Old 02-07-2011, 10:43 AM   #1
millertime21
Member#: 224474
2002 PSM WRX
STi Swaped Bugeye
Default JDM Version 7 & Version 8 ECU question
Hi,
I have a 02 wrx with the stock 16 bit ECU and im putting in an 05 STi long block with AVCS and a 04 STi transmission. My question to you all is what ECU do I need to purchase to make my avcs work? I don't want to deal with taking out and replacing my entire engine wiring harness and i heard that if u get the right ECU u can run AVCS without doing that whole swap...is this true? Please chime in with info.
millertime21 is offline   Reply With Quote
Old 02-07-2011, 10:50 AM   #2
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
nothing to see, i'm stock
you need the matching 05 STi ecu for the 05STi long block. Dont mix usdm with jdm
fastnoypi is offline   Reply With Quote
Old 02-07-2011, 10:51 AM   #3
millertime21
Member#: 224474
2002 PSM WRX
STi Swaped Bugeye
so even if i got the JDM v7 or v8 ecu I would be messing with something else?
Old 02-07-2011, 11:24 AM   #4
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
the avcs solenoids are different between the markets, you'd be chasing your tail if there are other unexplainable issues to troubleshoot.
FS: *6 SPEED* JDM STI EJ20 Version 7 & 8 Tranny JdmRacingMotors Drivetrain 391 05-14-2013 05:53 PM
Version 7 out... Version 8 in! subenick Subaru Conversions 4 04-09-2007 09:34 AM
6MT: Version 7 vs Version 8-Need input quickly STi Hunter Transmission (AT/MT) & Driveline 1 01-24-2007 12:36 AM
Version 7 vs Version 8 question WrxRacer305whp Factory 2.0L Turbo Powertrain 32 01-18-2005 09:23 PM
Version 7 and Version 8 Power Potential... dug-e-fresh Factory 2.0L Turbo Powertrain 12 08-08-2003 01:30 AM
Message Board Statistics All times are GMT -4. The time now is 04:08 PM.
