Old 02-05-2011, 10:55 PM   #1
Ryan23
Member#: 15116
2000 Ver6 STi Type-R
EJ257/GT35R
Default 00' Version 6 STi, 2.5L, ATP 35R, 376 whp
Event: Road tune
Ambient Temp: 45* F
Elevation: 50 ft ASL
Weather: Cool/dark
Tires: Dunlop Direzza Star Spec 235/40/17
Car: 00' JDM Impreza STi Version 6, Type R
Tuner: Me
Dyno Info: Airboy
Airboy variables are as follows:
Smoothing: 5 (65 points of data)
Car weight: 2800 lbs
Delta weight: 375 lbs
Cd, Drag Coeff; 0.33
Frontal Area: 22
RPM to Speed Conv: 72.32
Crr, Rolling Res Coeff: 0.015
Elevation above sea Level: 0
Rel. Humidity: 60
Air Temp: 45
Gear ratio: 1.346
Final: 3.9
Engine to speed: 72.32
Transmission: 05' JDM GDB 6spd & rear
Gear: 4th
Peak HP at RPM: 376 hp @ 6310
Peak Torque at RPM: 351 @ 4970
Target Boost: 16.5 psi
Target AFR: 11.5:1
Fuel: 93 octane base gas
Engine/Power Modifications:
Engine bottom end
EJ257 "USDM" engine block
Cosworth stock bore pistons, 8.5:1 comp.
Manley I-Beam con rods
2010 EJ257 crankshaft
ACL H Main and HX connecting rod engine bearings
12mm JDM Legacy oil pump
Killer B Ver 2 oil pan, pickup and baffle
STi Kevlar timing belt
Cosworth timing belt guide
Perrin crank pulley
Cylinder heads and top end
EJ207 AVCS cylinder heads, fully ported, chambers matched to 99.5mm bore, 5 angle valve job by ASF Machine
Supertech +1mm Inconel exhaust valves
Supertech +1mm Stainless Steel intake valves
Brian Crower valve springs and Ti retainers
Kelford 272/268 cams
ARP head studs
Subaru MLS head gaskets
JDM Spec C Intake manifold, TGV-less
Grimmspeed air/oil separator
Turbo, exhaust and intercooler
Stock location ATP GT35R, internally gated, ported and HPC coated turbine housing
GT Spec SS equal length header
Syms 80mm downpipe, ported to clear the wastegate flapper
Custom 80mm full titanium exhaust, downpipe-back
100mm FMIC
APS 3" turbo inlet pipe
Apexi air filter
Engine management and ignition
Link G4 "Xtreme" standalone, speed density tune
Link 4 Bar MAP sensor
MAC 3 port boost solenoid
Innovate wideband 02
Bosch Motorsports KS-P knock sensor
GDB coil on plug ignition
NGK Iridium plugs
Fuel System
STi Group N fuel baffle, pickup
Perrin top feed fuel rails & lines
Injector Dynamics 1000cc injectors
Nismo adjustable fuel pressure regulator
Walbro 255 lph pump
Suspension/other stuff:
Prova coilovers and a bunch of other things not pertinent to PPB
First off, sorry for it only being an Airboy! Dyno time out here is ridiculously expensive, even for only a power check. Last time I was quoted 45,000 yen ($550 USD) for Dynapack setup and only 3 pulls with A/F
Data for the spreadsheet was extrapolated from my Link logs at .1 sec increments. I datalog at 50hz (.02 sec) to keep an eye on knock events but 320 data points doesn't seem to jive too well with Airboy. It looks like 60 points (every .1 sec) works well.
Car feels strong for only 16.5 psi! Pulls from 97 -153 km (60-95 mph) in 3.28 sec from 4th gear. I'll be tuning for higher boost soon; just waiting for a BSP to NPT adapter to get here from McMaster Carr so I can hook the water/meth back up. There is obviously some work left to be done.
Timing tapers off up top. I pulled some timing out due to some false knock triggering caused by a flaky crank sensor. Logs are below, any input appreciated!
Code:
Time	RPM	MAP	IDC	Inj PW	Ign Adv	AVCS LH /RH WideBand   Speed	Knock Level
0	3193	101	17.9	6.752	36.9	31.2	28.7	14.6	70	19
0.02	3199	102	18.1	6.808	36.8	31.4	29.7	14.6	70	19
0.04	3219	103	18.2	6.808	36.8	31.2	29.4	14.4	70	19
0.06	3241	103	18.5	6.867	36.7	30.7	29.8	14.1	70	19
0.08	3243	104	18.7	6.923	36.5	30.6	29.2	13.5	70	19
0.1	3231	104	18.6	6.923	36.5	30.1	29.5	12.8	70	19
0.12	3238	105	18.7	6.98	36.2	30.1	29.4	12.2	70	19
0.14	3245	106	19	7.025	36.1	29.6	29.4	11.7	70	19
0.16	3264	106	16.3	5.988	36.1	29.7	29.3	11.4	70	19
0.18	3268	106	14.4	5.297	36.1	29.5	29	11.1	70	19
0.2	3277	107	14.5	5.336	36.1	29.2	29.4	10.9	70	19
0.22	3277	108	14.7	5.385	35.9	29.3	28.8	10.8	70	19
0.24	3283	108	14.7	5.385	35.9	29	29.2	10.8	70	19
0.26	3284	108	14.8	5.427	35.9	29.1	28.6	10.8	70	19
0.28	3293	109	14.8	5.417	35.7	28.7	28.8	10.9	71	19
0.3	3306	110	15	5.457	35.6	28.7	28.8	11.1	71	19
0.32	3311	110	15	5.457	35.6	28.4	28.8	11.4	71	19
0.34	3316	111	15.2	5.499	35.4	28.5	28.7	11.7	72	19
0.36	3319	111	15.2	5.499	35.4	28.3	28.4	12.1	72	19
0.38	3330	112	15.3	5.529	35.3	28	28.8	12.4	72	19
0.4	3338	112	15.3	5.529	35.3	28.2	28.3	12.7	72	19
0.42	3348	113	15.5	5.569	35.1	28	28.6	13	73	19
0.44	3348	113	15.6	5.611	35	28.2	28.2	13.2	73	19
0.46	3353	114	15.6	5.6	35	27.8	28.2	13.3	73	19
0.48	3360	114	15.6	5.6	35	28	28.2	13.3	73	19
0.5	3370	115	15.8	5.651	34.8	27.7	28.1	13.3	73	19
0.52	3381	115	16	5.681	34.6	27.8	28.1	13.3	73	19
0.54	3386	116	16	5.681	34.6	27.7	27.9	13.4	73	19
0.56	3392	117	16	5.681	34.6	27.4	28.2	13.4	73	19
0.58	3393	117	16.1	5.721	34.5	27.6	27.8	13.4	73	19
0.6	3409	118	16.3	5.761	34.3	27.2	27.8	13.4	73	19
0.62	3419	118	16.4	5.761	34.4	27.4	27.8	13.4	73	19
0.64	3425	119	16.4	5.761	34.4	27.2	27.7	13.4	74	19
0.66	3425	119	16.5	5.803	34.2	27.5	27.7	13.4	74	19
0.68	3434	120	16.7	5.843	34	27.5	27.4	13.5	74	19
0.7	3447	120	16.7	5.832	34	27.1	27.8	13.6	74	19
0.72	3449	121	16.8	5.873	33.9	27.3	27.4	13.6	75	19
0.74	3460	121	16.9	5.862	34	26.8	27.5	13.6	75	19
0.76	3460	122	17	5.924	33.9	27	27.5	13.6	75	19
0.78	3471	122	17.1	5.924	33.9	26.7	27.3	13.6	75	19
0.8	3481	123	17.4	5.998	33.7	26.7	27.3	13.6	75	19
0.82	3494	124	17.6	6.049	33.5	27	26.8	13.7	75	19
0.84	3501	124	17.7	6.072	33.6	26.9	27.2	13.7	75	19
0.86	3501	125	17.9	6.147	33.4	27.1	27	13.7	76	19
0.88	3512	125	18	6.158	33.4	26.9	26.9	13.8	76	19
0.9	3517	126	18.2	6.222	33.2	27.2	27.1	13.8	76	19
0.92	3533	127	18.3	6.222	33.2	27.1	26.8	13.8	76	19
0.94	3547	127	18.6	6.308	32.9	26.9	27.3	13.7	76	19
0.96	3551	128	18.6	6.308	32.7	27.1	27.2	13.7	76	19
0.98	3556	128	18.9	6.385	32.7	26.9	27	13.7	76	19
1	3560	129	19.1	6.462	32.5	27.2	27.2	13.7	77	19
1.02	3574	129	19.3	6.475	32.4	27.2	26.8	13.6	77	19
1.04	3594	130	19.6	6.54	32.2	27	27.4	13.6	77	19
1.06	3597	131	19.8	6.595	32	27.3	27.2	13.6	77	19
1.08	3602	131	19.9	6.63	31.9	27.1	27.1	13.6	78	19
1.1	3597	132	20.1	6.71	31.8	27.3	27.2	13.7	78	19
1.12	3603	133	20.2	6.753	31.7	27.2	26.8	13.7	78	19
1.14	3622	133	20.4	6.777	31.5	26.8	27.3	13.6	78	19
1.16	3635	134	20.7	6.833	31.3	26.9	27.1	13.6	78	19
1.18	3649	135	21	6.926	31	26.6	26.9	13.5	78	19
1.2	3647	135	21.1	6.95	31	26.7	27.2	13.5	78	19
1.22	3661	136	21.3	6.995	30.7	26.9	26.5	13.4	79	19
1.24	3674	137	21.5	7.032	30.6	26.7	26.7	13.4	79	19
1.26	3677	137	21.8	7.113	30.5	27	26.9	13.4	79	19
1.28	3690	138	22	7.156	30.1	27	26.4	13.4	80	19
1.3	3704	139	22.3	7.24	29.9	26.7	27.1	13.4	80	19
1.32	3706	139	22.4	7.265	29.9	26.7	26.8	13.4	80	20
1.34	3713	140	22.7	7.36	29.6	26.3	26.5	13.3	81	19
1.36	3716	141	22.9	7.406	29.5	26.3	26.8	13.1	81	19
1.38	3744	141	23.2	7.444	29.3	26.5	26.1	13	81	19
1.4	3759	142	23.5	7.502	29	26.3	26.3	12.9	81	19
1.42	3756	143	23.6	7.561	28.8	26.7	26.5	12.8	82	19
1.44	3766	144	23.9	7.62	28.5	26.7	26	12.7	82	19
1.46	3778	145	24.1	7.667	28.3	26.4	26.6	12.7	82	19
1.48	3784	146	24.3	7.692	28.2	26.7	26.4	12.8	82	19
1.5	3801	146	24.6	7.764	27.9	26.2	26.2	12.8	82	19
1.52	3814	147	24.8	7.811	27.8	26.2	26.7	12.8	82	19
1.54	3818	148	25.1	7.884	27.5	26.3	26.4	12.8	83	19
1.56	3829	149	25.2	7.897	27.3	26	26.2	12.8	83	19
1.58	3850	150	25.6	8.017	27.1	26	26.5	12.8	83	19
1.6	3855	150	25.9	8.044	27	26.2	25.8	12.7	83	19
1.62	3866	151	26.1	8.12	26.8	25.9	25.8	12.7	83	19
1.64	3866	152	26.4	8.193	26.6	26.2	25.9	12.7	83	19
1.66	3886	153	26.7	8.256	26.4	26.1	25.5	12.7	83	19
1.68	3898	154	27.1	8.331	26.3	25.6	25.7	12.7	84	19
1.7	3898	155	27.3	8.409	26.1	25.8	25.9	12.7	84	19
1.72	3922	156	27.7	8.513	26	25.6	25.3	12.6	84	19
1.74	3938	157	28.1	8.561	25.8	25.2	25.3	12.6	85	19
1.76	3938	158	28.3	8.624	25.7	25.5	25.3	12.5	85	19
1.78	3953	159	28.8	8.729	25.5	25.6	25	12.5	85	19
1.8	3967	160	29.2	8.822	25.4	25.3	25.2	12.5	86	19
1.82	3971	161	29.5	8.913	25.2	25.3	25.2	12.6	86	19
1.84	3991	162	29.8	8.992	25.2	25.1	24.8	12.6	86	19
1.86	4003	163	30.2	9.041	25.5	24.6	24.9	12.7	87	19
1.88	4005	165	30.5	9.155	25.4	24.7	25	12.7	87	19
1.9	4023	166	30.7	9.169	25.4	24.7	24.6	12.7	87	19
1.92	4029	167	31	9.219	25.4	24.5	24.7	12.7	87	19
1.94	4037	168	31.4	9.334	25.3	24.6	24.9	12.7	87	19
1.96	4062	169	31.9	9.428	25.3	24.9	24.4	12.7	87	19
1.98	4076	170	32.3	9.51	25.3	24.8	24.5	12.7	88	19
2	4101	171	32.6	9.59	25.2	24.7	24.8	12.6	88	19
2.02	4100	173	33.2	9.707	25.3	24.9	24.7	12.6	88	19
2.04	4106	173	33.3	9.737	25.3	24.6	24.6	12.6	88	19
2.06	4132	175	34	9.856	25.2	24.4	24.9	12.6	90	19
2.08	4139	176	34.3	9.937	25.2	24.5	24.7	12.6	90	20
2.1	4158	177	34.9	10.068	25.3	24.6	24.3	12.6	90	19
2.12	4175	178	35.4	10.168	25.3	24.4	24.5	12.6	90	19
2.14	4172	180	35.7	10.27	25.3	24.6	24.6	12.6	90	19
2.16	4190	181	36.1	10.336	25.3	24.7	24.3	12.7	90	27
2.18	4207	182	36.6	10.44	25.2	24.4	24.5	12.7	91	37
2.2	4234	184	37	10.51	25	24.2	24.8	12.7	91	20
2.22	4240	185	37.7	10.648	24.5	24.4	24.7	12.6	91	20
2.24	4250	186	38.1	10.768	24.2	24.4	24.5	12.6	92	20
2.26	4274	188	38.7	10.872	23.8	24.2	24.7	12.5	92	30
2.28	4273	190	39	10.942	23.5	24.5	24.5	12.5	92	19
2.3	4299	190	39.8	11.08	23.3	24.7	24.2	12.4	93	39
2.32	4317	192	40.4	11.238	23	24.6	24.4	12.3	93	20
2.34	4344	194	41.3	11.414	22.5	24.4	24.8	12.3	94	20
2.36	4339	196	41.4	11.467	22.3	24.5	24.7	12.2	94	19
2.38	4349	196	42.1	11.628	22	24.6	24.4	12.1	94	19
2.4	4366	198	42.9	11.756	21.7	24.4	24.5	12.1	95	20
2.42	4403	200	44.2	12.044	21.1	24.3	24.9	12.1	95	20
2.44	4408	201	44.6	12.134	21.3	24.6	24.7	12.1	95	36
2.46	4422	202	45	12.209	21.2	24.8	24.2	12.1	96	34
2.48	4441	203	45.4	12.283	21.3	24.7	24.4	12.1	96	20
2.5	4461	207	47.1	12.673	21.4	24.6	24.8	12	96	20
2.52	4489	207	48	12.841	21.5	24.7	24.5	12	96	19
2.54	4508	208	48.7	12.955	21.5	24.5	24.8	12	96	20
2.56	4525	210	49.7	13.22	21.5	24.3	25.2	12	98	91
2.58	4533	210	50	13.225	21.4	24.6	24.8	12	98	30
2.6	4555	210	50.5	13.264	21.3	25	24.4	12	99	22
2.62	4555	211	50.7	13.34	21.3	24.8	24.8	11.9	99	20
2.64	4585	213	51.5	13.476	21.1	24.4	25.3	11.8	99	20
2.66	4597	212	51.5	13.419	21.1	24.3	24.9	11.7	100	24
2.68	4618	212	51.8	13.419	21	24.5	24.4	11.6	100	20
2.7	4631	213	52.3	13.515	21	24.2	24.4	11.6	100	19
2.72	4660	214	52.9	13.593	20.8	23.8	24.7	11.5	101	20
2.74	4657	213	52.6	13.534	20.8	24	24.4	11.4	101	21
2.76	4680	214	53.1	13.612	20.7	23.9	24.3	11.4	101	19
2.78	4709	214	53.4	13.654	20.6	24.3	23.9	11.4	101	19
2.8	4712	215	54	13.732	20.6	23.6	23.9	11.4	101	20
2.82	4728	215	54	13.713	20.6	23.1	24.2	11.4	102	20
2.84	4739	216	54.6	13.792	20.4	23.2	23.8	11.4	102	20
2.86	4769	215	54.9	13.771	20.3	23.3	23.2	11.3	102	22
2.88	4785	215	54.9	13.752	20.2	23.2	23.1	11.3	104	20
2.9	4805	217	55.8	13.91	20.1	22.8	22.9	11.3	104	20
2.92	4843	217	56.4	13.929	19.9	22.4	23.1	11.3	105	21
2.94	4827	217	56.1	13.929	20	22.5	22.8	11.4	105	20
2.96	4833	217	56.1	13.929	19.9	22.3	22.7	11.4	105	21
2.98	4875	217	56.4	13.948	19.8	22.3	22.1	11.4	105	21
3	4877	217	56.8	13.968	19.7	22	22	11.4	105	24
3.02	4895	219	57.8	14.128	19.5	22	21.8	11.4	105	23
3.04	4935	219	58.4	14.147	19.3	21.6	22	11.4	106	20
3.06	4936	219	58.4	14.147	19.3	21.7	21.5	11.4	106	20
3.08	4935	219	58.4	14.147	19.3	21.5	21.4	11.5	108	25
3.1	4970	220	58.8	14.227	19.2	21.4	20.9	11.5	108	69
3.12	4994	219	59.1	14.147	19.1	20.9	20.8	11.5	108	26
3.14	5008	220	59.5	14.208	19	20.8	20.5	11.6	108	22
3.16	5030	221	60.2	14.288	18.9	20.4	20.6	11.6	108	20
3.18	5020	220	59.8	14.246	19	20.5	20.2	11.6	109	20
3.2	5044	219	59.8	14.166	19.1	20.3	20	11.6	109	34
3.22	5067	221	60.2	14.267	18.9	20.5	19.5	11.5	109	20
3.24	5081	220	60.6	14.246	18.9	20.2	19.3	11.5	110	31
3.26	5106	221	61.3	14.307	18.8	19.6	19.4	11.5	110	20
3.28	5127	221	61.3	14.308	18.7	19.5	19.1	11.6	111	23
3.3	5134	221	61.3	14.328	18.8	19	19.2	11.6	111	22
3.32	5131	220	60.9	14.248	18.8	19	18.7	11.6	111	20
3.34	5162	221	61.7	14.268	18.7	18.6	18.4	11.6	112	25
3.36	5201	221	62.1	14.328	18.6	18.6	17.9	11.6	112	22
3.38	5221	221	62.8	14.388	18.6	18.2	17.6	11.5	113	20
3.4	5217	221	62.5	14.328	18.5	17.7	17.5	11.5	113	20
3.42	5217	221	62.5	14.328	18.5	17.3	17.1	11.5	114	28
3.44	5246	222	62.8	14.388	18.5	16.5	17.2	11.5	114	22
3.46	5272	221	62.8	14.328	18.4	16.1	16.7	11.5	114	20
3.48	5290	221	63.2	14.328	18.4	15.6	16.4	11.5	115	22
3.5	5313	222	63.6	14.328	18.4	15.4	15.8	11.5	115	44
3.52	5314	220	63.2	14.268	18.4	15.1	15.6	11.5	115	31
3.54	5313	221	63.6	14.328	18.3	15.1	14.8	11.5	115	27
3.56	5344	221	64.1	14.328	18.3	14.5	14.3	11.4	116	33
3.58	5378	221	64.5	14.388	18.2	14.1	14.1	11.4	116	34
3.6	5395	221	64.5	14.328	18.2	13.5	13.6	11.3	116	22
3.62	5417	222	64.9	14.388	18.1	13.1	13.2	11.3	117	21
3.64	5420	222	65.3	14.388	18.1	12.2	13.3	11.3	117	46
3.66	5434	221	64.9	14.328	18.1	11.7	12.8	11.3	118	30
3.68	5453	221	65.3	14.328	18.1	11.2	12.3	11.3	118	33
3.7	5463	221	65.3	14.328	18.1	11.1	11.8	11.3	119	31
3.72	5482	221	65.7	14.328	18	11	11.5	11.4	119	32
3.74	5503	221	65.3	14.248	18	10.4	11.1	11.3	119	30
3.76	5500	221	65.7	14.328	18	10.6	10.2	11.3	119	23
3.78	5526	220	66.2	14.308	18	10	9.9	11.3	119	30
3.8	5539	220	65.7	14.248	18	9.5	9.3	11.3	120	43
3.82	5568	220	66.6	14.289	18	9.3	9	11.3	120	27
3.84	5610	221	67.1	14.268	18	8.7	8.9	11.3	122	23
3.86	5615	220	66.2	14.169	18	8.4	8.6	11.3	122	24
3.88	5615	220	66.6	14.193	18	8.1	8.3	11.3	122	24
3.9	5659	221	66.6	14.174	18	7.8	7.9	11.3	122	27
3.92	5690	220	67.1	14.155	18	7.4	7.4	11.2	122	44
3.94	5664	221	66.6	14.056	18.1	6.9	7.7	11.2	123	29
3.96	5674	220	67.1	14.115	18	6.7	7.3	11.2	123	38
3.98	5683	220	66.6	14.056	18.1	6.3	7.1	11.2	123	63
4	5695	219	66.6	14.035	18.1	5.8	6.9	11.3	123	38
4.02	5733	219	67.1	14.016	18.1	5.4	6.5	11.3	124	44
4.04	5749	218	67.1	13.936	18.1	5.2	5.9	11.3	124	47
4.06	5749	218	67.1	13.916	18.1	4.8	5.5	11.3	126	26
4.08	5765	218	67.1	13.916	18.1	4.5	5.1	11.3	126	23
4.1	5778	218	67.1	13.897	18.1	4.5	4.7	11.3	126	118
4.12	5806	218	67.5	13.897	18.1	4.1	4.5	11.3	126	62
4.14	5819	219	67.5	13.878	18.1	3.6	4.2	11.3	127	60
4.16	5835	218	67.5	13.838	18.1	3.4	4	11.3	127	43
4.18	5852	217	67.5	13.838	18.2	3	3.7	11.3	127	86
4.2	5859	217	67.5	13.779	18.2	2.7	3.5	11.3	127	54
4.22	5875	217	67.5	13.8	18.2	2.2	3.2	11.4	127	65
4.24	5896	218	68	13.819	18.1	2	3	11.4	128	47
4.26	5909	217	68	13.76	18.2	1.7	2.9	11.4	128	105
4.28	5922	217	68	13.74	18.2	1.4	2.4	11.4	129	38
4.3	5942	217	68	13.702	18.2	1.1	2	11.4	129	53
4.32	5959	217	68.4	13.721	18.2	1	1.7	11.4	129	30
4.34	5973	216	68	13.681	18.2	0.6	1.3	11.5	129	44
4.36	5977	216	68	13.643	18.2	0.5	1	11.4	130	36
4.38	6001	217	68.4	13.702	18.2	0	0.6	11.4	130	97
4.4	6025	216	68.4	13.624	18.2	0.2	0.4	11.4	130	68
4.42	6036	217	68.9	13.681	18.2	0	0.2	11.4	130	75
4.44	6046	217	68.9	13.643	18.2	0	0.1	11.4	132	38
4.46	6046	216	68.9	13.624	18.2	0	0.1	11.4	132	48
4.48	6067	217	68.9	13.624	18.2	0	0	11.4	132	55
4.5	6091	217	68.9	13.604	18.2	0	0	11.4	132	64
4.52	6099	217	68.9	13.564	18.3	0	0	11.4	133	65
4.54	6109	217	68.9	13.468	18.3	0	0	11.4	133	64
4.56	6135	217	69.4	13.507	18.3	0	0	11.4	133	72
4.58	6139	217	68.9	13.449	18.3	0	0	11.4	133	36
4.6	6157	217	69.4	13.486	18.4	0	0	11.4	133	44
4.62	6175	217	69.9	13.507	18.4	0	0	11.4	133	66
4.64	6200	217	69.4	13.408	18.5	0	0	11.4	135	86
4.66	6198	218	69.4	13.408	18.5	0	0	11.4	135	50
4.68	6216	218	69.9	13.484	18.4	0	0	11.4	135	44
4.7	6241	219	69.9	13.465	18.4	0	0	11.3	135	66
4.72	6264	218	70.4	13.427	18.5	0	0	11.3	136	31
4.74	6279	219	69.9	13.35	18.5	0	0	11.3	136	55
4.76	6302	219	70.9	13.424	18.6	0	0	11.3	137	72
4.78	6279	217	69.9	13.272	18.6	0	0	11.3	137	63
4.8	6287	218	70.4	13.387	18.6	0	0	11.4	137	44
4.82	6306	217	70.4	13.328	18.7	0	0	11.4	137	48
4.84	6325	217	70.4	13.308	18.7	0	0	11.5	138	82
4.86	6349	217	70.4	13.252	18.7	0	0	11.5	138	123
4.88	6368	218	70.9	13.289	18.8	0	0	11.5	138	98
4.9	6379	217	70.9	13.326	18.8	0	0	11.5	138	51
4.92	6371	217	70.4	13.212	18.8	0	0	11.5	139	53
4.94	6388	218	70.4	13.193	18.8	0	0	11.5	139	60
4.96	6408	217	70.4	13.136	18.8	0	0	11.5	140	103
4.98	6449	219	70.4	13.115	18.9	0	0	11.4	140	55
5	6467	219	70.9	13.171	18.9	0	0	11.4	140	80
5.02	6463	218	70.9	13.132	19	0	0	11.4	141	73
5.04	6469	218	71.4	13.168	19	0	0	11.4	141	66
5.06	6490	218	70.9	13.092	19	0	0	11.4	141	78
5.08	6519	217	70.9	13.073	19	0	0	11.3	141	47
5.1	6519	217	71.4	13.017	19	0	0	11.3	142	59
5.12	6530	217	70.9	13.017	19	0	0	11.3	142	79
5.14	6539	218	71.4	13.073	19	0	0	11.4	142	77
5.16	6585	218	71.4	13.017	19.1	0	0	11.4	142	46
5.18	6592	218	71.9	13.033	19.1	0	0	11.4	142	46
5.2	6590	218	72.4	13.089	19.2	0	0	11.4	142	53
5.22	6606	217	71.4	12.96	19.2	0	0	11.5	144	117
5.24	6611	217	71.4	12.94	19.2	0	0	11.6	144	70
5.26	6644	217	71.4	12.9	19.3	0	0	11.6	145	46
5.28	6653	216	71.9	12.92	19.2	0	0	11.6	145	57
5.3	6656	217	71.9	12.92	19.3	0	0	11.7	145	42
5.32	6665	216	70.9	12.792	19.3	0	0	11.7	145	42
5.34	6703	217	72.4	12.881	19.4	0	0	11.6	145	53
5.36	6718	217	71.4	12.787	19.4	0	0	11.7	146	86
5.38	6698	217	71.9	12.862	19.4	0	0	11.7	146	63
5.4	6713	216	71.9	12.803	19.5	0	0	11.6	146	72
5.42	6725	216	71.9	12.748	19.4	0	0	11.6	146	58
5.44	6742	215	71.9	12.822	19.5	0	0	11.6	147	84
5.46	6773	216	71.9	12.729	19.5	0	0	11.5	147	63
5.48	6773	216	71.9	12.675	19.5	0	0	11.5	148	33
5.5	6795	216	72.4	12.71	19.6	0	0	11.5	148	55
5.52	6808	216	71.9	12.636	19.6	0	0	11.5	148	73
5.54	6808	215	71.9	12.598	19.6	0	0	11.5	148	69
5.56	6823	215	71.9	12.651	19.7	0	0	11.6	148	76
5.58	6828	215	71.9	12.598	19.7	0	0	11.6	149	58
5.6	6853	215	71.9	12.598	19.7	0	0	11.6	149	63
5.62	6868	215	71.9	12.579	19.7	0	0	11.6	149	40
5.64	6875	215	72.4	12.579	19.8	0	0	11.5	149	43
5.66	6885	215	72.4	12.558	19.8	0	0	11.5	150	61
5.68	6908	215	72.4	12.5	19.8	0	0	11.5	150	74
5.7	6903	214	71.9	12.467	19.8	0	0	11.6	151	64
5.72	6931	215	72.4	12.52	19.8	0	0	11.6	151	47
5.74	6944	215	72.4	12.52	19.9	0	0	11.7	150	139
5.76	6954	215	72.4	12.5	19.9	0	0	11.8	151	62
5.78	6954	215	72.4	12.481	19.9	0	0	11.8	151	76
5.8	6967	214	72.9	12.481	20	0	0	11.9	152	57
5.82	6967	214	72.4	12.409	20	0	0	11.9	152	121
5.84	7001	215	72.9	12.462	20	0	0	11.9	153	55
5.86	7030	215	72.9	12.457	20	0	0	11.9	153	42
5.88	7035	216	72.9	12.438	20	0	0	11.9	153	87
5.9	7025	215	72.9	12.419	20	0	0	11.9	153	87
5.92	7025	214	72.9	12.438	20	0	0	11.8	153	63
5.94	7062	213	72.9	12.331	20	0	0	11.8	154	64
5.96	7072	214	72.4	12.273	20	0	0	11.7	154	100
5.98	7096	215	73.5	12.419	20	0	0	11.6	154	54
6	7102	214	73.5	12.38	20	0	0	11.6	154	143
6.02	7096	214	72.9	12.328	20	0	0	11.6	155	76
6.04	7121	214	73.5	12.38	20	0	0	11.6	155	71
6.06	7131	214	73.5	12.328	20	0	0	11.6	155	79
6.08	7145	215	72.9	12.236	20	0	0	11.6	155	72
6.1	7151	215	73.5	12.34	20	0	0	11.6	155	112
6.12	7159	214	73.5	12.34	20	0	0	11.6	156	110
6.14	7181	213	72.9	12.179	20	0	0	11.6	156	78
6.16	7194	214	72.9	12.179	20	0	0	11.7	157	59
6.18	7183	215	74	12.302	20	0	0	11.8	157	89
6.2	7200	214	73.5	12.211	20	0	0	11.8	157	107
6.22	7219	214	73.5	12.23	20	0	0	11.8	157	120
6.24	7233	215	73.5	12.23	20	0	0	11.8	157	75
6.26	7239	215	74.6	12.244	20	0	0	11.8	157	82
6.28	7244	214	74.6	12.264	20	0	0	11.8	157	122
6.3	7270	213	73.5	12.121	20	0	0	11.8	158	78
Ryan23 is offline   Reply With Quote
Old 02-06-2011, 12:37 AM   #2
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
when you say 93 octane, are you using 98ron octane? Can't wait to see the boost get to 24lbs or so
scoobystas is offline   Reply With Quote
Old 02-06-2011, 12:49 AM   #3
Ryan23
Member#: 15116
EJ257/GT35R
It's "base gas", which is rated at the pump as 93 R+M/2 (same as US). It's currently $3.03 a gallon. Japanese hai-oku (100 Ron) is about $7 usd a gallon.
Meth is cheaper
Ryan
Old 03-09-2011, 04:25 AM   #4
Mohammadov
Member#: 110160
2005 STI+JDM V7 Swap
Man your log is very detailed,i mean u got good rpm log,how did u do it?did u use RomRaider for logging?
Mohammadov is offline   Reply With Quote
Old 03-09-2011, 04:28 AM   #5
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
nice numbers..
Old 03-09-2011, 04:52 AM   #6
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
He has a Link Ecu. It has onboard logging.
Old 03-09-2011, 04:54 AM   #7
Mohammadov
Member#: 110160
that ecu has a fast CPU
Old 03-09-2011, 08:13 AM   #8
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Good numbers on the low boost. However I think your tune is VERY conservative. You run 18 degr. of timing through peak torque and hardly increase timing towards the topend. I think more can be had there.
I think you can run more boost on AKI ((R+M)/2)) 93 Octane but I would definitely go richer on the AFRs. I have seen too many failures at 11.6 ~ 11.8 AFR full bore pumpgas tunes. They make lots of power but usually results in melted pistons down the road. Better to give up a few BHP for more safety. Are you watching EGTs?
Gotta love Stand Alone SD systems They are very nice to tune and have awesome logging capabilities. After getting spoiled with all the nice features you wish that was the first mod you bought
Jasper Kopinga
CS Racing
Taiwan.
jkopinga is offline   Reply With Quote
Old 03-09-2011, 08:14 AM   #9
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
OP you have a very nice set up. I'm still puzzle as to how you can run that much timing and not see any knock on 93 octane. It's probably dude to the low boost and the turbo working at a high efficiency but i think once you raise the boost on pump your timing has to be lowered a good amount. This car hits peak torque at almost 5000 rpm and you are running 19* of timing which is way too much unless you are running better fuel or meth and your AFR is in the mid 11's. I suggest you do a pull from lower RPM between 2000 and 2500 rpm all the way to readline to compare.
Wil
wil06STI is offline   Reply With Quote
Old 03-09-2011, 09:11 AM   #10
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
^^^ 18~19 degr. of timing is quite high indeed. Just remember that this engine is running enlarged chambers on the EJ207 heads AND is running large duration cams which lowers dynamic compression even more. TBH, ignition advance figures are not that meaningful and are really dependant on the setup. Some engines make very good power on low advance figures (11~12s peak TQ and 15~16s Peak HP) and some engines are just more "Timing hungry" requiring 18s through peak TQ and upto 28s Peak HP.
OP, what is the static compression of this engine?
Jasper.
Old 03-09-2011, 10:06 AM   #11
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
Jasper.
I agree that each setup is different and that some can run more or less timing than others but he is using a USDM shortblock so the only major difference from most USDM Sti is the EJ207 heads machined to 99.5mm. We know they are better than USDM Sti heads and we know that most USDM Stis running 93 octane run very similar timing profile with similar size turbo. I think the heads are making a huge difference or the low boost is the reason he can run that much timing.
Wil
Old 03-09-2011, 05:13 PM   #12
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Nice work, but watch that AFR...
Spenk is offline   Reply With Quote
Old 03-22-2011, 06:41 AM   #13
Ryan23
Member#: 15116
EJ257/GT35R
Thanks for the input guys. Just saw this thread again, been kinda "busy" over here in Japan. The car is still running well although I still haven't got the meth hooked up. The meth fitting came in but I've been busy with other things.
The timing curve was lifted from my previous EJ207 tune and tweeked while monitoring knock via detcans & Link's built in knock logic with a Bosch Motorsports KS-P knock sensor. I'm also running Cossie pistons. A few folks who have tuned engines with Cossie pistons have noted they could get away with a little more advance over the standard slugs. Can't state if that's fact, just relaying my logs here. Tune has been richened up a tad throughout the top end.
IIRC, static compression was calculated ~8.7:1 after cc'ing the heads.
Ryan
Old 03-22-2011, 10:13 AM   #14
Jeremy05sti
Member#: 142040
2005 STI
HTA Twisted
add a little more fuel up top, I would start at 4k rpm and start bringing your timing down to around 13-15 @ 5k rpm then start adding from there to redline and look for around 22-24 degrees (little bit at a time) at the top
Jeremy05sti is offline   Reply With Quote
Old 04-15-2011, 06:35 PM   #15
666stars
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd 5 speed now!
How do you like the kelfords? I'm getting ready to put kelford 264's in my ej207 w/ tomei 20G and water /meth inj
666stars is offline   Reply With Quote
Old 04-16-2011, 06:37 PM   #16
RUBASUREX
Member#: 186063
04 fxt
gold
Dam nice for such low boost
RUBASUREX is offline   Reply With Quote
Dyno Tune: 2.5L + ATP GT3076r .82ar makes 301kw/409hp ATW @23psi SanMan Proven Power Bragging 4 01-27-2011 10:59 AM
EQ Stage 1 Shortblock, EQ Stage 2 Heads, ATP 35R Stock Location, 91 + Meth = 450whp! Equilibrium Tuning Proven Power Bragging 28 01-20-2010 02:30 PM
FS: SO CAL 02 WRX 2.5L GT32 Turbo 313 WHP Hybrid22l Private Vehicle 'For Sale' Classifieds 8 02-04-2008 03:41 PM
World One 2.5L Short Blocks 500 WHP Capable. Stages I, II, III, and IV. WorldOne Engine/Power/Exhaust 5 04-26-2005 02:22 PM
STi 2.5L engine MAF tube - same inner diametre as ver5/6? Llama Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-13-2004 08:10 PM
