Old 02-04-2011, 04:49 PM   #1
rpg5553
Member#: 253423
Default EJ20G Turbo Motor In Porsche 914 Getting Code 45
Greetings,
I put a 95 EJ20G (JDM) turbo motor in a Porsche 914 and It runs fine until the turbo kicks in, then it falls on it's face Pulled the codes and got a code 45 which says turbo pressure sensor. Found out this is a pretty important part which I am missing
I started looking around for this sensor with no luck. Is there any other car that uses this particular sensor or do I have any other options? Found out it is a denso part number 22012AA020 if that helps.
Also, as I made up my own wiring harness I found out I needed a VSS. Looking on the web I found out where someone grounded the PARK pin on the ECU and that bypassed the VSS and kept it out of limp mode. Can any one verify that.
Thanks for any help.
Ronnie G
rpg5553 is offline   Reply With Quote
Old 02-04-2011, 05:17 PM   #2
sawtooth
Member#: 185339
'73 914 suby
Cool, this is 914 day in the Conversion forum. Got any pics of your project?
sawtooth is offline   Reply With Quote
Old 02-06-2011, 09:38 AM   #3
rpg5553
Member#: 253423
Default Got to get the camera out
sawtooth
I just checked out your build and it looks great. Wish I would have gone with the suby trans but decided to use the base Renegade kit. Figured I have been shifting the old 901 tranny for 10+ years so kinda used to it.
I took a few pictures starting out then got pulled into the build and forgot to take any more. I'll get the camera out when it stops raining in Atlanta,
supposed to be nice today and get some pictures.
Mine has been on the road for a few months but having an issue when the boost gets up. It will give you whiplash till about 4K then drops off.
Missing a turbo pressure sensor so suspect that is the culprit causing my boost problems.
Enjoy your teener
Ronnie G
Old 02-06-2011, 10:11 AM   #4
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
for what its worth its also its more commonly referred to as the MAP sensor
Old 02-06-2011, 05:30 PM   #5
rpg5553
Member#: 253423
JAXX,
Guess I am confused on terminology on what this part is that I need.
I picked up a pressure exchange solenoid from Pull-A-Part from a 95 Impreza non turbo. There was a map sensor attached to the pressure exchange solenoid with a hose with a part number of denzo 22012AA070.
From looking on the web it looks like I need something from a turbo to resolve my code 45 issue. Am I on the right track looking for a turbo pressue sensor denzo 22012AA020. Hope this helps.
Thanks
Ronnie G
Old 02-07-2011, 10:20 AM   #6
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
map = manifold absolute pressure
a n/a will always have vacuum so they use a 1 bar sensor -full vacuum to atmospheric
turbo charged cars (hopefully) have positive manifold pressure and use a 2 bar (or more) full vacuum to +14.5 psi
truth be told the part you need is not a 2 bar its more like a 2.4ish bar.. and sensor outputs are not standardized so you need the original part
i would triple-quad x2 check my wiring and ground before i ordered one, as its not a common failure
Old 02-13-2011, 06:55 PM   #7
gtu89rx7
Member#: 108029
95 Impreza Outback
EJ20G swapped
make sure you have the pressure exchange solenoid wired in, if it is not it will show code 45 also. the pressure exchance solenoid switches the signal from the boost line from the boost sensor to atmosphere so the ecu can get a reading on atmospheric pressure.
i am also looking for a map sensor, but cant find one cheap. I am currently using a GM 2 bar map sensor, which is close enough to not throw codes
gtu89rx7 is offline   Reply With Quote
Old 02-13-2011, 09:35 PM   #8
a914622
Member#: 264504
As far as your Vss there are a few options. There are ones out there that simulate VSS. depending on the computer you are using that may be all you need. I had it work and at 2k the computer learned and started throwing codes
There is also the smallcar set that bolts to the CV. good option.
You can also rework the 914 ERG box. You need to pull apart the subaru speedo and put the magnet ring in the erg box. Thats what i did on my vanagon. works good
Search vvs on the vanagon subaru yahoo group.
jcl
a914622 is offline   Reply With Quote
Old 02-13-2011, 09:58 PM   #9
a914622
Member#: 264504
Old 02-19-2011, 07:39 PM   #10
rpg5553
Member#: 253423
Default Boost Or Limp Mode.
Thanks for the replys,
So does the pressure exchange solenoid and turbo pressure sensor both use vaccum? I have a pressure exchange solenoid denso # 14774aa500 currently hooked to two vaccum lines. Got it from a 95 n/a Impreza which said it should replace the 14774aa341 that would have came with my engine.
A vaccum hose from it goes to the Turbo pressure sensor which I just picked up. Got three wires, two going to ecu. 5v and signal and another wire for ground. When I wire it up like this the engine will start and then die. Pull the turbo pressure sensor wires off, engine fires up and runs fine except for my boost issue. I am not sure if the engine is in limp mode or is getting boost cut. If I take it out and accelerate hard boost will go to 8 psi and engine will shut down. I can accelerate slowly and pull 12-14 psi boost and engine will rev to 6k. Does this sound like limp mode or getting boost cut. Anyone have a clue on what is going on with it?
Thanks.
Ronnie G
Old 05-07-2011, 01:19 PM   #11
ruby914
Member#: 243509
2002 WRX in a 914POR
Many
jcl
I got a VSS from Smallcar http://www.smallcar.com/index.php?di...iew&page_id=15 but I am not so happy with it.
It seems to work on and off, not sure why??
I look for a better plan.
The problem I find is most aftermarket VSS are not 5 pulse per rev.
I am using both the WRX speedo and ECU so that is what I need.
I saw a link for a fix on the Vanaru's instrument cluster but I don't recall that would work with the Subaru gauge.
I like the Idea of going from the Trans output shaft like this: http://www.914world.com/bbs2/index.p...&hl=sti&st=260
Maybe you can get Scott to update his thread for more info.
I think we still need 5 pulse for the ECU but if your using a different speedo I think you would need a pulse to match the speedo
ruby914 is offline   Reply With Quote
Old 05-16-2011, 03:22 PM   #12
charliew
Member#: 125304
RPG I know it's been awhile since you posted about the map sensor problem but I just read about your last question. When my son and I worked on his motor we made a new cold air intake and used the original map sensor. When we tried to start the motor it wouldn't run good. My son found the answer on nasioc. We had the map turned around backward in it's mount.
charliew is offline   Reply With Quote
95 EJ20G JDM Turbo getting code 45 rpg5553 Pre-2002 Factory Turbo Powertrain 7 02-19-2011 08:37 PM
BOOST table ej20 Turbo in Porsche 914 budman5201 Factory 2.0L Turbo Powertrain 1 07-18-2009 09:00 AM
Turbo 2.0 in porsche 914 Temperature problems budman5201 Newbies & FAQs 5 07-05-2009 01:20 PM
WTB: NA Subaru Motor for Porsche 914 Simon Tibbett Private 'Wanted' Classifieds 2 06-08-2009 12:40 PM
Turbo motor into Porsche 914. Which motor to use and where to get it? pktzygt Subaru Conversions 18 11-08-2008 04:52 PM
Message Board Statistics All times are GMT -4. The time now is 10:25 AM.
