Old 02-06-2011, 02:46 PM   #1
RR
Member#: 48191
2012 WRX
Ducati Monster
Default Need help identifying a plug and a hose
I've been having problems with idle, hesitation, and fuel economy since reinstalling this engine. There are a couple things I am unclear on, and need help figuring out what they are and how they should be connected.
First up, what is this plug?
Currently, it is plugged into this:
Which then goes nowhere, this has to be a problem.
On the original (to me) setup this was connecting to a home depot style CAI. At first I had this connecting to the airbox but in troubleshooting, I pulled it off to connect the hose in the last picture of this thread. Symptoms remained the same with either configuration.
Next up, I am looking for the correct plumbing for this valve:
Currently I have it running like this:
In case its not clear, the valve at the top of the engine bock splits to connect to the air box and to a metal valve (PCV?) on the intake manifold.
RR is offline   Reply With Quote
Old 02-06-2011, 05:14 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Your PCV hose is correct. What does the part inside the hose look like? As you can probably tell, subaru give you just enough wire to connect things, try looking in the radius of the plug/mystery piece.
See where the vacuum hose goes to the fuel pressure regulator? Look underneath there. There is a valve that does....something for emissions. It's bolted to the underside of the intake manifold, is that it?
Old 02-06-2011, 05:35 PM   #3
RR
Member#: 48191
2012 WRX
Ducati Monster
I replaced the PCV valve a couple weeks ago, i'm just not sure that hose should be splitting and going to the airbox or if it should just be running from the block to PCV.
Old 02-08-2011, 10:19 AM   #4
RR
Member#: 48191
2012 WRX
Ducati Monster
bump, still trying to figure this out.
Need help identifying hose. SLOMatt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-07-2008 12:36 AM
Exhaust I need help identifying this and its for sale. robsta1 SCIC Private Classifieds 6 01-15-2008 12:55 PM
Need help identifying springs and tophats jameslippert Brakes, Steering & Suspension 10 07-23-2006 06:07 PM
I need help identifying a song. (in New Jack city and I think in CB4) Eric SS Off-Topic 18 09-25-2002 11:17 PM
Need help identifying a hose. SleeperWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-01-2002 07:39 PM
