Old 02-01-2011, 11:36 PM   #1
Wewocadet
Member#: 241865
2011 WRX Hatch
i have read supermoose and lachlans thread for jdm rhd swaps..very helpful but on supermooses thread he says
6. LHD AC condensor will NOT clear EJ20 radiator. i like having AC (live in texas)
also will my oem lhd shifter base fit with this center console?
i will do this on my 06 wrx ej25. my front clip has a/c lines/brake lines, brake booster, rack, dash everything. i was wondering if the a/c condenser will fit or if i will need a rhd one. thanks
also if anyone has any tips for me that would be awesome.
here are a few pics of the clip
Wewocadet is offline   Reply With Quote
Old 02-12-2011, 06:07 AM   #2
tad_07
Member#: 235873
wish I could help but keep us posted with pics & info you come across
tad_07 is offline   Reply With Quote
Old 02-12-2011, 09:56 AM   #3
ruckus racing
Member#: 196844
1997 Impreza L
flat black/green
those pics suck... need better ones please
ruckus racing is offline   Reply With Quote
Old 02-13-2011, 11:43 PM   #4
05subysti
Member#: 268190
2005 STi
damn im jealous, wish i could have a rhd clip with all the accesories
05subysti is offline   Reply With Quote
Old 10-25-2011, 01:30 AM   #5
02 wrx roar
Member#: 199600
Default Rhd
Im currrntly do this as well ac is the same just differnt lines.i got both cars stripped and im welding in the steering brackets and rhd inner brake braces and studs.. The rest is just drilln holes and reassembling.. Theres a few thing im still tryn to figure out
- should just extent my harness for the wipers and leave them along?
-and does the exhuast switch side for clearence i
Going to have a maddive turbo so im thinkn i
Going to have to
-think i can swap harrness in the doors to the oppiset sides and just buy switches?
- is the rear part of the harness the same on a 02 lhd and rhd bc mine cut off behind the seat and i was gonna just match the color code.
-also do u cut a hole for the blower motor and reweld up the other side or leave it?
As i progress with this i will try to answer question i want it done within a few weeks.. If u can help that be awsome thanks guys
02 wrx roar is offline   Reply With Quote
Old 10-26-2011, 03:01 AM   #6
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
Going to have to
i would use a rhd wiper set up...that way you can see in the rain. exhaust doesnt switch sides...just harder to fit us brand rotated kits. You can swap door harnesses side to side. youll have to find a jdm wiring schematic. cant go color to color. and yes cut a new hole and weld up the old one
blkwagon is offline   Reply With Quote
Old 10-27-2011, 12:21 AM   #7
02 wrx roar
Member#: 199600
Default Rhd
Hell yeah this wont be hard at all... Hardest part prolly be finding a jdm wireing sheet.. But ill work on it.. Thanks for clearing all that up only one other thing i was tryn to figur out is how to mount the wipers bc its differnt on that side.? Thanks for the help man much apprecated..
Old 10-27-2011, 03:05 AM   #8
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
woah, what is the bottle on the "passenger" side of the clip with the blue cap? Washer bottle? it's crazy looking.
Your center console should be the same, shift bezel too.
BeBop86 is offline   Reply With Quote
Old 10-27-2011, 10:49 PM   #9
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
It's the the intercooler spray bottle
Old 10-31-2011, 01:10 AM   #10
02 wrx roar
Member#: 199600
Default Rhd ??
So how did u mount the wiper motor? The top the car is defferent right there will it fit?cut it? Or wat im thinkn rainx and leave it fhd wiper idk.. How do u mount it
Old 10-31-2011, 12:51 PM   #11
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
The JDM condensor can just stay.... you dont need it at all! Just an FYI; The USDM firewall also has all the same spots as the JDM clip. Ive done 3 RHD swaps in GD cars and ive never swapped parts of the firewall. Just used a hole saw and die grinder to make it perfect. Not sure if this was how you were going to do it, but most people have been hacking the firewall up and swapping sections of it which is totally not necessary.
If you find a way to wire the driver side door switch to totally work properly let me know. Ive tried everything and just about everyone. Ive always had to wire the driver side window button to the Right Rear and just lost the Right rear window function all together. I even got on the UK subaru forums and had people take pics of their window switch and asked for wiring diagrams but nobody could provide a wiring diagram. In the end 3 windows work and door locks work, just no right rear window function because the button is used as the right front window function. If some how you do get it to function correctly PM me that info.
The lower console will fit just fine, all you need is the upper part and vents. the RHD dash is ever so slightly angled to the right for RHD and the USDM stuff wont fit properly. But it looks like you have the stuff that you need accept for the center vents, you will need to find a JDM or EDM one. Look on Ebay UK for RHD parts. Ive always found what i needed there., although the wording for a lot of parts is much different.
PM me if you have more RHD questions
UK-Wagon is offline   Reply With Quote
Old 11-01-2011, 02:30 AM   #12
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
haha...i actually got around to wiring my doors for the door locks finally....al my windows work but door locks are a different story...it works with my fob but not the switch.
Any one go RHD and DBW in GC8??? need help mounting 04sti Pedal bstoehr83 Subaru Conversions 3 10-16-2009 09:26 PM
Just moved to Portland and have a couple questions kyleblix North West Impreza Club Forum -- NWIC 7 11-06-2007 06:14 PM
Moving to Mass and have a couple of questions woody06967 New England Impreza Club Forum -- NESIC 28 07-28-2007 07:08 PM
Saying hi and have a couple questions VaBeachRex Newbies & FAQs 9 03-31-2007 01:02 PM
Going back to stock and have a couple of questions... Ldogdotcom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-21-2005 12:33 PM
