Old 03-21-2011, 10:06 AM   #26
track43788
Member#: 164294
at least it was a quick fix!
track43788 is offline   Reply With Quote
Old 03-21-2011, 04:17 PM   #27
quazimoto
Member#: 70395
Originally Posted by mneste8718 View Post
where is the crank position sensor located?
http://forums.nasioc.com/forums/show...8&postcount=11
quazimoto is offline   Reply With Quote
Old 04-18-2011, 03:46 PM   #28
illmatic
Member#: 3536
2013 SWP BRZ Limited
2002/2003 AW/PSM WRX
I believe mine just died at ~160K. The car threw a P0336 while merging on the freeway.
illmatic is offline   Reply With Quote
Old 04-18-2011, 10:29 PM   #29
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Did you take it apart and visually inspect it? You might be able to just clean it off and reuse it.
Old 04-18-2011, 11:26 PM   #30
ojala
Member#: 255441
2005 Saab
First try cleaning it or check your battery. It is much more common to have a dirty sensor or a bum battery than to have a bad CPS.
ojala is offline   Reply With Quote
Old 04-19-2011, 09:20 AM   #31
rkramer
Member#: 118209
2002 WRX Sedan
Originally Posted by rick-l View Post
The sensor is just a magnet and a coil of wire right?
More or less, there are other parts also. But yes, there is a magnet.
http://en.wikipedia.org/wiki/Hall_effect_sensor
Old 04-19-2011, 10:11 AM   #32
rick-l
Member#: 33868
2003 wrx
srp
A hall effect sensor would require 3 wires Power,Ground and Signal. The wiring diagram only shows two.
I think these are typically variable reluctance sensors.
A quick search: http://www.linnbenton.edu/auto/scope/vary_reluct/
Note the magnet to attract ferrous materials. Shavings just on the end should not afffect operation much however, just if it bridged g=from the tip to the side.
rick-l is offline   Reply With Quote
Old 04-19-2011, 10:15 AM   #33
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
I once had a bucking / trailer-hitching issue at a specific engine speed, and once I cleaned the funky stuff off both the crank and cam position sensors, it went away. I'm guessing it was enough build-up to cause a slight "out of phase" condition, but not enough to throw a CEL.
NitroTrike is offline   Reply With Quote
Old 04-19-2011, 01:10 PM   #34
kellygnsd
Member#: 32669
2007 FR TS EFR 7670
LINK G4 hybrid STi
Actually any metal buildup on the end of the sensor can diminish the amplitude of the signal and with the stock ECU the threshold is preset. In short, any build up of ferrous material on a magnetic type sensor can effect its performance.
kellygnsd is online now   Reply With Quote
Old 04-19-2011, 01:49 PM   #35
rick-l
Member#: 33868
2003 wrx
srp
Yup you're right. Looking at a sensor again magnet, coil of wire around a iron rod and a iron piece to complete the magnetic path around the magnet except for a gap that gets filled by a gear tooth. Any ferrous material across the gap would diminish the flux change seen by the coil. Don't know what I was thinking.
Old 04-23-2011, 05:41 PM   #36
illmatic
Member#: 3536
I just replaced mine with a Borg Warner sensor from Pepboys for $24.99(CSS564 - Made in Japan) OEM Part number is 22055AA052 . There is enough space to remove the sensor with out completely removing the alternator.
The car has been sitting since last Thursday 4/14(from a P0336 CEL), so I'm charging the battery right now. First attempt the car did not start. What do you think caused the damage to the sensor, jumped timing belt, sprocket tooth? I think I'm going to pull the timing covers to inspect for more damage as soon as I have new oem parts.
FYI, I had my timing belt and water pump replaced at ~102K miles with the PCI kit on ebay.
Left OEM sensor at 160K. Right is the new BWD Sensor.
Old 04-24-2011, 12:35 AM   #37
NitroTrike
Member#: 62408
I would definitely check the cam belt / timing before even trying to crank it again. Something hit it. It almost looks like the belt hit it... did someone leave the crank belt guide off???
Old 04-24-2011, 08:27 AM   #38
jaxscuby
n00b Moderator
Member#: 10613
2002 USDM WRX
please spray clean your motors..
so we don't have to look at grime covered motors.
Old 05-11-2011, 05:19 PM   #39
Gutless
Member#: 266027
03 WRX Wagon
Originally Posted by stikboy9 View Post
I meant putting up resistance to removal. I can spin it around, but I can't pull it out.
stikboy, I have the same prob right now. Did u get it out eventually? How?
Gutless is offline   Reply With Quote
Old 05-11-2011, 06:03 PM   #40
rick-l
Member#: 33868
2003 wrx
srp
Why is the end of it deformed like that? That is probably why it won't come out.
Old 05-12-2011, 05:57 PM   #41
Jirv311
Member#: 273528
2002 Impreza WRX
Did you take out the bolt?
Jirv311 is offline   Reply With Quote
Old 05-12-2011, 06:00 PM   #42
Jirv311
Member#: 273528
2002 Impreza WRX
+14 to just try cleaning it first. Mine looked exactly like the OP's when I tore apart my motor and it just cleaned right off.
Old 05-16-2011, 10:16 PM   #43
Gutless
Member#: 266027
03 WRX Wagon
yup...i can spin it but it wont pop out. 'pb blasted, too....
Old 05-17-2011, 07:58 AM   #44
stikboy9
Member#: 85019
MY02 & MY04 Turbo'd
Money Pits
Nope. I had a limited amount of time to do a crap ton of stuff and haven't had a chance to mess with it since. I'll be revisiting it soon though. I'll post an update when I do.
stikboy9 is offline   Reply With Quote
Old 05-30-2011, 05:59 PM   #45
ezoq
Member#: 92685
2011 WRX,
00 2.5RS
Gutless, any luck on this ? I'm having the same problem on my 2.5...
ezoq is offline   Reply With Quote
Old 07-29-2011, 06:38 PM   #46
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Has anyone replaced cam shaft sensor? how did it look?
Old 07-29-2011, 11:00 PM   #47
bushman95
Member#: 248738
2004 wrx
red
I had the same problem with mine. 02 with 160k. Just spin in place but one come out.
bushman95 is offline   Reply With Quote
Old 08-03-2011, 12:56 PM   #48
bushman95
Member#: 248738
2004 wrx
red
I got mine out but it was difficult. I took off the alternator and pulled at it with pliers. Eventually I felt a pop and I had a pile of wires on the end of my pliers. The end of the sensor ripped out of the casing. So I took a fine screwdriver and folded in the edges of the casing slowly. Eventually I worked the whole casing down enough where it was loose and I pulled it out with pliers. Cleaned up the hole, slid the new sensor in and was on my way. Stressful but noting too complicated to get out.
Old 09-27-2011, 06:46 PM   #49
Dhendershot
Member#: 239405
1999 Impreza L
Default Crankshaft position sensor problems
i had the same problem with my camshaft postion sensor and my crankshaft position sensor. camshaft sensor was easy to remove, but crankshaft sensor i had to drill out of the hole. i made the hole a little wider on accident. i put in new crankshaft sensor and now the car doesn't even run. just turns over and misfires like crazy. can even get it to a garage now...
Dhendershot is offline   Reply With Quote
Old 09-28-2011, 12:06 PM   #50
kellygnsd
Member#: 32669
2007 FR TS EFR 7670
LINK G4 hybrid STi
Make sure you didn't damage the trigger wheel when you drilled out the sensor.
Crankshaft Position Sensor, Air Intake Temp Sensor CODES!! please Help!! GT40R Engine Management & Tuning 2 07-05-2006 10:50 AM
Crankshaft Position Sensor Air Intake Temp Sensor CODES!! please Help!! GT40R Factory 2.0L Turbo Powertrain 12 07-02-2006 05:07 PM
Crankshaft Position Sensor, Air Intake Temp Sensor CODES!! please Help!! GT40R Southern California Impreza Club Forum -- SCIC 2 07-01-2006 06:03 PM
Crankshaft position Sensor Malfunction Rossi Service & Maintenance 1 01-26-2004 01:19 PM
Message Board Statistics All times are GMT -4. The time now is 02:39 PM.
