#1 |
Member#: 272624
Well here goes : When the car was running- the dash lights
seemed dimmer but no warning lights. Then, while driving all electrical 'stuff' got slow, then the abs light came on, and the tach and speedo stopped reading. Thinking my alt belt was gone I drove until I felt I had to stop. Wouldn't restart. Waited for the wife to come get me. Decided to get it off the road better than I had and it started with all things working. Made it 12 kms. Happened again. The battery is a few months old tests at 12v( 14.8 with car running) I took it to Gemini Motors in Kitchener,ON. They said my battery wouldn't hold a charge and that was the problem. I was stranded this morning. They'll get another chance, but I could use some insight . Help ??
#2 |
Member#: 4835
Vehicle:2003 Baja 5MT Yellow w/ 220,000 miles |
Once the vehicle is running, it no longer depends on the battery to run. The battery will serve as a backup if something like the alternator fails. A bad battery would not explain why your vehicle is dying while driving. Did they test the alternator?
#3 |
Member#: 93577
Vehicle:98 Impreza |
Even if the alt belt breaks, the speedo and tach will keep working as long as the car has power (which if the engine is still running, it does).
#4 |
Member#: 272624
Yes. After they replaced my 4 month old battery. Both are good, they say.
They are looking into 'the problem' today. I am hoping for an edge on info. I explained the problem, they said it was fixed by replacing the battery. I say the problem caused the battery to die. |
#5 |
Member#: 4835
How many miles are on it? Do you notice any unusual corrosion on any of the wiring and contacts for the battery, alternator, fusebox, etc?
#6 |
Member#: 80465
RMIC
Vehicle:2001 2.5RS Black Diamond Pearl |
This probably belongs in electrical...
The battery is not just for starting, it also helps "cushion", or damp the voltage from the alternator. It sounds like he got nervous and shut the car off, it didn't die. OP, is that correct? That means what the repair shop told him is correct. Also, once a car battery is drained, it has a harder time holding a charge (depends on depth of discharge and length of time it was in that state, but you get the idea). Maybe there's a loose wire somewhere and during the drive, the alternator was only semi-running the car, which killed the battery. |
#7 |
Member#: 4835
yarrgh is correct.
#8 |
Member#: 272624
The OP didn't type the problem out well. He doesn't type much.
Thanks, but .... the car was dying, I got it off the main road and it stopped running. Yes, it started again because of the 'rebound' of the battery charge. This dying of the engine has happened a few times. I have condensed the issue for the forum. Start with the battery , work outward , I get it. Now, my battery light did not come on through any of the incidents. The light that came on was the ABS light. As the tach and speedo stopped reading. Car still running but electrical things weakening. |
#9 |
Member#: 272624
Thanks Samirr76, insightfull. I put a multimeter on the battery terminals and got
12 volts with the car off. Then I started it and got 14.8. Then, after a while the car works again. This recurs, each time the car runs for a shorter period, then dimm lights , abs light , no tach, rough idle cough, cough. Op doesn't let it stop itself, but rather, turns the key himself. |
#10 |
Member#: 272624
The repair shop said they fixed it yesterday and this morning I'm stuck in a snow storm
with no power to my symetrical all-wheel drive. Same symptoms/ problem/ description. |
#11 |
Member#: 192322
Vehicle:2002 Impreza TS |
Id call the garage that said they fixed it and tell the mto come get your ass. So as your driving everything will be normal then all of a sudden your dash lights go dim and warning lights all pop on at the same time then the car eventually dies? Could have a bad or loose ground wire.
#12 |
Member#: 272624
Thanks group. I suspected the loose wire, bad ground from the point I
figured out that I had 12v/14.8. Thought that some collected history could help. I will hold off on unloading on anyone, as it only inspires others to respond in kind. I am hopeful they find the issue, that it doesn't cost much, and that I am not stranded again, with the same problem. Loose /broken wire on the alt makes the most sense but alas, the same repair shop (Subaru dealer) fixed that a month ago. Huh? They redid my alt as an early Christmas present to myself. |
#13 |
Member#: 269045
Once you get the car back, start the car and while it is running disconnect the negative battery terminal. If the car dies immediately it means your alternator is not providing power to the car. The warning lights, combined with the lost speedo and tach readings then eventually chugging to a stop (as the fuel system doesn't have enough power to maintain pressure) has all signs pointing to alternator for me.
#14 | |
Member#: 80465
RMIC
| Thread Tools | |
| Display Modes | |
| 2002 2.5ts wagon mbp -$7500 | giveme5bux | Private Vehicle 'For Sale' Classifieds | 14 | 10-29-2006 02:31 PM |
| 2002 2.5TS Brake Rotors | wrenchy | Brakes, Steering & Suspension | 2 | 07-19-2006 01:40 AM |
| 2002 2.5Ts front suspension clunking ouch! | Luker | Brakes, Steering & Suspension | 3 | 03-18-2005 10:27 AM |
| Could it be true? About 2002 2.5TS | canadiannorton | Brakes, Steering & Suspension | 6 | 04-28-2002 10:16 AM |
| Could It Br TRUE? 2002 2.5TS | canadiannorton | New England Impreza Club Forum -- NESIC | 2 | 06-23-2001 09:49 PM |
