Old 01-31-2011, 11:13 PM   #1
Jake_S
Member#: 556
1999 BG9 Outback
Legacy 99 LOB. How to tell which valve cover is on the engine?
I have a 99 Legacy Outback that I have to change out the head gaskets. I am stalled until I can determine the type of valve cover is on the engine. I looked tonight and was not able to see any numbers stamped into the valve cover itself. So, ho do you determine of you have a 13264-AA190 (RH)/13278-AA170 (LH) cover or the 13264-AA160(RH)/13278-AA140 (LH) covers?
Thanks
Jake
Jake_S is offline   Reply With Quote
Old 01-31-2011, 11:19 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Why do you need to know about the valve cover? If you give a dealer your VIN, they can tell you.
Old 02-01-2011, 12:01 AM   #3
Jake_S
Member#: 556
1999 BG9 Outback
I do not have a decent dealer around me, and the covers require the correct gasket. I do not want to order a head gasket set and find out that the valve cover gaskets are wrong.
So, does anyone know the answer?
Jake
Old 02-01-2011, 12:46 AM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
The engine reseal kit will have both type of cover seals. The difference will most likely be the spark plug opening shape if we're talking about the early and late style DOHC heads.
Jay
Old 02-01-2011, 09:39 AM   #5
Jake_S
Member#: 556
1999 BG9 Outback
Storm, thanks for the info.
Jake
How does the Airboy Spreadsheet Compare to the Virtual Dyno Software? xluben Proven Power Bragging 277 06-25-2012 02:47 AM
How large of an amp will fit under the seat? phenryiv1 Car Audio, Video & Security 24 02-03-2011 11:17 AM
Jon Stewart is still The Man motorpotor Off-Topic 31 02-02-2011 07:56 PM
Which one of you is this? spaceywilly Rocky Mountains Impreza Club Forum -- RMIC 12 02-01-2011 06:30 PM
Newbee Trader on the way! CDF Racing Newbies & FAQs 7 01-31-2011 02:51 PM
