Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 02-02-2011, 03:17 PM   #1
qtr_wrx
Member#: 109567
Default PII ej25 hg thickness?
hello guys
I'm looking for a simple way to increase my na ej25 CR without going into pistons/shaving heads stuff! So I was thinking about a thiner hg
I was woundering what the oem hg thickness?
qtr_wrx is offline   Reply With Quote
Old 02-02-2011, 07:56 PM   #2
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
Stock head gasket thickness is 0.030 inches
Sti head gasket thickness is 0.020 inches
T Wrex--OH is offline   Reply With Quote
Old 02-03-2011, 06:49 PM   #3
qtr_wrx
Member#: 109567
thanks for the help. Do you know by how much points the CR will go up using sti hg?
Old 02-03-2011, 10:59 PM   #4
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
From 9.88 to 10.15.
That is according to my TWE compression calculator.
Old 02-03-2011, 11:26 PM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
IIRC the sti gasket is thicker. The N/A SOHC Phase II EJ25 HG is .60mm thick. If i'm not mistaken, the STi HG is 1.0mm thick. Anyone know for sure? Search button here I come...
~Josh~
FYI, sti gasket apparently is .60mm thick.
Old 02-03-2011, 11:37 PM   #6
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
~Josh~
Sorry man, I know this info is accurate.
0.75 mm for Phase II SOHC
0.50 mm for EJ25 STI
I know lower compression ratio of STI engine would suggest otherwise about the gasket thickness, but this is how it is.
Old 02-03-2011, 11:38 PM   #7
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
....But, the EJ25 DOHC on the other hand
1.50 mm thick head gasket.
Old 02-04-2011, 12:14 AM   #8
ballitch
Member#: 74907
98 cam'd EJ251
Well I knew that one...lol.
Not trying to say you're wrong, but just to be sure i'll throw my digi calipers on a new set of Phase II HG's and see what it says.
~Josh~
Old 02-04-2011, 12:44 AM   #9
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
I'm getting conflicting search results now.
I know the STI head gasket is indeed thinner, but by how much, I dunno.
Please, I'd like you to measure the gaskets with a caliper, I'm curious now.
I would do it, but who knows when I'll get my hands on them.
If you do measure the phase II gaskets, please include the part number.
Old 02-04-2011, 12:19 PM   #10
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
I changed my stock HG 11044AA633 for an STI one - 11044AA642. Forgot to asked the tech to measure but he said the crushed thickness of the STi one is greater
Would love to get actual values though and see how my CR changed
Old 02-04-2011, 02:23 PM   #11
qtr_wrx
Member#: 109567
From 9.88 to 10.15.
wow thats almost half point using oem parts.
Comteic make custom hg, right? I wounder if they make 0.010 inches to bump the CR up
Old 02-04-2011, 02:45 PM   #12
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
I wonder if the tech just looked at it and assumed it was thicker because it's multi-layered steel, as compared to the original, which is only single layered. I highly doubt he actually measured it.
I do not think the STI gasket is thicker. Possibly the same thickness, but definetely not thicker.
Old 02-04-2011, 04:12 PM   #13
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Found info! Bottom of the page...
http://www.b4et.com/docs/090618_ej_c...tio_matrix.pdf
Number crunching: If my HG went from 0.65 to 0.56mm for a stock CR of 10:1 my new CR is...?
Old 02-04-2011, 07:19 PM   #14
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
Nice find! What engine you have? SOHC EJ25?
Old 02-04-2011, 10:51 PM   #15
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
So if I plug in the bore and thickness of the gasket into the EJ25 SOHC, I get a final compression ratio of 10.19:1.
Not a bad bump in compression.
Old 02-05-2011, 12:44 AM   #16
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Thanks! Yes, I have a SOHC EJ251, 10:1... now raised to 10.2 :
Curious though ,where the heck do you plug these numbers in?
I'll have to do some logs soon to check if, with the increased compression, running 89 octane instead of 87 affects timing. Oh and some random online calculator stated that a .2 compression increase = +1hp....
Old 02-05-2011, 01:42 AM   #17
ballitch
Member#: 74907
98 cam'd EJ251
Google search "compression ratio calculator", take your pick. I use a site named not2fast.com Has a bunch of other links and info on the site that's fun to read up on.
~Josh~
Old 02-05-2011, 03:12 PM   #18
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
I have a .2 increase in compression too, yay! I'm plugging my numbers into an excel sheet made by Tech Works Engineering. Just google "twe compression calculator". It works great.
In honor of understanding men, I bring you Super Pii Pii brothers... maxQ Off-Topic 9 04-10-2008 03:41 PM
What is the thickness of the OEM Phase II 2.5 HG? w chapman Normally Aspirated Powertrain 2 09-20-2007 12:18 PM
EJ25 HG Questions... Experts needed! fastenova Normally Aspirated Powertrain 16 09-02-2006 05:00 PM
EJ25 pI / pII rod lengths? n2xlr8n Normally Aspirated Powertrain 3 12-08-2003 02:10 PM
Is there a reverse intake manifold made to fit a PII ej25? wighti Normally Aspirated with bolt-on Forced Induction Powertrain 7 08-11-2003 02:39 PM
