Old 03-03-2011, 11:08 PM   #276
dub599
Member#: 269645
2009 wrx
dgm
Originally Posted by GriffithBuilt View Post
What year Legacy? We could easily get something done in a day. It's most likely similar enough to an existing design that we could build it out in a few hours.
Cheap too. I want moar products on our website.
Jason
i dont have a legacy i have a 09 wrx sedan
Originally Posted by Shadowish View Post
You won't have a job, and you are still modding your car?!? That there is dedication! Or you are in desperate need of having your priorities rearranged.... Lol
i have cheap housing, and im very dedicated to getting my car to closer match the vision i have in my head. yes my priorities might be slightly off as well, but i have no kids and no wife so its kind of the perfect time for it.
dub599 is offline   Reply With Quote
Old 03-04-2011, 01:33 AM   #277
GriffithBuilt
Member#: 141927
Originally Posted by cheezmunky View Post
I've been following the hatch development for a while and have a few questions:
1) by straight through flowing design do you mean a design similar to cobb's exhaust? http://www.cobbtuning.com/images_products/5009.jpg
2) I see you are recommending polyurethane bushing for the hatchback but have not done so for the sedan.
--- a) Is this due to a difference between sedan and hatchback or will you be recommending them for the sedan as well
--- b) Is it possible to get a good fit without the bushings? I haven't looked under my car to see how exactly everything hooks up
3) Is the hatch exhaust flush with the valence or recessed? Looks pretty close to flush in the vids but wanted to be sure
4) I'll be going for sound rather than performance at this point in time. Is there any downside to just installing the axle-back with the step in size and is the gasket included?
Ah yes, busy day. I started replying to this earlier but got derailed with a few phone calls.
1. Yes, it is similar to that but instead of coming into the muffler at the rear it comes in the side. It is a straight through, non baffled, perforated pipe inside the muffler that goes from the inlet to a Y inside the muffler.
2. I'm just offering the bushings because I think some people may want them and I make a little money on them. They're a great solution for a rallycross/autocross/track car or a car that may see these events. The factory bushings are sloppy and in high cornering and left-to-right chicane type stuff, they will let the muffler move around more than the urethane units. These can also just as well be used on the Sedan. They are not by any means necessary for proper fitment or to keep the tips from touching the valence.
3. Hatch is currently only available in flush. We have only sold five exhausts that were not flush. It's the best option and if I can decrease confusion by decreasing options that nobody picks, I'll do it. That's not to say that we can't do custom stuff for anyone. And our fixture is set up variably to move those tips wherever you please.
4. No detractions to attaching to the factory midpipe and the gasket that spans the size of both flanges is included. We will eventually have a pull down menu item that requests whether or not the end user is attaching it to a factory midpipe or a 3".
Finally, that photo of 'flush' that xabre posted is not our exhaust and is not what our 'flush looks like. That photo sticks out a little bit, ours are flush. I.E. extended to match the face of the valence, not to stick out. The photos on our website of the sedan axleback show a side view for clarity.
And if you need any clarification about what the options are or which you should buy for your car, CALL ME. 360.263.5001. And if you don't leave a message, don't expect a call back. I get 20 hangups on the answering machine every day. We're a 3 person shop and we are busy as a three legged cat burying a turd on a marble floor. That's not to say that I won't spend a half an hour on the phone talking to you to answer all of your questions - that's my job here. :-)
Talk to you all soon!
Jason
GriffithBuilt is offline   Reply With Quote
Old 03-04-2011, 01:34 AM   #278
GriffithBuilt
Member#: 141927
Ooh that's even better!!
Jason
Old 03-04-2011, 01:46 AM   #279
GriffithBuilt
Member#: 141927
Originally Posted by ericsson View Post
ummm can someone please explain the options?? maybe a "muffler for dummies" guide or something??
staggered: Astonished, taken aback
valence: The chemical conbining capacity of an element or ion
doublewall? halfway?? rolled lip??
The defintions I found aren't quite right..
Ok no problem!
Staggered is where the dual tailpipe tip on one side (two pipes per tip) are offset relative to each other so the tip nearer the outboard (fender) of the car is sunk in a little further (in our case .5") than the inboard (license plate) tip. This gives the nice curved look that matches the rear of the car. It fits well. Some people want a straight tip though, similar to the BMW M3 exhausts - both tips are the same length relative to one another.
The valence is the bumper cover - that big piece of plastic that wraps around a chunk of styrofoam on the back of your car ;-) The 'valence' typically refers to the lower edge of this bumper panel, where the cutouts are for the tips to poke out of the back of the bumper. So when we say 'flush with valence' we mean that the end of the tailpipe tips goes out just to the edge of the bumper. 'Halfway is halfway between the 'flush' position and the 'recessed' factory position.
Double Wall/Rolled Lip/Single Wall are the style of tip -
A double wall tip is a design where the tailpipe tip is actually made up of closed inner and outer wall so there is an air gap between the inside of the pipe and the outside of the tip.
A rolled lip tip is a single wall tube of stainless steel with the outside lip (that faces the back of the car) mechanically rolled in, so the edge isn't sharp.
A single wall tip is one that is just basically a pipe that is usually cut at an angle or straight, but it's just a .065" thick pipe.
Hope that adds some clarity. We plan on updating our website fairly soon to have some good illustrations of these options to clarify for our future customers as well. Just been busy making existing parts and designing new ones. Need to focus on the website soon! Lots.
Talk to you all soon,
Your friendly neighborhood parts builder,
Jason
Old 03-04-2011, 09:38 AM   #280
ericsson
Member Sales Rating: (2)
Member#: 208672
2013 WRX STI Limited
Obsidian Black
You had to rub it in, didn't ya??
Ok.. makes a lot more sense now.. thanks!!
ericsson is offline   Reply With Quote
Old 03-04-2011, 09:15 PM   #281
stanrc
Member Sales Rating: (4)
Member#: 266177
2006 MX-5
RED
Has anyone installed one with the gloss black finish? I'd love to pictures of it installed to see how it looks on a car. Pref WRB
stanrc is offline   Reply With Quote
Old 03-04-2011, 09:46 PM   #282
robert.lshoc
Member Sales Rating: (1)
Member#: 164906
11n7 WRX
Satin pearl white/ wrb
Jus tordered my ss slash cut offset equal about how long till i see it?
robert.lshoc is offline   Reply With Quote
Old 03-04-2011, 10:05 PM   #283
GriffithBuilt
Member#: 141927
Depends on whether or not it can get welded out tonight. If not tonight it'd be finished Monday and shipped Tuesday, which is barely just maybe squeezing it in for Friday delivery. I'll do my best to finish it and ship it Monday to ensure that you get it by the weekend. I'll put a note on the work order as well. :-)
Thanks for the business, really appreciate it!
Jason
Old 03-04-2011, 10:07 PM   #284
GriffithBuilt
Member#: 141927
I have a customer who just got a black set on a WRB car. I'll ping them and see if they're installed yet. Not sure who else is running the 10% Gloss (which is actually almost a satin finish, it's low gloss, not full gloss) on a WRB colored car.
Jason
Old 03-04-2011, 10:13 PM   #285
stanrc
Member#: 266177
2006 MX-5
RED
Jason
Great, thanks.
Old 03-04-2011, 11:07 PM   #286
jt0thevizzle
Member Sales Rating: (11)
Member#: 174979
Can't wait to see those pics jason! hahaha i feel like a proud father?
jt0thevizzle is offline   Reply With Quote
Old 03-05-2011, 08:01 AM   #287
Aluma
Member#: 136157
2011 WRX
Hey jason, would it be possible to extend the skidplate and incorporate a splitter or lip?
Aluma is offline   Reply With Quote
Old 03-05-2011, 08:46 AM   #288
mrkyle3
Member#: 272675
2011 WRX
2004 Miata
Yes if you use a stock gasket on the cobb it will mate up perfectly. Our goal when it comes to the mating to the downpipe is to use a proprietary donut gasket to allow connection to our 3" downpipe to both the stock and aftermarket exhausts. But yes, our midpipe will connect to the factory or COBB 2.5" outlet on the downpipe.
As for pricing, here's the deal:
Catback (one price if you buy it all at once): $899.
Axleback on its own: $485 (will be discounted to $435 until we release the midpipe).
Midpipe on its own: $515 (if you buy an Axleback before the midpipe is released you'll get $50 off on it as well).
So the bottom line is, you get the catback price if you buy the Axleback first. And if you only buy the axleback first with no intention of buying a midpipe, you get $50 off for being one of the early adopters of the system.
Jason
When is the midpipe getting released? I won't be able to order the exhaust for another week or so.
Also, this may be a noob question, but how big is the box it comes in? Where I choose to have it delivered is dependent on its size.
mrkyle3 is offline   Reply With Quote
Old 03-05-2011, 09:45 AM   #289
Jdawson01
Member#: 275178
2011 WRX (Limitied)
Pearl White
6'' tips that come with tin snips or u guys fail and go.
Jdawson01 is offline   Reply With Quote
Old 03-06-2011, 05:56 PM   #290
airwg2189
Member#: 263307
2011 Impreza WRX
Black Pearl
Put my exhaust on last night, installation is easy and everything bolts perfectly up to stock piping. These pipes sound absolutely amazing! Youtube videos do NOT do this product justice. It's very loud, but not annoying, and your car will sound nasty when you step on it.
Greatly satisfied customer!
airwg2189 is offline   Reply With Quote
Old 03-06-2011, 09:20 PM   #291
Pineapple Devil
Member#: 261570
2011 WRX Premium
so the price went from $300 to $435?
Pineapple Devil is offline   Reply With Quote
Old 03-06-2011, 10:39 PM   #292
Don Plata
Member#: 272259
2011 STI
plasma blue pearl
435 WTF, I WAS GOING TO BUY A SET NEXT WEEK
Don Plata is offline   Reply With Quote
Old 03-06-2011, 10:43 PM   #293
Yuckfou
Member Sales Rating: (8)
Member#: 225513
2015 STI
You guys do realize that we are discussing 2 different systems right?
The Sedan exhaust is still $300
http://namelessperformance.com/produ...eback-exhaust/
The Hatch exhaust is $435
Do some research before pooping yourselves.
Yuckfou is offline   Reply With Quote
Old 03-06-2011, 10:44 PM   #294
Redmed427
Member#: 254409
2011 WRX 5-door
LR
SMH, Guys, go check the site out. Its 300 for the sedan exhaust and 435 for the hatch.
http://namelessperformance.com/products/subaru
Redmed427 is offline   Reply With Quote
Old 03-06-2011, 10:45 PM   #295
Don Plata
Member#: 272259
2011 STI
plasma blue pearl
^^^ me happy now , me has a 4 door
Old 03-06-2011, 10:46 PM   #296
Yuckfou
Member#: 225513
2015 STI
Cool
Old 03-06-2011, 11:22 PM   #297
Pineapple Devil
Member#: 261570
2011 WRX Premium
yeah me too. i had such high hopes too
Old 03-06-2011, 11:24 PM   #298
Pineapple Devil
Member#: 261570
2011 WRX Premium
i did research. i was under the impression that the hatch version was going to be $300 too.
Old 03-07-2011, 12:18 AM   #299
Ruz4life
Member#: 258261
2011 WRX 5-door
Obsidian black pearl
Me too
Was going to spend 300 + 40 bucks shipping for the axleback, but now the hatch is gonna be almost 500 bucks with shipping for an axleback.
Just seems to be too high now to justify. I guess I'm still a little confused how the hatch is more expensive than sedan?
Ruz4life is offline   Reply With Quote
Old 03-07-2011, 01:58 AM   #300
Olduwan
Member#: 266164
2011 STI Sedan Ltd
Satin White Pearl
Originally Posted by Ruz4life View Post
Me too
He answered that question a couple pages back. It's because the hatch axleback has mufflers and more complex bends. It just costs more to make. If you look at the pics of both the sedan and hatch version, it'll make sense.
Olduwan is offline   Reply With Quote
