Old 02-06-2011, 01:56 AM   #1
offcambersm
Member#: 244248
Default part number for an aluminum thermostat housing?
...for a 2004 impreza outback sport 2.5L?
trying to avoid replacing the plastic one every time i change the thermostat.
thanks
offcambersm is offline   Reply With Quote
Old 02-06-2011, 02:42 AM   #2
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Why are you replacing the plastic one?
BAN SUVS is offline   Reply With Quote
Old 02-06-2011, 02:57 PM   #3
offcambersm
Member#: 244248
because it warps and leaks if you reuse it when you put in a new thermostat
Old 02-06-2011, 10:29 PM   #4
bobbyjimmy
Member#: 114012
2002 Outback
Your doing it wrong then.
I've still got my original plastic one on the car from when it was new in 2002 and 10+ coolant changes.
bobbyjimmy is offline   Reply With Quote
Old 02-06-2011, 11:03 PM   #5
grafton
Member#: 187936
07 WRB STi
I'd like an aluminum housing just for the awesomeness of it
so +1 for the part number
grafton is offline   Reply With Quote
Old 02-07-2011, 12:24 AM   #6
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
11060AA071
Phase 1 2.2 should be metal. I have to agree with bobbyjimmy though if yours is "warping" you're doing something wrong.
Old 02-07-2011, 08:34 AM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Another vote for "you're doing it wrong".
Old 02-07-2011, 02:42 PM   #8
grafton
Member#: 187936
07 WRB STi
Originally Posted by BAN SUVS View Post
11060AA071
thank you, my phase 1 lego had a plastic one, oh well.
OP if you are having leaks, are you using an OEM thermostat gasket? I used one that came with a timing belt kit and coolant pissed out the housing, the gasket was visibly too thin when compared to the oem gasket.
Old 02-07-2011, 03:59 PM   #9
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Fair warning, I really don't know for sure that part number is metal and not plastic. It's just the oldest 2.2 water neck so I'm going on assumption.
Old 02-07-2011, 04:44 PM   #10
offcambersm
Member#: 244248
i'm actually just going off what my friend told me i should do i.e. get a metal one or always replace the plastic one. She has worked on numerous subies and knows them in and out...maybe here in TX the coolant doesn't cool down enough before entering the housing.
results may vary, yada yada yada.
Mine is metal but i'm ordering parts for my friend...
Old 02-07-2011, 04:58 PM   #11
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
The one on your 2004 TS is metal? If so the part number is the same as what I listed before. So it's metal.
Old 02-07-2011, 07:27 PM   #12
offcambersm
Member#: 244248
no, the the 04 obs is my friends car. the metal one on my motor is out of a 98 2.2 i bought to replace the blown motor in my 96 L that i'm rebuilding. the guy i bought it from worked at a dealership so he may very well have replaced it himself...making sure to get a metal housing. i guess i need to contact him.
talked to my other friend and she said the warping can be caused by a previous owner over torquing a plastic one. plastic does dissipate heat better though...
Old 02-08-2011, 10:21 AM   #13
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Well, apparently she knows something that nobody else that works on Subarus knows. I've read lots and lots of threads about head gasket fixes, timing belt changes, water pump replacements, etc, and have never heard anyone mention anything about replacing the factory plastic thermostat housing with a metal one. I didn't even know a "normal" metal one existed - the only metal thermostat housing I know of is the one that has the additional hose nipple for the OEM oil cooler (as seen here on scoobymods.com).
Not even close. Plastic is an insulator. Aluminum is literally about 1000x better at dissipating heat. Not that the heat dissipation ability of the thermostat housing matters in the slightest.
Part number for control arms? poly_poly-man Brakes, Steering & Suspension 1 02-05-2011 03:54 PM
Part Number for Front Bushing for STi Aluminum Control Arm? kpluiten Brakes, Steering & Suspension 8 01-19-2011 05:21 PM
Thermostat housing part number for oil cooler? tmeh Normally Aspirated Powertrain 4 02-24-2008 10:30 AM
Part number for thermostat gasket? skubie209 Service & Maintenance 3 04-19-2005 06:29 PM
Anybody know the correct part number for an alternator-only belt on UR pulley? P.K. Motorsports Normally Aspirated Powertrain 0 11-14-2000 02:16 PM
