Old 02-06-2011, 03:11 PM   #1
cassinelli23
Member#: 198655
2011 STI
Default knock knock whose there? CEL!
ok my sister has 2002 2.5rs with 180k on it. the car had run great all along except a few months back the car over heated... seemed like a random event. last month the car over heated on her again and she parked it because everyone had said it was a head gasket. Until i got to look at the car myself thats what i thought too, that the heads were just expanding when it was driven hard. I dug the car out of the months worth of snow and drove it all day yesterday. The car ran fine except for the following CEL codes. That went away then came back at one point.
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0156 Oxygen Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 Oxygen Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
P1872 Rear Left ABS Sensor Signal.... im not sure if thats right?
all of these codes seem related to the car knocking but it seems like just replacing the sensor wont be the fix
cassinelli23 is offline   Reply With Quote
Old 02-06-2011, 04:19 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Where did you pull those codes from because the only one that applies to a Subaru is P0328
The rest do not apply there is no bank 2 sensor 2 on an RS, nor bank 2 sensor 3
and there is no 1872 code.
Old 02-06-2011, 04:26 PM   #3
cassinelli23
Member#: 198655
2011 STI
i got the the codes(the numbers) off of my accessport for my wrx. the definitions i pulled from a website because it was easier to copy and paste. the banks arent right and just the definitions are i believe. ill get the real codes up in a bit
Old 02-06-2011, 04:39 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
access port is a terrible code reader.
Those are standard OBDII codes, they just do not apply to a 2002 RS.
P0156
P0157
P0063
P1872
Go get a real code reader or go to an autozone and have them pull the codes.
The only one that applies is P0328 which is for knock sensor circuit issue. Do some searching on here there is plenty of info as it is a common code.
Old 08-24-2011, 12:22 AM   #5
sparkyL
Member#: 263343
01 2.5rs
I just pulled the codes from my 2001 2.5rs with an accessport when the CEL came on. As well as the code that I'm presuming is the one I need to address (P0420 - catalyst), I got the same codes P0156, P0157, P0063 and P1872.
sparkyL is offline   Reply With Quote
Knock knock. Who's there? The Dayman Off-Topic 17 09-26-2008 04:11 PM
Knock knock! Who's there? SWAT Team, LOL! aod Off-Topic 31 10-17-2007 06:33 PM
*knock knock* Who's there? j/k We're the police with a warrant! fuzzycuffs Off-Topic 116 11-03-2006 11:33 AM
my first utec log. knock knock, who's there Rickyh Engine Management & Tuning 4 10-13-2004 06:14 PM
Knock Knock.....who's there? ScoobieSnaX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-11-2002 04:46 PM
