Old 07-10-2002, 05:21 PM   #1
TCENGEL
Member#: 8302
2002 WRX WRB Sold!
2006 Scion TC-T
Default Water Injection Questions
I am thinking of doing water injection to keep my WRX from pulling timing. I have a few questions.
-What are the pros and cons. Noone seems to be using it but all the others (dsm, Audi, Toyota and Honda) are using it and praise it's ability to stop detonation.
- How does it work and can it be run without a stand alone computer. I have a unichip for now?
-Who makes a good system?
Anyone can chime in. I have been in an MR-2 Turbo with it and he was running some damn high boost. I think he was running like 18-19PSI daily. It seemed to run great.
I really just want my engine to last longer, and run a bit harder without pulling timing all the time.
Thanks for info
Tim Cengel
TCENGEL is offline   Reply With Quote
Old 07-10-2002, 05:57 PM   #2
STEALTH-WRX
Member#: 7822
Multi layer snot green
here is what i know about it. a very very fine mist of water and methanol is sprayed in your intake. it cools the intake charge and should make your ecu pull less timing. from what i am told for every degree of timing pulled there is about a 2-3 hp loss. so if you can save 5-10 degrees of timing you will be ok. then again if you have a bigger more effecient turbo, the air will be colder or if you have an aftermarket ecu you can program it not to pull so much timing. i have talked to many people who have this and they swear by it. it is in know way new technology. in wwII they used water injection in air crafts for the same thing. how it works is that you have a pressure switch ( that you can adjust) that gives power to a pump at a certain psi. once you start to boost it pumps water and pushes it at around 36psi through a small jet. you can either get a tank or use your windshield washer fluid. as far as the liquid goes. i have heard 50% water, 50% methanol works best, but never exceed 50% methanol. some people just use water and it works fine. a company that makes it is called aquamist. www.vividracing.com has the aquamist erl water injection kit for sale. the only downside to it in my eyes is that it cost $500 for the lowest kit.
STEALTH-WRX is offline   Reply With Quote
Old 07-10-2002, 06:09 PM   #3
DJWRX
Member#: 10340
Yeah, most of the people on this board are not big fans of water injection. I, on the other hand, think it could work great on our cars. You are right, LOTS of other turbo enthusiasts use it, and get good results.
Biggest con I can think of is the fact that the water runs out (possibly very frequently) and with that, so does your engine safety. There are ways around this though. Using pressure switches to turn it on and off, you can set the switch to come on only when you are in approach of detonation. Say your engine det's at 18lbs of boost, set it to come on at 15 psi, and you only run water when you're going to full boost. This would help save H2O.
Not so much a water conservation technique, but you could set it to come on if the throttle is open below a certain % AND seeing high boost, that way you could combat the high egt's that plague ball/spring MBC's. But, IMHO, if you are going to go with WI, get a quality boost controller first.
Pros:
Cleans your engine out. The steam loosens all the carbon deposits inside.
Better gas mileage(when you run it).
Cooler intake charge
Cooler EGT's
Allows you to run a higher boost level than normal
Cons:
Runs out
Need to find a location for a tank
Runs out
Good kits are expensive
Runs out
Some take a little time to get the right "jetting" for the nozzle, but this will happen with anything adjustable, as you have to find the right setup for YOUR car.
I only emphasize the "runs out" because it does, and it is an extra thing to fill up every few days/week. If you could set it up to only need filling once a week, you could just do it when you fill up on gas. It could be kinda like a nitrous system, where you only run it when you switch to the high setting on your boost controller.
go to www.aquamist.co.uk
They have a very competent systems that require no outside managment. They also have some to be used in conjunction with standalones. I personally don't have the money, or agenda to do this, YET. So, if you do end up trying WI out, please be sure to post and let all of us know.
peace,
Tim
DJWRX is offline   Reply With Quote
Old 07-10-2002, 07:11 PM   #4
Happy
Member#: 12115
Firstly, the ERL/Aquamist pump has a working pressure of circa 140psi, not 36psi. This is why the Aquamist system is so good at producing a very fine spray/mist, if used with their water jets.
I have been using the system for about 2 1/2 yrs on my car, and have NEVER run out of water, or come even close. I use a 12ltr boot mounted tank, and day to day driving, it lasts me WEEKS. On track, it's good for about an hours use, before I need to top it up.
You can work out how much water the system uses per min' flat out, and allow yourself a safety margin. Depending on jet size, you could be using upto 250cc's per min'.
Regardless of what tank you use, fit a low level sender, and led on the dash.
I'd also suggest fitting an adjustable air intake temp switch in line, with the pressure switch. So that the system will only trigger over a certain boost, and temp threshold.
Happy.
Happy is offline   Reply With Quote
Old 07-10-2002, 07:52 PM   #5
Boostup!
Member#: 552
SOHC RS-Turbo EJ257
Tec-2 Aquamist 2D
Happy, where did you mount the water nozzles? I'm trying to figure out a good place to put them on a car with TMIC. IIRC Aquamist's instructions says to put them after the IC and before the TB, there is so little distance between there on our cars with TMIC.
The location is quite critical, if you put them in a bad location, the water mist might condense into droplets and that's not a good thing and you want to make sure each cylinders get an equal amount of spray.
Oh btw, my friend runs the Aquamist system in his 500+ whp 300ZX-TT with great results. He says it's like running higher octane fuel. Those cars come stock with a low fluid warning light too, so it works out just great for them.
Boostup! is offline   Reply With Quote
Old 07-10-2002, 09:11 PM   #6
wackie
Member#: 14580
2004 Forester XT
www.wrxhackers.com
In this PDF on the Aquamist site they recommend mounting it before the intercooler on our cars due to the heat soak characteristics of the TMIC.
JD
He who wants water injection and an A/L intercooler
wackie is offline   Reply With Quote
Old 07-10-2002, 11:53 PM   #7
suparu
Member#: 16729
Water injection is foundation upon which I am building my WRX.
You can see my implementation here.
Bob
Bob's '02 WRX Project
suparu is offline   Reply With Quote
Old 07-11-2002, 12:36 AM   #8
Corn-Picker
Member#: 8679
2010 The most hated
vehicle on the internets
Happy.
Do you use tap water, filtered water, or deionized water?
Also, where are the water injectors placed?
Thanks
Corn-Picker is offline   Reply With Quote
Old 07-11-2002, 08:17 AM   #9
russthelm
Member#: 7700
2003 Lancer Evo 8
Weightless White
I use distilled water (~ $1 from the supermarket), and denatured alcohol (~ $4 ).
I have a 2.5 qt reservoir in the rear and inject the water into my intercooler pipe just after the intercooler (my intake is long).
You would simply have to not pay attention to run out of water.
If I am hard on the gas all the time and drag racing from every light, my 2.5 qt would last a few days. With normal driving it would last the whole tank of gas.
As far as the cost I paid under $300 by using a Shurflo pump, and aquamist lines and nozzles (the most common setup for DSM's).
My system is boost activated by a 10 psi switch. With this system you would buy different size nozzles to determine how much flow you get. You could also add extra nozzles if needed, since the pump can handle the load.
There is a high speed valve option available which takes a pulse width signal so you can vary the output using a standalone ECU or something like that.
Here are some pics of my system.
http://home.earthlink.net/~rrwarren/Galant/wi1.jpg
http://home.earthlink.net/~rrwarren/Galant/wi2.jpg
http://home.earthlink.net/~rrwarren/Galant/wi3.jpg
russthelm is offline   Reply With Quote
Old 07-11-2002, 08:54 AM   #10
WRXpkr
Member#: 13607
82 Suzuki GS 1100E
Gold-ish
Thanks Everyone!
Ive brought this up a few times, and all i get from most is either i dont know much about it, or, and this is my favorite... Its Just a Band Aid for bad tuning... LMAO
I just got an sti boot tank, and need a few more engine mods before this is necisarry.
Yall didnt happen to mention that with WI you could run just about ass gas without a problem, witch ive seen become a problem out in the middle of nowhere with someone with an older Visinu stage 1. No good gas = trying to drive without boost till you find it. Not fun lol
ANyway, im glad there aer a few more here that see the benifits as i do.
Ill be keeping an eye on this thread for future reference.
Thanks again,
Trent
WRXpkr is offline   Reply With Quote
Old 07-11-2002, 09:09 AM   #11
Carlo
Member#: 18376
367 WHP!
460 HP at the crank!
I'm looking for some type of device like your boost activated switch. Can you tell me who makes yours or where to get something similar?
Thanks,
Carlo
Carlo is offline   Reply With Quote
Old 07-11-2002, 12:28 PM   #12
TCENGEL
Member#: 8302
2002 WRX WRB Sold!
2006 Scion TC-T
Wow,
Thanks for all the info guys. It seems like it's a good idea. I have decided to use an upgraded top mount intercooler instead of a front mount to keep lag to a minimum. I think combined with the water injection this could be a great idea.
I already fill the tank for my intercooler water sprayer so I am used to that already.
As soon as I do this I will make sure to take many pictures of the install and provide a good right up.
Any additional comments would be great.
Old 07-11-2002, 02:06 PM   #13
wackie
Member#: 14580
2004 Forester XT
www.wrxhackers.com
Note: this info is second hand. Stuff I picked up reading technical docs and talking to Shiv.
There is a possible negative effect to water injection. If you don't tune for it there is a decent chance you're going to lose a small amount of power by injecting water into your cylinders. However, with the proper tuning you can push the envelope a bit more, as intake and in-cylinder temps will be down and therefore the possibilities of knock are reduced. I'm not sure how the WRX ecu alone would react to it. . . I would be curious to see if it would start tuning more agressively. Anyone have some hard data on this? Maybe some DeltaDash logs?
JD
Old 07-11-2002, 03:10 PM   #14
TCENGEL
Member#: 8302
2002 WRX WRB Sold!
2006 Scion TC-T
I'm not looking for more power at the same boost. I'm looking to be able to run 18 PSI every day without any problems and possibly 20 PSI at the track. I love putting race gas in the car but water is sure a lot cheaper. 100 octane costs me about $ 40.00
for a full tank. You can see where the $500 initial cost of the water injection would pay itself off.
Where can I get the aquamist kit. Vivid sells the ERL kit. I would like to compare them.
Old 07-11-2002, 03:17 PM   #15
TCENGEL
Member#: 8302
2002 WRX WRB Sold!
2006 Scion TC-T
Oh yeah, as soon as it is installed and running I will make an appointment at TurboXS to do a dyno tuning. This way I can get true data on horsepower improvements. I hope to be able to dyno about 280-300 Horsepower at the wheels.
Old 07-11-2002, 03:23 PM   #16
bluesubie
Member#: 767
04 FXT
Lightbulb
Found this in the Technical Forum archives. It has comments from shiv, as well as a link to a very lengthy discussion on 22b.com
-Dennis
Old 07-11-2002, 08:32 PM   #17
DJWRX
Member#: 10340
OMG!!! I got sucked into that thread. It is LONG. Lots of good information being repeated. Worth the read though, VERY informative, especially if you aren't familiar with the merits/drawbacks of WI.
Tim
Old 07-11-2002, 10:18 PM   #18
TCENGEL
Member#: 8302
2002 WRX WRB Sold!
2006 Scion TC-T
Really good thread, Thanks.
Now that I have seen the new TXS TMIC I think the two would be great together. I imagine I could run really cool and safe with that combo. I definately need more info on the water injection though. It never came to me that the water takes up space of air and gas. I figured all the oxygen in the water would make the car faster, not slower. Great info so far though.
Old 07-11-2002, 10:47 PM   #19
spd wgn
Member#: 8571
2002 wrx
I would suggest that if you're interested in W.I., check out "suparu's" website: "Bobs 02 wrx project" as noted in previous post in this thread.
Bob is an ex-Corvette modifier who isn't one to blow his own smoke, but I think he really knows what this is all about. Very serious and researches thoroughly; not a person for fads or gimmicks.
spd wgn
spd wgn is offline   Reply With Quote
Old 07-12-2002, 02:14 AM   #20
DJWRX
Member#: 10340
I agree with (REO)spd wgn(I'm probably not as funny as I think, but humor me and laugh), suparu's work is impressive. His kit, that he put together himself mind you, is IMHO, top notch stuff. Well thought out and well executed. I'm tempted to ask him to put another kit together for me, I'd pay top $.
There is tons of information to read on WI. Go and research the hell out of it. I originally looked it up for my supercharged M3 project. It was an eaton blower, so it would have been very difficult to implement an intercooler in my plan. Well, sadly, that dream never got realized and I sold my baby the other day(after getting hit by a City of Austin garbage truck and getting stiffed on the $$$ for the damage). Long story and way off topic.
Tim
Old 07-12-2002, 11:41 AM   #21
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
I do water injection on my turbocharged SVX. It seemed like it reduced detonation, but I have no documentation to that effect or dyno results. I used a $200 spearco system. $500 is way too much for what you get. A small pump tank, tubing, and pressure switch. I should start selling them! Even $200 is too much for this setup IMHO. For me it is just piece of mind. I have not tried methanol. I'm sure the results would improve. I was just worried about corroding my expensive fuel injectors with that stuff. It is harsh on engine parts.
cdigerlando is offline   Reply With Quote
Old 07-12-2002, 01:20 PM   #22
zaxrex
Member#: 9898
Water Injected Blue
What pressure switch are you using, cdigerlando?
Also, nobody would happed to have a copy of this lying around, eh?
TITLE: Alcohol-water injection for high compression engines Authors:James C. Porter of Northern Regional Research Lab., Peoria, IL. Document Number: 500042
Lots of other sweet sounding titles here
Water injection
zaxrex is offline   Reply With Quote
Old 07-12-2002, 02:25 PM   #23
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Would there be any advantages/disadvantages to running water injection AND intercooler spray at the same time? It seems to me that if you had a good pump and you only needed to spray the intercooler when you wanted to inject water (high boost), then you could actually share the system and trigger both together.
If you have water injection (before the intercooler) would you even need an intercooler spray? I found some links to some 1-5 gallon fuel cells and it wouldn't be too hard to set one up as a resevoir.
My current boost control system runs stock boost levels at anything less than WOT and a throttle switch triggers the MBC to raise boost when needed. It would be incredibly easy to also wire in a relay and trigger water injection or even water injection/intercooler spray any time the boost is triggered. Does this sound feasable or even remotely worth the work? Of course a shared system would mean you'd probably want to run water only or a very low concentration of alcohol.
Mike Robinson
2002 WRX Sport Wagon
bluescoobywagon is offline   Reply With Quote
Old 07-12-2002, 03:59 PM   #24
zaxrex
Member#: 9898
Water Injected Blue
Make sure you don't run out of water mix, engine go boom under high boost det, I would think. The IC sparayer will go through lots of water if it is boost triggered. Some discussion has gone on about a more inteligent and effective spray management.
One other thought, the nozels/injectors are going to be flowing different volumes, and I would assume at different pressures (really fine mist for injection, and larger drops for IC sprayer) could one pump service both? If the water injectors are after the turbo, must take into account the pressure difference from the boost, you'll need to overcome XX PSI of boost to get the water out.
Old 07-13-2002, 02:51 PM   #25
DJWRX
Member#: 10340
I would have to disagree with zax. With a properly setup system, I would have some sort of high boost disable incase the water ran out. But, this is one of the big con's anti-WI advocates use, so I won't take that away from them, besides, with a poorly designed system, this is a very real problem.
I did have a question though, and I guess it sorta depends on the pump you're using, but would pressurizing the supply line TO the pump help pump efficiency? Or might it damage the parts designed to run on 0 pressure(well, atmospheric)? Suppose it is a Surflow(like suparu's(bob's)) or ERL/Aquamist pump
I stated in the N2O IC sprayer thread that I am designing a WI/IC sprayer system. If used solely as an IC sprayer, I've come up with a way to have a pressurized system without using a pump(sort of). If the prototype water sprayer works, AND its easy(and cheap) enough to source parts, I will offer a kit that should be substantially cheaper than most kits out there. Again, this depends on price and availability of parts. I am awaiting my tank to begin the building process. I'll let you know how it works.
So, for a WI system, will a pressurized feed to the pump help/hurt the pump performace?
Thanks,
Tim
SECS water injection question Twerthi Engine Management & Tuning 0 05-03-2005 11:09 PM
Water injection question, pump activated by relay wcbjr Water/Methanol Injection, Nitrous & Intercooler Cooling 2 02-22-2005 02:24 PM
Exhaust Water Injection question for Autotranny Kevin Thomas Transmission (AT/MT) & Driveline 10 09-08-2003 10:09 AM
water injection question FuelCutOff Engine Management & Tuning 9 09-03-2003 11:59 PM
Water Injection Question! MN Technical Forum Archive 7 05-10-2000 04:15 PM
