Welcome to the North American Subaru Impreza Owners Club Sunday August 2, 2015
Old 02-07-2011, 12:34 AM   #1
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Default stuck in fifth gear...
so after a long two days of problems the ppg 5mt is in the car. after going for a 30 mile highway cruise i went to pull it out of fifth gear to slow down on the exit ramp and sure as **** its stuck in fifth gear.
the clutch will disengauge so the engine idles down and everything. connections are good below. just wont pull out of fifth gear even if i pull sorta hard.
called the guy i bought ti from and he said i need to pull the side bolts off and pull a little spring and ball out of it. use a flathead to pop it over out of fifth and repalace that little spring since its prob worn out.
Keep in mind the ppg gearset and syncros only have 500 miles on them prior to me buying and the trans is a 03 5mt with 60k miles on it. shifter forks have 20k miles on them but are oem.
Trans is filled with redline shockproof gear lube and all of my shifts were soft as ever. hard to believe with the ppg but after install my engine is not running at all but thats a different thread to deal with. and needless to say she got flat bedded home yesterday evening.
anyways any ideas woudl be great or should i just do what the guy told me to do since its happened to him before. just would like some other members imput as well.
problem was worn springs which caused the ball not to push into the fork rod and hold it in place. fixed with three new springs for dealership. thank gosh!
WhiteBgeye02 is offline   Reply With Quote
Old 02-07-2011, 05:39 PM   #2
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
any ideas? i got the plug and spring and ball out but it wont pop over unless i am trying the wrong hole....
Old 02-08-2011, 06:18 PM   #3
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
well no luck and no advice so i am going to pull it tonight/tom morn.
Old 08-07-2012, 09:04 PM   #4
NICKNICK
Member#: 328442
Did you ever figure it out? What happened?
Mine got stuck in fifth, and it "fixed" itself when they put it on a lift. once the wheels were off the ground and the tension was out of the driveline, it was OK...
i hope it doesn't happen again.
NICKNICK is offline   Reply With Quote
Old 08-07-2012, 10:00 PM   #5
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
there are three balls in the side of the trans under three 10mm bolts. they line up vertically. they have a spring pushing on them and stick into the side of the shifter forks in triangle shaped slots. when you shift the ball slides out of the one notch and moves to the next one on the fork so it doesnt let it pop out basically. idk why mine ever did it but i made the springs longer by stretching them a bit after applying heat. only like 1cm in lenght and then put them back. this way when i am shifting out of a gear the ball slides into the middle slot ont he shifter fork i just pulled out of and doesnt get stuck part way sliding in while i go to the next
Old 02-11-2013, 09:06 AM   #6
666stars
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd 5 speed now!
Same thing just happened to my car. Dealer rebuilt the trans and added a dccd housing to my 5 speed. they took it out for a test drive and 1-4 gears shifted perfect. they went to shift into fifth and when they did it wouldnt come out of gear .I just went by the dealer and asked the guy if he replaced those 3 springs on the rebuild, he said no. So he's checking them now.
666stars is offline   Reply With Quote
Old 02-11-2013, 03:01 PM   #7
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
yeah pull them out and it should help release it. if not the rear section needs to be taken off so the shift fork from 3/4 becomes unstuck partway so the 5/r fork can slide out of gear. i have yet to have a problem. knock on wood in the past two years now.
Old 02-11-2013, 04:19 PM   #8
666stars
Member#: 221364
This piece up top is stuck for some reason, it's really actually touching the shift fork.
Old 02-11-2013, 04:23 PM   #9
666stars
Member#: 221364
Also the mechanic says the housing that I'm using to add dccd is different and it doesn't have a piece inside to stop the part from spinning.
Wrx housing has two pieces cast below the plastic part
Old 02-11-2013, 04:24 PM   #10
666stars
Member#: 221364
Phase 1 case doesn't have those castings
Old 02-18-2013, 10:20 PM   #11
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
looks like you found your problem. idk what that thing is for exactly but maybe it can be eliminated to work with your trans. maybe fine a blown up version of the phase 1 trans and see what its got there. might need a diff end piece.
Old 02-18-2013, 11:04 PM   #12
666stars
Member#: 221364
The phase one looks like this
135i outruns Cayman in Fifth Gear comparison test terps Off-Topic 70 02-21-2008 12:52 AM
04sti tops out in fifth gear between 5000- 5500rpm? splitsec Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 10-30-2005 08:38 PM
HELP, car stuck in 4th gear and won't roll with clutch in silver arrow Transmission (AT/MT) & Driveline 10 12-22-2004 08:57 PM
High Pitched noise in fifth gear flyinwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-24-2004 01:00 PM
CEL cruising in fifth gear kdogpenny1 Newbies & FAQs 8 02-13-2004 12:01 AM
