he slips the clutch, he is letting it out slowly while giving it gas. In the end wearing it faster!
775sti is offline   Reply With Quote
Old 02-01-2011, 07:20 AM   #16
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
If you slip the clutch correctly you won't wear it out faster. Slipping it to much then your "burning" it and yes it will wear it out quicker. Got to find that middle part.
Just because it didn't have a burning smell doesn't mean you were doing it right. But on snow days like we have had if you shift quick(more than what you should) because the ground is slippery you will cause the tires to spin which again doesn't cause damage. However if you did it on warm tarmac might be a different story.
+1 for Uncle Scotty. Man knows what he is talking about and couldn't have said it myself. When I did my 6spd swap my stock 5mt clutch looked brand new with 33k miles even with some autox days, "snow parking lot days", +stage2 power, etc. Again that is due to find that balance between spinning wheels, breaking tranny and burning the clutch for no reason. I will add to uncle scotty remarks a method to finding a good shift(think this goes for any vehicle but harder on subarus(actually awd in general)) Is when you shift you don't feel it at all. The car doesnt jerk the slightest bit. Its not easy and takes lots of practice and can be done at WOT or at grandma speed and anything inbetween.
talvai is offline   Reply With Quote
Old 02-01-2011, 09:43 AM   #17
ScoobieNoob
Member#: 267079
2011 WRX HB
So how do you achieve a proper shift @ the dragstrip while going for the fastest time possible?
Lets say you are going down the track at WOT and you hit your target shift RPM. Does it go something like this?
- Let off throttle completely
- Mash clutch (fast as possible)
- Shift gear (fast as possible)
- Let off clutch, feather slightly throughout engagement point so as your clutch deliberately slips a little, allowing a smooth(er) transition to the next gear, while simultaneously giving it some gas
- After shift is completed, increase throttle to WOT (fast as possible)
- Repeat.
ScoobieNoob is offline   Reply With Quote
Old 02-01-2011, 09:51 AM   #18
ericsson
Member#: 208672
2013 WRX STI Limited
Obsidian Black
If this is your first subby, maybe you should enjoy the car for a year or two before you start slipping clutches
ericsson is offline   Reply With Quote
Old 02-02-2011, 02:20 PM   #19
dnorton
Member#: 218997
07 WRX Mikey Tuned
If it was me I'd do something like you described instead of not letting off the gas and slamming it in gear. As long as your on the track and your trying to set a constant time then there shouldn't be a problem letting off a little and making sure it's in the next gear good and tight. Of course everyone has there own opinion how to do it and I think it's good you are trying to ask the guys who do this everyday so to figure out the right way so you don't hurt your trans.The down side is if your running a 5 speed you are taking a chance of busting a gear anytime you do hole shots plus slamming into the next gear and the higher the TQ you have the more of a chance it could happen. This is my 2 cents not from someone who does it every day.
What the hell is wheatgrass, and why is it so expensive? plunk10 Off-Topic 16 03-27-2008 10:15 PM
What is this in my fuel return line, and why is it there...argg munkis Normally Aspirated with bolt-on Forced Induction Powertrain 5 07-19-2004 07:21 PM
whats with this Intel Centrino thing and why is it so expensive? GooseMan Off-Topic 12 11-21-2003 03:27 PM
What is this connector, and why is it unplugged?? Kwyjibo Electrical & Lighting 7 09-24-2003 01:21 AM
What hose is this, and why is it coming loose? CirrusWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-11-2002 02:32 PM
