Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 07-10-2002, 03:43 PM   #1
Member#: 7970
2002 Impreza WRX
Default Anti-lift kit install on my02
Does anyone know where I can find info on intalling a anti-lift kit on a my02? I have found plenty of info for the gc8 but all i can find for the wrx is comments like "Its a pain in the arse" with no real info. If anyone has done the install could you just type up a quick set of instructions? Thanks
subix is offline   Reply With Quote
Old 07-10-2002, 05:53 PM   #2
Member#: 17042
2004 Impreza WRX STi
ObsidianRS is offline   Reply With Quote
Old 07-10-2002, 06:11 PM   #3
Storm Racing
Member#: 9204
Those instructions are for a GC8. For the WRX there are a number of subframe spacers that must be installed in addition to the instructions found above.
I attempted this myself.
I quickly found a place with a hoist.
It takes 2 people.
The subframe around the front of the car needs to be removed, its not as bad as you think, its just cumbersome.
The spacers must be placed and new bolts used at each mounting point. In the whiteline instructions it tells which spacer goes where.
With a hoist and the proper tools to remove those bolts its an hour job.
I would venture to say that without a hjoist its gonna take all day if not near impossible to undo some of those bolts.
Storm Racing is offline   Reply With Quote
Old 07-10-2002, 06:15 PM   #4
Member#: 14812
You can also find our 2002 ALK supplementary (subframe spacers) instructions here; http://www.whiteline.com.au/docs/208_KCA359.pdf.
Whiteline Automotive.
Whiteline is offline   Reply With Quote
Old 07-10-2002, 11:46 PM   #5
Member#: 7970
2002 Impreza WRX
yea, I cant really read the instructions because the packet of grease broke open during shipping and got all over them. Thanks for the help everyone, maybe when I go and do this I'll take some pics and do a writeup. Oh, and sounds like I will have fun doing this with jack stands!
Old 07-11-2002, 12:10 AM   #6
Member#: 8143
2014 sti
WR Blue
this install was nearly impossible
it can be done by one. i did. ah sheez!
1) got on my rhino ramps
2) took off plastic under covers (i think it was 1 big, 2 small side pieces, just philips screws and pop-screws, no brainer)
3) take off U-brace. be careful, this baby is heavy
now the fun part!
DO NOT USE 3/8" breaker bar. i destroyed 2 sockets and a torque wrench. thank goodness for Home Depot/Husky Lifetime/No questions warranty.
4) Use at least 1/2" breaker bar WITH helper bar. i think the socket size was 19mm (3/4"). take off the 2 bolts from each side.
5) now you need a 24mm box wrench, get one as long as you can get to get the right leverage to loosen it.
6) slide the old bushing off
7) using breaker bar or crow bar to leverage the control arm down to slide in the ALK.
8) reverse procedure while using the supplemental provided by Whiteline for the spacers.
ChuckCheeze is offline   Reply With Quote
WTB: Anti Lift Kit (ALK) for MY02 WRX YourMother'sLover TXIC Private Classifieds 1 01-29-2006 05:36 PM
Anti-Lift Kit Install Scooby02 Brakes, Steering & Suspension 2 07-01-2002 04:32 AM
Anti-Lift Kit Install (yes I searched!) fmyellowWRX Brakes, Steering & Suspension 1 12-14-2001 05:02 PM
Where can I get Anti-Lift kits Installed hedbusta Tri-State Area Forum 4 07-03-2001 10:20 AM
Anti-Lift kit install? yebokmj Newbies & FAQs 5 11-15-2000 04:03 PM
