Welcome to the North American Subaru Impreza Owners Club Tuesday May 31, 2016
Old 08-23-2011, 10:33 PM   #1
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
Default Burning off diff fluid, is this possible?
So while getting my front 02 sensor replaced at a shop today (OEM crapped out at 62K), I was informed I was low on diff fluid, about a quart too low.
I had my 60K service done at 52K when my 4eat was rebuilt and the diffs were filled with Motul stuff, whatever they had at the shop. I ran Amsoil stuff until then, but they didn't see the Amsoil gear fluid among the Amsoil ATF and oil that I brought with me for the 60K service.
Is it possible to lose so much within 10K miles? Does diff fluid burn off the same way as motor oil? In all honesty, I never bother to check it between maintenace intervals, only check oil levels religiously.
It might have been low from the get go at 52K as I was informed that my ATF was overfilled, so it might be shop carelessness to begin with.
eurospek is offline   Reply With Quote
Old 08-23-2011, 10:39 PM   #2
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
It will leak, but there's nowhere for it to burn off. Motor oil can seep into the combustion chamber. If your gear oil is getting into the combustion chamber, you've got some serious issues.
But seriously, a 4eat front diff only holds 1.2-1.4 quarts of lube, I would think you've got problems if it's empty.
CosmoTheCat is offline   Reply With Quote
Old 08-23-2011, 10:45 PM   #3
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
What's the rear diff fluid capacity?
Edit:
Found them! For the 4eat:
Rear Diff = 1.7 pints or .85 qts
Front Diff = 2.7 pints or 1.35 qts
Burning a DVD for free? Is this possible?!?!! MattDell Off-Topic 12 09-04-2006 01:29 AM
o.e mt and diff fluid is syn? newbie sewbie Transmission (AT/MT) & Driveline 2 01-23-2003 02:06 AM
Is this possible? Die Civic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 03-27-2001 12:07 AM
is this possible? trojan9x General Forum Archive 14 03-16-2001 12:01 AM
Building a B4 Legacy - is this possible with a MY'00 Legacy? Pls help... Mr. Jones Legacy Forum 4 11-03-2000 08:33 AM
