Old 02-06-2011, 06:02 PM   #1
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
Default 01 OBW wont start, really odd
Ok so the wifes 01 Outback wont start. She put gas in on tuesday, drove it tues, wed, thurs, Friday morning it just would crank no start.
I have tried the following,...
Swaped out fuel filter
Checked fuel pressure coming out of fuel filter-ok
Swapped out fuel pump ( was my old working pumping from my wrx that I took out when I did my turbo swap )
It will sputter itself out quickly if it does try to turn over
If I spray MAF cleaner in the Butterfly and then turn the car over it runs, although rough for 3-5 seconds.
There are no CELS
I do not believe it is Fuel or line freeze up because I have pressure post fuel filter, although it is not as strong as the pressure from my buddies 98 LGT....
reset the security system no love
thoughts?
jmlaser is offline   Reply With Quote
Old 02-06-2011, 06:26 PM   #2
gmullin
Member#: 271800
spark? crank/cam sensor are the injectors getting a singnal
gmullin is offline   Reply With Quote
2002 WRX really weird wiring problem, car wont start, injectors, fuel pump staying on 91turbosedaan Electrical & Lighting 20 01-16-2016 12:14 PM
Experts needed. Car wont start, CL/OL problems, works on group n sometimes WhiteBgeye02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-07-2011 10:14 PM
Parking lights wont work now car wont start inevitable_101 Electrical & Lighting 0 07-21-2009 04:51 PM
01 OBW lean misfire cyl 2 mechanic can't locate cause! GYates Outback Forum 3 08-23-2006 01:57 PM
odd symptoms, wont start desperate 'Old School' Subaru Forum 20 08-30-2005 12:57 AM
