Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 02-06-2011, 02:39 PM   #1
soob noob
Member#: 220158
02 bugeye
medamullet tuned
Default wideband question...
So i bought the LC-1 innovate Wideband from Jason(medamullet) about a year ago. Its worked great since i installed it a year ago although i did have to re-calibrate it once.
lately i start my car and it blinks 7.4 like usual and then starts reading. sometimes after i drive for a little bit something freaks out and it starts blinking 7.4 again and wont go back reading until i start my car again.
do i just need to re-calibrate it again? is my sensor going bad? I dont know whats going on
soob noob is offline   Reply With Quote
Old 02-06-2011, 03:11 PM   #2
azn2nr
Member#: 35276
its probably loosing the signal
azn2nr is offline   Reply With Quote
Old 02-06-2011, 04:32 PM   #3
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Double check your wiring, especially your ground.
907Bum is offline   Reply With Quote
Old 02-06-2011, 04:48 PM   #4
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Agreed on the grounding, really sensitive to a decent ground, did you run a deddicated ground or link into an already used line?, Run a nice fresh ground just for your WB from the block or simular, yank it and fresh air cal it... I used to do mine every couple months as a matter of course.
Kastley85891 is offline   Reply With Quote
Old 02-06-2011, 06:14 PM   #5
soob noob
Member#: 220158
02 bugeye
medamullet tuned
The ground is a fresh ground it's not tied into anything..but I'll make sure the bolt holding it down didn't come loose.
Also I'll re-calibrate it to. Hopefully that fixes it
Old 02-06-2011, 07:24 PM   #6
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Just clean up under the connection point also, I had some crud under mine once and it caused intermittant crap.
When you talk to it with the innovate software, just make sure it is still set for 14:7.1 gasoline.... mine changed out of mode a couple times and gave the silly 7 error
Old 02-06-2011, 09:47 PM   #7
soob noob
Member#: 220158
02 bugeye
medamullet tuned
alright ill try messing with the ground and calibrating it again. if that doesnt work ill have to get ahold of jason so he can check that part out
Old 02-07-2011, 12:18 AM   #8
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I have a couple of sensors if you want to see if it's bad. Usually if the sensor is bad it will flash a different error. You need to look at the little LED and see how many flashes it does. I believe there are 1-7 blinks in a row before a pause that will indicate what is going on. Look in you rlogworks folder on your computer for the instructions. the very last page is the trouble shooting and blink look up chart.
Usually the flashing means bad ground though.
medamullet is offline   Reply With Quote
Old 02-07-2011, 09:45 PM   #9
soob noob
Member#: 220158
02 bugeye
medamullet tuned
alright next time it does it ill count how many times the LED blinks.. it hasn't blinked since saturday night so we'll see what it says next time
Old 02-08-2011, 10:49 AM   #10
soob noob
Member#: 220158
02 bugeye
medamullet tuned
So the LED started blinking today. And I counted 8 times in between each pause. In the manual that says that the "sensor timing error (typically a damaged sensor)" so did I fry my sensor?
Where can I buy a new one and how much
Old 02-08-2011, 01:40 PM   #11
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
I just went though this the other night! The replacement part number is a bosch: 17014
http://www.amazon.com/Bosch-17014-Oxygen-Sensor-Fitment/dp/B000BZI4ZWhttp://www.amazon.com/Bosch-17014-Oxygen-Sensor-Fitment/dp/B000BZI4ZW
And Autozone/checker etc has them. They are all around 50 bucks, not to shabby imo!
Old 02-08-2011, 01:47 PM   #12
soob noob
Member#: 220158
02 bugeye
medamullet tuned
awesome! thanks man
does this happen often? ive only had this on my car for about a year...
Old 01-14-2012, 11:13 PM   #13
Mush04
Member#: 191705
2007 Limited STi
Swp
Hey I'm bringing this thread back cause I just installed my wideband and seem to be getting some crazy lean readings, I ran a dedicated ground to the block (maybe I did this "wrong"?) and got power from my clock wire, which by the way anyone know how many volts that is? my instructions say I need a 10-18 volt power and utilizes a 10A fuse. So either I'm runnig extremely rich or somethings not connected right.......
so any info/ help would be awesome cause if I actually am running as rich as it says I'm in trouble haha
Mush04 is offline   Reply With Quote
Old 01-14-2012, 11:22 PM   #14
soob noob
Member#: 220158
02 bugeye
medamullet tuned
Did you calibrate it?
Old 01-14-2012, 11:39 PM   #15
Mush04
Member#: 191705
2007 Limited STi
Swp
well it said the factory setting was P0 which is just normal A/F ratio operation??? is there a calibrating process that the manual doesn't really say?
Old 01-15-2012, 12:01 AM   #16
Mush04
Member#: 191705
2007 Limited STi
Swp
In fact I was just reading through the manual and it says something about a laser trimmed somethin somethin which replaces the traditional "free air" calibration....
Old 01-15-2012, 01:59 AM   #17
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
calibrate the sensor, but i'm thinking you could use a different ground. My LC-1 was grounded to the chasis, worked well
Old 01-15-2012, 02:22 AM   #18
Mush04
Member#: 191705
2007 Limited STi
Swp
Do I just need to take the sensor out in fresh air and turn the key on? Ill look for another ground tomorrow.
Hydra/wideband question masiolli Other Engine Management 2 04-21-2005 11:05 AM
wideband question Dissectional Engine Management & Tuning 4 12-25-2004 03:08 AM
Tuner wideband question. Houdini Engine Management & Tuning 25 05-23-2004 03:08 PM
Different types of WideBands...question Eric1855 Engine Management & Tuning 1 03-27-2004 03:16 PM
Techedge Wideband Question WRC 555 Engine Management & Tuning 4 05-08-2003 04:06 PM
