Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 04-21-2011, 10:49 AM   #76
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Originally Posted by ryanveld
There is no better oil for a Subaru than amsoil 0w30.
O rly?
XanRules is offline   Reply With Quote
Old 04-21-2011, 11:19 AM   #77
polarisboy385
Member#: 222041
2009 Impreza 2.5i
PRP
Also check out this site for more info on oil. Www.bobistheoilguy.com
I used to think that till I realized 100+ an oilchange was throwing mah munny away.
Then again I have a 2.5I
polarisboy385 is offline   Reply With Quote
Old 04-21-2011, 11:41 AM   #78
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
Oh cool, another thread to make people stand in the isle at the store and read every bottle while scratching their heads.
It's motor oil, not a blood transfusion.
NitroTrike is offline   Reply With Quote
Old 04-21-2011, 11:42 AM   #79
toehead
Member#: 268638
Originally Posted by Garrek11 View Post
There is a write up from FP about a bunch of oils they tested to the new spec qualifications and Rotella T6 was one of the worst.
Link?
toehead is offline   Reply With Quote
Old 04-21-2011, 12:08 PM   #80
griff9502
Member#: 251477
2006 Subaru WRX
Rotella T6 is also widely used in late model Chevy stroker motors running extremely high compression
griff9502 is offline   Reply With Quote
Old 04-21-2011, 12:11 PM   #81
Legacy01
Member#: 256016
2005 WRX
CGM
Gotta love these threads If unsure just go with what the current rating is for your spec(visc/weight/etc)...check UOA's and pick one you like that matches with a good rating.
Legacy01 is offline   Reply With Quote
Old 04-21-2011, 12:51 PM   #82
issueslude99
Member#: 280335
2011 WRX
Im getting close to my first oil change on my car, wondering if anyone has tried Lubri-moly and how it worked
issueslude99 is offline   Reply With Quote
Old 04-21-2011, 09:13 PM   #83
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Originally Posted by toehead View Post
Link?
I will see if I can find the email they sent me when they re built my turbo. If I cant I will give them a call and see if I can get the link since its not on there website.
Garrek11 is offline   Reply With Quote
Old 04-24-2011, 06:28 PM   #84
ryanveld
Member#: 238053
2006 STI
SGM
So a $100 dollar oil change every 24,000 miles or 1 year is a waste?
ryanveld is offline   Reply With Quote
Old 04-24-2011, 09:24 PM   #85
vinxH
Member#: 159796
2006 WRX
^Just because an oil can still lubricate well up until 24,000 miles does not mean it will not become abrasive by that time.
I like to play it safe and not pass the recommended 7500mi interval, no matter what oil I am using. I would also be hesitant using "European Car Formula" oil on a Subaru engine.
Some of you guys are losing sleep over oils, and it's almost quite funny. Just use Rotella T6 and do 7500mi changes, but keep an eye on the oil level every now and then. SURPRISE! That's all you have to do.
vinxH is offline   Reply With Quote
Old 04-24-2011, 09:37 PM   #86
bluesubie
Member#: 767
04 FXT
Why? Because it has more Anti-Wear additives, resists fuel dilution, and stays in grade? Also, Amsoil 0W-30 is not a European oil if that's what you were referring to. It would probably be a better oil if it were.
-Dennis
Old 04-24-2011, 09:38 PM   #87
thewritingwriter
Member#: 243214
2014 WRX Premium
I use Shell Rotella T 5w-40 full syn in my 06. Wally world has it for a pretty good price.
thewritingwriter is offline   Reply With Quote
Old 04-24-2011, 09:49 PM   #88
bluesubie
Member#: 767
04 FXT
Amsoil does not recommend going past 3,750 miles with any of their oils in a Subaru turbo. I ran SSO twice to 8k miles and had high oxidation and nitration.
-Dennis
Old 04-25-2011, 12:23 AM   #89
ryanveld
Member#: 238053
2006 STI
SGM
-Dennis
They say that as a disclaimer. Subaru sent out a bulletin shortening their intervals due to the clogging of 2 screens. I got rid of those screens. I have been running amsoil In my 06 sti for just under 9000 miles. I had it tested at 7500 and everything was fine. I'm planning on changing at 10,000. Unless I pull another sample and everything looks good again. I just found what works for me. In my jetta I am just under 15,000 miles and all is well. That using their euro oil though. I personaly think amsoil is good stuff and will never chose another oil.
Old 04-25-2011, 08:40 AM   #90
bluesubie
Member#: 767
04 FXT
I'm very familiar with those screens but Amsoil doesn't make a distinction between model year or 2.0 vs 2.5. I'm sure it's to cover themselves, but I'd be interested in seeing those uoa's if they include TBN, oxidation, and nitration.
-Dennis
Old 04-30-2011, 12:24 AM   #91
vinxH
Member#: 159796
2006 WRX
-Dennis
As a previous engineering major, I would be hesitant in using anything that was designed and then advertised specifically for a group of different automakers.
With more research in a specific oil, maybe I'd be more at ease, but with all the other good oils out there, like Rotella, I would have no good reason to switch off to an oil advertised for European cars.
Also, while the characteristics you mentioned are generally referred to as "Good" in engine oils, it's hard to jump conclusions that all oils labeled "European" would always be better than if it wasn't European, since we own Japanese cars.
As far as I am concerned, Japanese automakers tend to make their engines "tighter" and european automakers tend to make their engines "looser" ... which is why many european cars you see use a thicker oil than japanese cars. This is not always the case because we've seen GC work well in a Subaru motor, but just something to consider. But from what I've seen/read on here, GC is only close to a 40 oil, it isn't a true 40 weight oil. (Not sure if this is true, straight from nasioc )
Also I want to address one thing about those who say that 30 weight oils are bad because they shear to 20 weight. The people at Subaru who decided that the recommended oil should be 5w30 are the engineers.. the same people who designed/tested the motor and oils. They are engineers, they are not dumb. If they say that 5w30 is recommended, they already considered the fact that there is a possibility that the oil can and will shear down a bit.
and no, I wasn't referring to the Amsoil 0w30.
I'm not making any claims, there's just too many flawed logic in here and I'm just trying to maintain some integrity in this thread.
EDIT: I realize you said that European oils stay in grade. Being that the recommended oil change interval for Subaru is 7500 miles.. and even longer for some European automakers, do you have any data to back up that claim? I'm not calling you out, I'd just be surprised and pretty impressed if a 40 weight oil can stay a 40 weight oil after 7500-10,000 miles.
Old 01-02-2012, 01:24 PM   #92
swissmochaj
Member#: 305648
Default i hope i dont get flamed
So I've been reading all these posts and I haven't seen anything on the bulletin sent out by Subaru. Saying all 2011 and later cars with turbos must use Syn. Oil. Is this true or am i reading it wrong? I'm a new owner of a 2008 WRX and don't want to void any warranties. Its completely stock. I called Subaru and they said "the engine was designed for dino oil but synthetic doesn't hurt the engine. They also said if you use syn or dino the OCI doesnt change. I'm so confused on this issue. I will be changing oil every 3000. so it seems why run synthetic if my OCI is at 3000. Any clarification in lamen terms would be greatly appreciated.
swissmochaj is offline   Reply With Quote
Old 01-02-2012, 02:29 PM   #93
hieu1004
Member#: 240385
E92 BMW M3
^If you're changing your oil in such short intervals, you'll be fine with almost any good oil, dino or synthetic. Synthetic is required for my 2011 STi (2011 cars w/turbos - it states in my updated manual insert and on cars101 as linked below) but it was not for my 2010 WRX. Your 2008 WRX does not have a requirement to run synthetic only. As far as Subaru and their OCI requirements, it is pretty much to protect themselves from liability. Don't lose sleep over it - just use common sense: use a good oil, check it regularly and change it as required.
http://www.cars101.com/subaru/impreza/wrxsti2011.html
hieu1004 is offline   Reply With Quote
Old 01-02-2012, 02:35 PM   #94
habitatxskate
Member#: 197537
06 WRX
matte black
This, I usually find cheapest name brand stuff in 0w30
Usually castrol gtx or something
habitatxskate is offline   Reply With Quote
Old 01-02-2012, 03:17 PM   #95
RollForever
Member#: 305506
2005 STI
Castrol Syntec 5w-30 here
RollForever is offline   Reply With Quote
Old 03-08-2013, 12:55 PM   #96
4thgenx42
Member#: 146312
I currently use Motul in my car.
What's anyone's opinion on Kendall Full Synthetic?
4thgenx42 is offline   Reply With Quote
Old 03-08-2013, 07:58 PM   #97
S1CkWrx
Member#: 325249
2012 wrx
dgm
motul 5w30!
S1CkWrx is offline   Reply With Quote
Old 03-08-2013, 10:21 PM   #98
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
BradPen 10w40 partial synthetic. Only if your catless
booSTin-scoobs is offline   Reply With Quote
Engine oil for turbo engine differs from regular engine oil? cinemaster Service & Maintenance 9 04-29-2006 04:34 PM
25,000 miles and switching over to synthetic oil - do i need an engine oil flush? anthonyrb98 Service & Maintenance 1 04-25-2005 07:21 PM
oil leak from front of engine, oil pump? drftsub Legacy Forum 14 01-06-2003 08:44 PM
How often do you change engine oil with synthetic oil? malelee21 Service & Maintenance 53 04-14-2002 11:33 AM
Is it bad to change the engine oil and automatic transmission oil at 2-3000km?? V6 Normally Aspirated Powertrain 1 10-27-2000 10:08 AM
