Welcome to the North American Subaru Impreza Owners Club Friday July 31, 2015
Old 02-03-2011, 08:19 PM   #1
SnaP
Member#: 135339
2011 Impreza WRX STi
Dark Grey Metallic
Default engine whistle
just started last week... a noticible whistle noise coming from my engine. gets louder when the rpms go up.. almost sounds like a turbo spooling up :-/... lubed teh belt doesnt change it.. turning on / off a/c doesnt change it does it whether driving or sitting still.. 2.5n/a uel headers 118k... im stumped tried searching but cant find anything solid enough
SnaP is offline   Reply With Quote
Old 02-03-2011, 08:50 PM   #2
monr8
Member#: 97162
2005 OBS
Steel Gray Metallic
Does it have a lightweight pulley? If so, that might be it. I noticed it in my car after I installed one.
monr8 is offline   Reply With Quote
Old 02-03-2011, 09:07 PM   #3
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
A whistle can be a sign of an exhaust leak.
kero is offline   Reply With Quote
Old 02-03-2011, 09:16 PM   #4
EclipseMTL
Member#: 260404
2004 WRX
San Remo Red
Could also be a vacuum leak somewhere as well!
EclipseMTL is offline   Reply With Quote
Old 02-03-2011, 09:18 PM   #5
GrundleJuice
Member#: 165749
or a pulley warning you its about to empty it bearings all over the inside of the timing belt cover
Old 02-03-2011, 10:59 PM   #6
kgeezy
Member#: 241559
1999 impreza 2.5rs
Rbp
or if you have an intake. ganzflow or anytthing might whistle. did it on my car. sounded like a turbo kinda. very high pitched
kgeezy is offline   Reply With Quote
Old 02-03-2011, 11:03 PM   #7
radica1
Member#: 258466
2011 Impreza
Satin White Pearl
Hm, interesting. I have that exact sound too, but never really thought anything about it.
Also, my car is much newer and had that sound since I bought it new? Is there a different answer in this case?
radica1 is offline   Reply With Quote
Old 02-04-2011, 11:13 AM   #8
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
Maybe it was that new whistle tip you put on your exhaust. It makes your car go Whoooooo..whoooooo.... or check your intake.
aclver1 is offline   Reply With Quote
Old 02-04-2011, 11:16 AM   #9
rallyvovo
Member#: 167738
I think im experiencing a similar phenomenon!
Can whistling be confused with light pinging though???
rallyvovo is offline   Reply With Quote
Old 02-04-2011, 01:27 PM   #10
razrielle
Member#: 205698
have you done your timing belt yet/ replaced all the pulleys and what not
razrielle is offline   Reply With Quote
Old 02-04-2011, 03:55 PM   #11
rallyvovo
Member#: 167738
You need to determine if throttle position is a factor.
Walk the motor up at 1/4 gas to high RPMS when you normally would hear it. Do the same but w/ 3/4 throttle.
Keep a constant throttle doing this. See about noise.
IF the noise IS throttle related you can most likely rule out any of the belt drive components (and transmission etc). This would mean it is most likely air/fuel related:
-intake ducting
-air filter
-exhaust (leak)
-i maintain it could even be a ping or ten!
Old 02-05-2011, 12:16 PM   #12
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
loose belts in the cold... sometimes my car sounds like it has a supercharger.
also my exhaust whistles between 2-3k rpm when there's a lot of water/condensation inside it... it sounds like a wheel bearing... it went away after I drove it for a few hours without stopping... shorter commutes for me create lots of condensate inside the exhaust.
Sir-Knight is offline   Reply With Quote
Old 02-06-2011, 12:59 AM   #13
SnaP
Member#: 135339
Dark Grey Metallic
head gaskets/ timing belt / waterpump and all that fun stuff were done around 98K under warrenty.. no intake all everything is stock except for the exhaust.. noise did start in the cold i always though that had somethign to do with it :-\..... noise is there at idle than while im driving steadily increasing or maintaing throttle position.. like sir knight said... sounds exactly like a supercharger .. as the rpms go up it gets louder than when i let off teh gas it just eases down and ive noticed sometimes over the past few weeks the engine doesnt idle down right away between shifts... if i shift at 4000 and press in the clutch the engine will slowly go down in rpms not like it used to.. might be associated with the whistle both started around same ttime
Old 02-06-2011, 12:48 PM   #14
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
I had this "about to happen" before i changed my tbelt and pulleys. Was all crunchy.
moogoob is offline   Reply With Quote
Old 02-06-2011, 08:20 PM   #15
lionsault
Member#: 245453
2010 Subaru Impreza
My guess. Exhaust leak.
lionsault is offline   Reply With Quote
Old 02-06-2011, 09:06 PM   #16
tw000rs
Member#: 182102
02 WRX Aspen white
Built 257 07 STi trans
Check the "torque" box on your intake. I had the same issue and it was from it not being put back on correctly. Good luck.
tw000rs is offline   Reply With Quote
Old 02-08-2011, 03:23 PM   #17
andrew's bug eye
Member#: 254997
2014 Impreza
Pearl White
I have an injen intake and once I put it on, I noticed a whistle with the throttle at about 1/4. If I keep it about 1/4, the whistle is constant. Any ideas
andrew's bug eye is offline   Reply With Quote
Old 02-09-2011, 08:44 PM   #18
Overload11
Member#: 273456
1999 Ouback Limited
Green
Question Similiar whistle?
I have experienced a similar whistle in my 99 Outback. At least I think it is the same. It comes from the rear of the car, but is activated by a certain spot and pressure on my gas pedal. When i hit the spot it remains, but if I push harder or left off the whistle stops.
Overload11 is offline   Reply With Quote
Old 02-09-2011, 08:49 PM   #19
N/A_Scoobs
Member#: 255985
2008 Impreza N/A
dark grey metallic
Check the hose clamps on the hoses that are attached to the crank case! I tightened mine up the other day and my whistling days are over
note: I dont have a CAI but i do have a Hybrid intake so same hoses just not same intake
N/A_Scoobs is offline   Reply With Quote
Old 02-09-2011, 09:32 PM   #20
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
ahhH! beat me to it. If it's only in tha moanin, it's def whistle tips. If it is all the time, it's probably your intake.
Mine whistled a little bit when I first got my car, then I installed a hybrid intake and it got louder. Mine does it the loudest under smooth RPM climbs in 2nd and 3rd gears. Like mentioned above, if you can confirm that it is your intake plumbing it shouldn't be an issue. I guess you could install some sort of resonance chamber to get rid of it. That is what THIS (circled below) is on the stock intake if I understand correctly. There is also one under the torque box.
Rudgers73 is offline   Reply With Quote
Old 02-09-2011, 11:53 PM   #21
andrew's bug eye
Member#: 254997
2014 Impreza
Pearl White
yeah its definitely weird. ill check all my fittings and let yall know
Old 02-10-2011, 08:21 AM   #22
Boxer4Dad
Member#: 137226
2005 Saabaru 2.5i
OBP, or Black
Could this be the fuel pump? I have this, and it seems to be getting worse (happens more often, and not just in cold situations).
Boxer4Dad is offline   Reply With Quote
Old 02-11-2011, 01:32 AM   #23
Overload11
Member#: 273456
1999 Ouback Limited
Green
It might be, I googled fuel pump humming noise and it seems to a similar description
of what is going in my Subaru. Is there a good way to find out if the fuel pump is bad?
Old 02-11-2011, 10:30 AM   #24
Boxer4Dad
Member#: 137226
2005 Saabaru 2.5i
OBP, or Black
I think the only way is some kind of fuel pressure check. I'm about to get one for mine. At 130K, it wouldn't be a surprising failure. When I've had them go in the past (other makes), you could usually hear the whine for a while, and it just got harder and harder to start. Mine starts hard now, which I thought was due to the cold, but it just might be the pump going. Hope that helps, and sorry about the threadjack...
Old 02-12-2011, 07:04 PM   #25
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
If the fuel pump is bad it would have trouble starting occasionally and I would imagine it would have issues under hard acceleration (ie shuddering/coughing) Eventually it would be stalling, then ultimately not start for you.
Engine Whistle Paul V Legacy Forum 6 02-20-2014 11:14 PM
2.2l Engine whistle at high RPM boyleia1 Normally Aspirated Powertrain 11 10-24-2007 04:37 PM
06 Stock STi - Sudden Engine Whistling Noise After High Speed SixSigma Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 37 02-09-2006 09:43 PM
Whistling on engine compartment alexr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-13-2005 06:14 AM
Liberty (legacy) 2.2 lt engine whistle Paul V Legacy Forum 6 04-21-2004 10:20 AM
