Old 02-01-2011, 12:47 PM   #1
ydeardorff
Member#: 269164
Default Noob help needed Mixing 03 wiring with an 05 motor
Hello All,
First of all I must say this is the best collection of data Ive found yet on Subaru's.
However in my last couple of week of searching, Ive come up with zilch as far as the info I need. Every similar question asked, that I have found, seemed to be asked and no one responds.
I have a VW based kit car called a Sterling.
I just bought and am waiting for my 05 WRX 2.0 turbo engine (from a wagon)to arrive via a freight carrier.
I have the ability to buy an entire wrecked 03 WRX impreza with no engine or trans (it had the same engine but was an 03 model), that I can rob all the electrical and fuel systems out of.
So I will be using the entire electrical system out the car and placing it in my car. So my car will be electrically (including the ECU) an 03 model, using every plug, relay, fuse, and connector from the donor car.
I will be using a shortened Subaru AWD manual transaxle (with flipped internals) and be mated up to the 05 engine.
I know it would be preferred to use 05/05, or 04/05 parts, but this is what has landed on my door step for a good price. I cant knock the opportunity here.
Can anyone help me lay out my to do list to get this engine to run normally in my car? Im only worried about getting the electrical to work properly. I will be using a motorcycle gauges cluster that is a stand alone unit (not requiring any computer to run it), and an 05 mini cooper steering column. So this iwill be somewhat of a frankenstein application. I only need the info for mating the suby parts. So basic question is, will an 05 wrx motor work in a 03 wrx using the 03 wiring and ECU?
I know there is about 1000 years of subaru knowledge in the site, Im hoping to tap into just a portion of it.
Thank you for taking the time to read this.
yaughn
ydeardorff is offline   Reply With Quote
Cable driven Impreza cluster parts, gauges, mix and match STi_v4_Wagon 1993 - 2001 Impreza Specific Parts 6 07-20-2007 12:13 AM
Mix and match tires for AX : help me not bork the center diff.. crystalhelix Motorsports 35 02-02-2007 09:56 AM
Need help mixing and matching exhaust components MyFirstDeuce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-22-2006 11:18 PM
Help Me Mix And Match!! Struts travisd13 Brakes, Steering & Suspension 12 10-11-2005 10:33 AM
Mix and Match OEM and CWest Bodykit fukamoto Interior & Exterior Modification 3 06-16-2002 03:39 AM
