Old 08-23-2011, 01:47 PM   #1
bako
Member#: 226211
2002 impreza WRX JDM
blue
Default 5w40 VS 10W40 synthetic
Hi everyone!
I have rebuilt ej205 with stock internals.
cranck is stock in pair with acl aluminum std size bearings.
clearances are: main: 0.025 - 0.03mm
rod: 0.035 - 0.04mm
now I'm breaking in my engine, but want to know about oil, I will use after. we know that good 40 grade oil is good for that clearances, and I have choice between mobil 5w40 and mobil delvac 10w40 synth. (I work in the company which is official importer of Mobil 1 in my country)
the car is DD, with some autocross or track days max once a month. I have short trips everyday, like 5-10 miles (my work is too close from my home)
one case is pressure on hot idle, but: for more adequate choosing, on what rpm should ej205 hit bypass valve pressure 6.2 bar (about 80psi)?
bako is offline   Reply With Quote
Old 08-23-2011, 06:04 PM   #2
gpshumway
Member#: 43950
07 WRX LTD Wagon
It sort of depends on your location (temperature). The 5w40 should be better for cold starts, but it basically won't matter if you live in Southern Spain.
As to the bypass pressure, that's going to have a lot to do with the oil temperature. The thermostat regulates the coolant to a much narrower range than the oil, so on a hot day at the track you might see bypass pressure at 6,000 RPM while a cold day in the Alps you might hit bypass pressure at 4,500.
Its hard to pick an oil which will be good for both short trips and track days, but my advice is don't over think it, just go with the 5w40 and do an oil analysis for peace of mind.
gpshumway is offline   Reply With Quote
Old 08-23-2011, 08:20 PM   #3
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
The less your oil pump bypasses, the more oil (flow) gets to the engine. I would suggest a quality 5W40.
bulwnkl is offline   Reply With Quote
Old 08-24-2011, 03:13 AM   #4
bako
Member#: 226211
blue
yes, I mean the problem of pressure vs oil flow, we all know beside of 40 grade same technologycal and quality 10w40 always will be thicker than 5w40 in this case
Rotella T 5W40 Vs. Royal Purple 5W30 Dirty25RS Service & Maintenance 167 09-26-2011 08:43 AM
5w40 or 10w40????? wadud Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 10-13-2010 10:09 PM
Quick Question: 5W40 or 10w40 kwan_1104 Newbies & FAQs 1 04-01-2008 11:18 PM
Oil 10W30 Vs 10W40 salaki Texas Impreza Club Forum -- TXIC 11 05-12-2005 06:14 PM
Mobil One vs. other synthetics AaronBBrown Service & Maintenance 81 12-18-2002 12:03 AM
