Old 02-01-2011, 05:51 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default Crankshaft position sensor after 99k miles... picture
Spent 30 min. replacing crankshaft position sensor due to bogging/jerking problem.
Make sure to check your sensor.
Old 02-01-2011, 05:57 PM   #2
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
Mine went and I needed my car right away so dealer did it for $250 in one day. I knew I should have done it myself.
Ernest is offline   Reply With Quote
Old 02-01-2011, 05:59 PM   #3
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Replacement sensor cost me $28 from advance auto part (made in Poland). I had to remove the alternator because I didn't have right tool to remove 10mm bolt without removing it.
Old 02-01-2011, 06:06 PM   #4
Ernest
Member#: 45076
I knew I got ripped, but it went when my other car was in the shop for something else. I had two cars down, so I just limped to the dealer and let them do it.
The crazy thing is the two days befor I was upstate in the lower adirondacks and searching for fishing spots on old logging trails and stuff. Thank god it did not go there, no cell service in the middle of nowhere would have sucked.
Old 02-01-2011, 06:07 PM   #5
shibby2821
Member#: 229778
04 WRX
WR blue
did it throw a code?
shibby2821 is offline   Reply With Quote
Old 02-01-2011, 06:30 PM   #6
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Surprisingly, it did not throw a code.
In comparison, crank position sensor w/ over 110k miles looked really clean on my Matrix.
Old 02-02-2011, 11:07 AM   #7
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Update: bogging/jerking is gone.
Old 02-02-2011, 11:13 AM   #8
MCFARAM
Member#: 189453
2002 WRX Wagon
This is good to know. If you didnt have a CEL, what pointed you in this direction?
MCFARAM is offline   Reply With Quote
Old 02-02-2011, 11:18 AM   #9
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
My past experience with Crankshaft position sensor. Had similar bogging/jerking issue when sensor connection came off loose.
Old 02-02-2011, 12:02 PM   #10
Gutless
Member#: 266027
03 WRX Wagon
just for my future reference, can you pin-point the sensor location. Tnx
Gutless is offline   Reply With Quote
Old 02-02-2011, 12:12 PM   #11
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
sure - it's located right under the alternator.
Old 02-02-2011, 12:17 PM   #12
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
what point did you have the bogging/jerking? was it in low rpm at tip in?
How did you determine it was your crank position sensor vs your IACV?
fastnoypi is offline   Reply With Quote
Old 02-02-2011, 12:21 PM   #13
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I had recent completely disassembled IACV for cleaning, so I knew it cannot be IACV. Also, I had inspected many gaskets recently while troubleshooting vacuum leaks (exhaust manifold, uppipe, TMIC, turbo inlet, intake manifold, etc). Bogging/jerking could be felt randomly mostly at low RPM; I never beat on the car ever since car developed this problem.
Old 03-19-2011, 11:51 AM   #14
stikboy9
Member#: 85019
MY02 & MY04 Turbo'd
Money Pits
How difficult was it to get the actual sensor out? Mine seems to have quite a bit of resistance and I'm concerned about breaking it.
stikboy9 is offline   Reply With Quote
Old 03-19-2011, 12:28 PM   #15
rick-l
Member#: 33868
2003 wrx
srp
Was that dirt on there magnetic?
The sensor is just a magnet and a coil of wire right?
When you say resistance... what does it read?
rick-l is offline   Reply With Quote
Old 03-19-2011, 12:35 PM   #16
stikboy9
Member#: 85019
MY02 & MY04 Turbo'd
Money Pits
I meant putting up resistance to removal. I can spin it around, but I can't pull it out.
Old 03-19-2011, 12:46 PM   #17
rick-l
Member#: 33868
2003 wrx
srp
OK
I guess when you bust it up getting it out you can answer the other questions.
Old 03-19-2011, 12:52 PM   #18
stikboy9
Member#: 85019
MY02 & MY04 Turbo'd
Money Pits
OK
Thanks.
That's kinda what I'm trying to avoid. Should it be difficult to remove, or should it pop right out?
Old 03-19-2011, 12:56 PM   #19
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
It wasn't difficult to remove. It just popped out.
Old 03-19-2011, 01:01 PM   #20
stikboy9
Member#: 85019
MY02 & MY04 Turbo'd
Money Pits
That's what I thought. I've been pulling at it and it wont budge.
Old 03-19-2011, 01:48 PM   #21
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Did you try using PB blaster?
Old 03-19-2011, 02:09 PM   #22
stikboy9
Member#: 85019
MY02 & MY04 Turbo'd
Money Pits
No. I guess I could squirt some around it. I can twist it around with a little force, but I can't pull it out. Im paranoid about snapping it.
Old 03-20-2011, 07:39 PM   #23
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I would have just tried cleaning it first. Its just a mag pickup style sensor. Build up on the sensor will effect its performance.
kellygnsd is online now   Reply With Quote
Old 03-21-2011, 09:53 AM   #24
quazimoto
Member#: 70395
+1 No to to replace it unless you can verify it is bad. Just wipe the face and reinstall.
quazimoto is offline   Reply With Quote
Old 03-21-2011, 09:58 AM   #25
mneste8718
Member#: 51562
2004 WRX Sedan PSM
EJ205 [email protected] 300whp
where is the crank position sensor located?
mneste8718 is offline   Reply With Quote
Crankshaft Position Sensor, Air Intake Temp Sensor CODES!! please Help!! GT40R Engine Management & Tuning 2 07-05-2006 10:50 AM
Crankshaft Position Sensor Air Intake Temp Sensor CODES!! please Help!! GT40R Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-02-2006 05:07 PM
Crankshaft Position Sensor, Air Intake Temp Sensor CODES!! please Help!! GT40R Southern California Impreza Club Forum -- SCIC 2 07-01-2006 06:03 PM
Crankshaft position Sensor Malfunction Rossi Service & Maintenance 1 01-26-2004 01:19 PM
